snoodlehouse
Connecting with 2 accounts from behind the same router
I use my main AirVPN account for a home desktop PC. I also have a 3-day account to try it out on my iPhone. When I use the OpenVPN iOS app, I can connect fine using the 4G cellular connection. But when I try to connect to AirVPN using my home WiFi router, the connection times out.
I assume this is because 2 devices are trying to connect to AirVPN from the same IP and there is a conflict somehow. I have tried generating iOS config files for different ports, TCP, UDP. I generated config files for ports 443, 53, and 2018. I have tried forwarding these ports from my router. None of these work with the home Wifi connection. They all work using the 4G connection.
Is there a way to get this to work? (I realize that it is possible to set up my router to use AirVPN. It ended up being way too slow.)
Thanks.
please see:
https://airvpn.org/topic/9171-i-have-two-or-more-computers-at-home-do-i-need-to-use-two-or-more-different-airvpn-account-for-simultaneous-access/
Also, have a look at https://airvpn.org/ddwrt and https://airvpn.org/tomato
Can you please tell us your router brand and model? We'll check if it is Tomato or DD-WRT compatible. If you have already tried that, resulting in unacceptable performance, you might evaluate to setup a computer as a host, sharing Internet connection, in order to allow all the devices in your home network to tunnel their traffic transparently.
