Baraka
ANSWERED Inactivity timeout after switching servers?
Every time I switch servers I can pretty much count on what is logged as an "inactivity timeout". It doesn't matter that my connection is constantly active. This is happening at the router level, where the VPN is implemented.
I can never predict when it will happen. It usually happens within 24 hours. Other times, like tonight, it can be a few days later. What's going on?
Here is what's in my log:
Jun 11 22:08:25 asus daemon.notice openvpn[13807]: [server] Inactivity timeout (--ping-restart), restartingJun 11 22:08:25 asus daemon.notice openvpn[13807]: TCP/UDP: Closing socketJun 11 22:08:25 asus daemon.notice openvpn[13807]: SIGUSR1[soft,ping-restart] received, process restartingJun 11 22:08:25 asus daemon.notice openvpn[13807]: Restart pause, 2 second(s)Jun 11 22:08:27 asus daemon.warn openvpn[13807]: NOTE: the current --script-security setting may allow this configuration to call user-defined scriptsJun 11 22:08:27 asus daemon.notice openvpn[13807]: Re-using SSL/TLS contextJun 11 22:08:27 asus daemon.notice openvpn[13807]: LZO compression initializedJun 11 22:08:27 asus daemon.notice openvpn[13807]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]Jun 11 22:08:27 asus daemon.notice openvpn[13807]: Socket Buffers: R=[114688->131072] S=[114688->131072]Jun 11 22:08:27 asus daemon.notice openvpn[13807]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]Jun 11 22:08:27 asus daemon.notice openvpn[13807]: UDPv4 link local: [undef]Jun 11 22:08:27 asus daemon.notice openvpn[13807]: UDPv4 link remote: 184.75.214.164:80Jun 11 22:08:27 asus daemon.notice openvpn[13807]: TLS: Initial packet from 184.75.214.164:80, sid=0f154308 3e8fcad9Jun 11 22:08:27 asus daemon.notice openvpn[13807]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.orgJun 11 22:08:27 asus daemon.notice openvpn[13807]: VERIFY OK: nsCertType=SERVERJun 11 22:08:27 asus daemon.notice openvpn[13807]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.orgJun 11 22:08:29 asus daemon.notice openvpn[13807]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyJun 11 22:08:29 asus daemon.notice openvpn[13807]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationJun 11 22:08:29 asus daemon.notice openvpn[13807]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyJun 11 22:08:29 asus daemon.notice openvpn[13807]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationJun 11 22:08:29 asus daemon.notice openvpn[13807]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSAJun 11 22:08:29 asus daemon.notice openvpn[13807]: [server] Peer Connection Initiated with 184.75.214.164:80Jun 11 22:08:31 asus daemon.notice openvpn[13807]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)Jun 11 22:08:31 asus daemon.notice openvpn[13807]: AUTH: Received AUTH_FAILED control messageJun 11 22:08:31 asus daemon.notice openvpn[13807]: TCP/UDP: Closing socketJun 11 22:08:31 asus daemon.notice openvpn[13807]: /sbin/route del -net 10.6.0.1 netmask 255.255.255.255Jun 11 22:08:31 asus daemon.notice openvpn[13807]: /sbin/route del -net 184.75.214.164 netmask 255.255.255.255Jun 11 22:08:31 asus daemon.notice openvpn[13807]: /sbin/route del -net 0.0.0.0 netmask 128.0.0.0Jun 11 22:08:31 asus daemon.notice openvpn[13807]: /sbin/route del -net 128.0.0.0 netmask 128.0.0.0Jun 11 22:08:31 asus daemon.notice openvpn[13807]: Closing TUN/TAP interfaceJun 11 22:08:31 asus daemon.notice openvpn[13807]: /sbin/ifconfig tun12 0.0.0.0Jun 11 22:08:31 asus daemon.notice openvpn[13807]: updown.sh tun12 1500 1558 10.6.0.6 10.6.0.5 initJun 11 22:08:31 asus daemon.info dnsmasq[13849]: exiting on receipt of SIGTERMJun 11 22:08:31 asus user.debug init[1]: 182: pptp peerdns disabledJun 11 22:08:31 asus daemon.info dnsmasq[14051]: started, version 2.61 cachesize 1500Jun 11 22:08:31 asus daemon.info dnsmasq[14051]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrackJun 11 22:08:31 asus daemon.info dnsmasq[14051]: asynchronous logging enabled, queue limit is 5 messagesJun 11 22:08:31 asus daemon.info dnsmasq-dhcp[14051]: DHCP, IP range 10.100.100.2 -- 10.100.100.62, lease time 7dJun 11 22:08:31 asus daemon.info dnsmasq[14051]: reading /etc/resolv.dnsmasqJun 11 22:08:31 asus daemon.info dnsmasq[14051]: using nameserver 64.0.55.201#53Jun 11 22:08:31 asus daemon.info dnsmasq[14051]: using nameserver 216.167.252.197#53Jun 11 22:08:31 asus daemon.info dnsmasq[14051]: using nameserver 67.212.94.250#53Jun 11 22:08:31 asus daemon.info dnsmasq[14051]: read /etc/hosts - 2 addressesJun 11 22:08:31 asus daemon.info dnsmasq[14051]: read /etc/dnsmasq/hosts/hosts - 22 addressesJun 11 22:08:31 asus daemon.info dnsmasq-dhcp[14051]: read /etc/dnsmasq/dhcp/dhcp-hostsJun 11 22:08:31 asus daemon.notice openvpn[13807]: SIGTERM[soft,auth-failure] received, process exiting
The past couple of days have been a nightmare. Many disconnections. Same server though. See the log:
Jun 22 00:53:11 asus daemon.notice openvpn[17350]: [server] Inactivity timeout (--ping-restart), restartingJun 22 00:53:11 asus daemon.notice openvpn[17350]: TCP/UDP: Closing socketJun 22 00:53:11 asus daemon.notice openvpn[17350]: SIGUSR1[soft,ping-restart] received, process restartingJun 22 00:53:11 asus daemon.notice openvpn[17350]: Restart pause, 2 second(s)Jun 22 00:53:13 asus daemon.warn openvpn[17350]: NOTE: the current --script-security setting may allow this configuration to call user-defined scriptsJun 22 00:53:13 asus daemon.notice openvpn[17350]: Re-using SSL/TLS contextJun 22 00:53:13 asus daemon.notice openvpn[17350]: LZO compression initializedJun 22 00:53:13 asus daemon.notice openvpn[17350]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]Jun 22 00:53:13 asus daemon.notice openvpn[17350]: Socket Buffers: R=[114688->131072] S=[114688->131072]Jun 22 00:53:13 asus daemon.notice openvpn[17350]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]Jun 22 00:53:13 asus daemon.notice openvpn[17350]: UDPv4 link local: [undef]Jun 22 00:53:13 asus daemon.notice openvpn[17350]: UDPv4 link remote: 184.75.214.164:80Jun 22 00:53:37 asus daemon.info dnsmasq-dhcp[17392]: DHCPINFORM(br0) 10.100.100.22 08:2e:5f:71:61:21 Jun 22 00:53:37 asus daemon.info dnsmasq-dhcp[17392]: DHCPACK(br0) 10.100.100.22 08:2e:5f:71:61:21 TerrianJun 22 00:54:13 asus daemon.notice openvpn[17350]: [UNDEF] Inactivity timeout (--ping-restart), restartingJun 22 00:54:13 asus daemon.notice openvpn[17350]: TCP/UDP: Closing socketJun 22 00:54:13 asus daemon.notice openvpn[17350]: SIGUSR1[soft,ping-restart] received, process restartingJun 22 00:54:13 asus daemon.notice openvpn[17350]: Restart pause, 2 second(s)Jun 22 00:54:15 asus daemon.warn openvpn[17350]: NOTE: the current --script-security setting may allow this configuration to call user-defined scriptsJun 22 00:54:15 asus daemon.notice openvpn[17350]: Re-using SSL/TLS contextJun 22 00:54:15 asus daemon.notice openvpn[17350]: LZO compression initializedJun 22 00:54:15 asus daemon.notice openvpn[17350]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]Jun 22 00:54:15 asus daemon.notice openvpn[17350]: Socket Buffers: R=[114688->131072] S=[114688->131072]Jun 22 00:54:15 asus daemon.notice openvpn[17350]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]Jun 22 00:54:15 asus daemon.notice openvpn[17350]: UDPv4 link local: [undef]Jun 22 00:54:15 asus daemon.notice openvpn[17350]: UDPv4 link remote: 184.75.214.164:80Jun 22 00:55:15 asus daemon.notice openvpn[17350]: [UNDEF] Inactivity timeout (--ping-restart), restartingJun 22 00:55:15 asus daemon.notice openvpn[17350]: TCP/UDP: Closing socketJun 22 00:55:15 asus daemon.notice openvpn[17350]: SIGUSR1[soft,ping-restart] received, process restartingJun 22 00:55:15 asus daemon.notice openvpn[17350]: Restart pause, 2 second(s)Jun 22 00:55:17 asus daemon.warn openvpn[17350]: NOTE: the current --script-security setting may allow this configuration to call user-defined scriptsJun 22 00:55:17 asus daemon.notice openvpn[17350]: Re-using SSL/TLS contextJun 22 00:55:17 asus daemon.notice openvpn[17350]: LZO compression initializedJun 22 00:55:17 asus daemon.notice openvpn[17350]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]Jun 22 00:55:17 asus daemon.notice openvpn[17350]: Socket Buffers: R=[114688->131072] S=[114688->131072]Jun 22 00:55:17 asus daemon.notice openvpn[17350]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]Jun 22 00:55:17 asus daemon.notice openvpn[17350]: UDPv4 link local: [undef]Jun 22 00:55:17 asus daemon.notice openvpn[17350]: UDPv4 link remote: 184.75.214.164:80Jun 22 00:55:35 asus daemon.info dnsmasq-dhcp[17392]: DHCPINFORM(br0) 10.100.100.22 08:2e:5f:71:61:21 Jun 22 00:55:35 asus daemon.info dnsmasq-dhcp[17392]: DHCPACK(br0) 10.100.100.22 08:2e:5f:71:61:21 TerrianJun 22 00:56:17 asus daemon.notice openvpn[17350]: [UNDEF] Inactivity timeout (--ping-restart), restartingJun 22 00:56:17 asus daemon.notice openvpn[17350]: TCP/UDP: Closing socketJun 22 00:56:17 asus daemon.notice openvpn[17350]: SIGUSR1[soft,ping-restart] received, process restartingJun 22 00:56:17 asus daemon.notice openvpn[17350]: Restart pause, 2 second(s)Jun 22 00:56:19 asus daemon.warn openvpn[17350]: NOTE: the current --script-security setting may allow this configuration to call user-defined scriptsJun 22 00:56:19 asus daemon.notice openvpn[17350]: Re-using SSL/TLS contextJun 22 00:56:19 asus daemon.notice openvpn[17350]: LZO compression initializedJun 22 00:56:19 asus daemon.notice openvpn[17350]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]Jun 22 00:56:19 asus daemon.notice openvpn[17350]: Socket Buffers: R=[114688->131072] S=[114688->131072]Jun 22 00:56:19 asus daemon.notice openvpn[17350]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]Jun 22 00:56:19 asus daemon.notice openvpn[17350]: UDPv4 link local: [undef]Jun 22 00:56:19 asus daemon.notice openvpn[17350]: UDPv4 link remote: 184.75.214.164:80Jun 22 00:56:19 asus daemon.notice openvpn[17350]: TLS: Initial packet from 184.75.214.164:80, sid=2f23600d ff9b62f2Jun 22 00:56:19 asus daemon.notice openvpn[17350]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.orgJun 22 00:56:19 asus daemon.notice openvpn[17350]: VERIFY OK: nsCertType=SERVERJun 22 00:56:19 asus daemon.notice openvpn[17350]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.orgJun 22 00:56:21 asus daemon.notice openvpn[17350]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyJun 22 00:56:21 asus daemon.notice openvpn[17350]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationJun 22 00:56:21 asus daemon.notice openvpn[17350]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyJun 22 00:56:21 asus daemon.notice openvpn[17350]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationJun 22 00:56:21 asus daemon.notice openvpn[17350]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSAJun 22 00:56:21 asus daemon.notice openvpn[17350]: [server] Peer Connection Initiated with 184.75.214.164:80Jun 22 00:56:23 asus daemon.notice openvpn[17350]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)Jun 22 00:56:23 asus daemon.notice openvpn[17350]: AUTH: Received AUTH_FAILED control messageJun 22 00:56:23 asus daemon.notice openvpn[17350]: TCP/UDP: Closing socketJun 22 00:56:23 asus daemon.notice openvpn[17350]: /sbin/route del -net 10.6.0.1 netmask 255.255.255.255Jun 22 00:56:23 asus daemon.notice openvpn[17350]: /sbin/route del -net 184.75.214.164 netmask 255.255.255.255Jun 22 00:56:23 asus daemon.notice openvpn[17350]: /sbin/route del -net 0.0.0.0 netmask 128.0.0.0Jun 22 00:56:23 asus daemon.notice openvpn[17350]: /sbin/route del -net 128.0.0.0 netmask 128.0.0.0Jun 22 00:56:23 asus daemon.notice openvpn[17350]: Closing TUN/TAP interfaceJun 22 00:56:23 asus daemon.notice openvpn[17350]: /sbin/ifconfig tun12 0.0.0.0Jun 22 00:56:23 asus daemon.notice openvpn[17350]: updown.sh tun12 1500 1558 10.6.0.6 10.6.0.5 initJun 22 00:56:23 asus daemon.info dnsmasq[17392]: exiting on receipt of SIGTERMJun 22 00:56:23 asus user.debug init[1]: 182: pptp peerdns disabledJun 22 00:56:23 asus daemon.info dnsmasq[17435]: started, version 2.61 cachesize 1500Jun 22 00:56:23 asus daemon.info dnsmasq[17435]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrackJun 22 00:56:23 asus daemon.info dnsmasq[17435]: asynchronous logging enabled, queue limit is 5 messagesJun 22 00:56:23 asus daemon.info dnsmasq-dhcp[17435]: DHCP, IP range 10.100.100.2 -- 10.100.100.62, lease time 7dJun 22 00:56:23 asus daemon.info dnsmasq[17435]: reading /etc/resolv.dnsmasqJun 22 00:56:23 asus daemon.info dnsmasq[17435]: using nameserver 64.0.55.201#53Jun 22 00:56:23 asus daemon.info dnsmasq[17435]: using nameserver 216.167.252.197#53Jun 22 00:56:23 asus daemon.info dnsmasq[17435]: using nameserver 67.212.94.250#53Jun 22 00:56:23 asus daemon.info dnsmasq[17435]: read /etc/hosts - 2 addressesJun 22 00:56:23 asus daemon.notice openvpn[17350]: SIGTERM[soft,auth-failure] received, process exitingJun 22 00:56:23 asus daemon.info dnsmasq[17435]: read /etc/dnsmasq/hosts/hosts - 22 addressesJun 22 00:56:23 asus daemon.info dnsmasq-dhcp[17435]: read /etc/dnsmasq/dhcp/dhcp-hosts
What's up??
@Baraka
Hopefully momentary problems from your ISP or somewhere between your node and the server. We don't detect any particular problem with that server.
