sandrovaldavid
Not sure what this is called or how to do it, but...
I'm not up to speed on the terminology... and don't quite understand what port forwarding, etc. really are...
I'd like to take two voip adapters on my network, cabled into my ddwrt routers, and let them bypass the vpn.
Ideally, I'd like to do it by mac id, because the router assigns ports dynamically and a lot of stuff comes and goes.
What is this called, and how would it be best accomplished?
you can do it through policy routing, supported by DD-WRT. In DD-WRT, once it is connected to an OpenVPN server, you can decide which devices must be tunneled and which not.
