mordants 5 Posted ... I am using http://checkmytorrentip.com/ as a test and leaving connection on with no traffic going, so normally I would see 95.211.191.41 as my Torrent Client IPand later on I refreshed and I saw<snip> <snip> Jun 20 04:32:51 NO uTorrent/3200(27886) Netherlands 95.211.191.41 Jun 19 23:18:15 NO uTorrent/3200(27886) Netherlands What does this mean? is Traffic still secure? I went to http://ipleak.net/ and looks normal to meYour IP Address95.211.191.41Netherlands - Noord-Holland LeaseWeb B.V. - AirVPN Server (Exit) Detected DNS Address95.211.191.41Netherlands - Noord-Holland LeaseWeb B.V. - AirVPN Server (Exit) I went to http://www.dnsleaktest.com/Your DNS test resultsThis page shows the DNS servers that your computer is using to resolve DNS names. The owners of the servers listed below have the ability to log the names of all websites you connect to.WARNING: If you are connected to a VPN service and ANY of the servers listed below are not provided by the VPN service then your DNS may be leaking. (You should be able to recognise them based on the hostname, ISP and location). This is not an issue if you trust the owners of these servers with your private data.We detected the 1 DNS server listed below.IP: 95.211.191.41 Hostname: hosted-by.leaseweb.com ISP: LeaseWeb B.V. Country: Netherlands Any thoughts or suggestion?Thanks Quote Share this post Link to post
mordants 5 Posted ... So i disconnected and reconnected and tried again.....I still get the same IP of 109.235.50.195 from http://checkmytorrentip.com But when I checkhttp://ipleak.net/it shows me the Airvpn server IP like Your IP Address95.211.191.41Netherlands - Noord-Holland LeaseWeb B.V. - AirVPN Server (Exit) Detected DNS Address77.109.138.45Switzerland - Zurich Init Seven AG - Residential I won't be using my computer because I am not sure if its secure with Airvpn...Please let me know your thoughts/suggestion thanks Quote Share this post Link to post
mordants 5 Posted ... Trying to see who this IP belongs toHttp://www.netrouting.nl/aboutus I switched from Leporis Server to OPHi server and still noticing the same issue Will try a different country server vs netherland/amasterdam Tried using our Spain Box and I don't see any discrepancies in the IP on torrent side or web browser side....I'll use Sweden for now... Would love to hear on the Netherland when someone from Staff can. Thanks Quote Share this post Link to post
Staff 10711 Posted ... @mordants Hello, about trackers, it's normal, probably you have missed this:https://airvpn.org/topic/9499-connecting-to-trackers-fails-from-different-servers/?do=findComment&comment=10370 About DNS, check for DNS leaks (if you run Windows). Kind regards Quote Share this post Link to post
JohnDaley 0 Posted ... Thank you for the terrific VPN service. Mordants, the exact same thing just happened to me. I'm connected to the Sirius server in the US and my IP address when I use http://ipleak.net/ and checkmytorrentip.com was the same (<Edit>). Maybe 10 mins ago, I was disconnected and then immediately reconnected to the Sirius server. When I was reconnected, though, the IP address that http://ipleak.net/ gives me is (<Edit>). However, checkmytorrentip.com is saying that my IP is (<snip>) in the Netherlands. Interestingly, checkmytorrentip.com also says that my browser IP is (<snip>), where as ipleak.net says the browser IP is (<Edit>), so my guess is that checkmytorrentip.com is messing up. I thought maybe it was an artifact, so I disconnected again and closed down my torrent program, but, when I reconnected, the two different IP addresses reemerged. Quote Share this post Link to post
Staff 10711 Posted ... Hello, it's not an artifact, and all the services you're using return the correct data. Everything is fine, this is our anti-blocking system working. Please do not publish IP addresses. Kind regards Quote Share this post Link to post
