g4life666 0 Posted ... Hi, so few days ago i tried connect to airvpn servers as usual, with latest openvpn installed and i couldnt make it. At first, i will show you my log. 2013-06-01 - 14:19 AirVPN client version: 1,8 2013-06-01 - 14:19 Reading options from C:\Users\root\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 2013-06-01 - 14:19 OpenVPN bundle version: OpenVPN 2.3.0 2013-06-01 - 14:19 OpenVPN current version: OpenVPN 2.3.0 2013-06-01 - 14:19 Ready. 2013-06-01 - 14:19 Login... 2013-06-01 - 14:19 Login success. 2013-06-01 - 14:20 Contacting service... 2013-06-01 - 14:20 Connecting... 2013-06-01 - 14:20 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 2013-06-01 - 14:20 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2013-06-01 - 14:20 Socket Buffers: R=[8192->8192] S=[8192->8192] 2013-06-01 - 14:20 UDPv4 link local: [undef] 2013-06-01 - 14:20 UDPv4 link remote: [AF_INET]95.211.191.33:443 2013-06-01 - 14:20 TLS: Initial packet from [AF_INET]95.211.191.33:443, sid=e89f00df 3042e494 2013-06-01 - 14:20 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 2013-06-01 - 14:20 VERIFY OK: nsCertType=SERVER 2013-06-01 - 14:20 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 2013-06-01 - 14:20 TLS_ERROR: BIO read tls_read_plaintext error: error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number 2013-06-01 - 14:20 TLS Error: TLS object -> incoming plaintext read error 2013-06-01 - 14:20 TLS Error: TLS handshake failed 2013-06-01 - 14:20 SIGUSR1[soft,tls-error] received, process restarting 2013-06-01 - 14:20 Restart pause, 2 second(s) 2013-06-01 - 14:20 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2013-06-01 - 14:20 Socket Buffers: R=[8192->8192] S=[8192->8192] 2013-06-01 - 14:20 UDPv4 link local: [undef] 2013-06-01 - 14:20 UDPv4 link remote: [AF_INET]95.211.191.33:443 2013-06-01 - 14:20 TLS: Initial packet from [AF_INET]95.211.191.33:443, sid=5c56134a 4eb02721 2013-06-01 - 14:20 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 2013-06-01 - 14:20 VERIFY OK: nsCertType=SERVER 2013-06-01 - 14:20 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 2013-06-01 - 14:20 TLS_ERROR: BIO read tls_read_plaintext error: error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number 2013-06-01 - 14:20 TLS Error: TLS object -> incoming plaintext read error 2013-06-01 - 14:20 TLS Error: TLS handshake failed 2013-06-01 - 14:20 SIGUSR1[soft,tls-error] received, process restarting 2013-06-01 - 14:20 Restart pause, 2 second(s) 2013-06-01 - 14:20 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2013-06-01 - 14:20 Socket Buffers: R=[8192->8192] S=[8192->8192] 2013-06-01 - 14:20 UDPv4 link local: [undef] 2013-06-01 - 14:20 UDPv4 link remote: [AF_INET]95.211.191.33:443 2013-06-01 - 14:20 TLS: Initial packet from [AF_INET]95.211.191.33:443, sid=0108fe22 7deb372d 2013-06-01 - 14:20 TLS_ERROR: BIO read tls_read_plaintext error: error:0D078094:asn1 encoding routines:ASN1_ITEM_EX_D2I:sequence length mismatch: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:1409000D:SSL routines:SSL3_GET_SERVER_CERTIFICATE:ASN1 lib 2013-06-01 - 14:20 TLS Error: TLS object -> incoming plaintext read error 2013-06-01 - 14:20 TLS Error: TLS handshake failed 2013-06-01 - 14:20 SIGUSR1[soft,tls-error] received, process restarting 2013-06-01 - 14:20 Restart pause, 2 second(s) 2013-06-01 - 14:20 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2013-06-01 - 14:20 Socket Buffers: R=[8192->8192] S=[8192->8192] 2013-06-01 - 14:20 UDPv4 link local: [undef] 2013-06-01 - 14:20 UDPv4 link remote: [AF_INET]95.211.191.33:443 2013-06-01 - 14:20 TLS: Initial packet from [AF_INET]95.211.191.33:443, sid=e37f5c73 999c9dde 2013-06-01 - 14:20 TLS_ERROR: BIO read tls_read_plaintext error: error:0D078094:asn1 encoding routines:ASN1_ITEM_EX_D2I:sequence length mismatch: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:1409000D:SSL routines:SSL3_GET_SERVER_CERTIFICATE:ASN1 lib 2013-06-01 - 14:20 TLS Error: TLS object -> incoming plaintext read error 2013-06-01 - 14:20 TLS Error: TLS handshake failed 2013-06-01 - 14:20 SIGUSR1[soft,tls-error] received, process restarting 2013-06-01 - 14:20 Restart pause, 2 second(s) 2013-06-01 - 14:20 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2013-06-01 - 14:20 Socket Buffers: R=[8192->8192] S=[8192->8192] 2013-06-01 - 14:20 UDPv4 link local: [undef] 2013-06-01 - 14:20 UDPv4 link remote: [AF_INET]95.211.191.33:443 2013-06-01 - 14:20 TLS: Initial packet from [AF_INET]95.211.191.33:443, sid=5342b985 4c621429 2013-06-01 - 14:20 TLS_ERROR: BIO read tls_read_plaintext error: error:0D078094:asn1 encoding routines:ASN1_ITEM_EX_D2I:sequence length mismatch: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:1409000D:SSL routines:SSL3_GET_SERVER_CERTIFICATE:ASN1 lib 2013-06-01 - 14:20 TLS Error: TLS object -> incoming plaintext read error 2013-06-01 - 14:20 TLS Error: TLS handshake failed 2013-06-01 - 14:20 SIGUSR1[soft,tls-error] received, process restarting 2013-06-01 - 14:20 Restart pause, 2 second(s) 2013-06-01 - 14:20 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2013-06-01 - 14:20 Socket Buffers: R=[8192->8192] S=[8192->8192] 2013-06-01 - 14:20 UDPv4 link local: [undef] 2013-06-01 - 14:20 UDPv4 link remote: [AF_INET]95.211.191.33:443 2013-06-01 - 14:20 TLS: Initial packet from [AF_INET]95.211.191.33:443, sid=e48cfe2d 2db4590e 2013-06-01 - 14:20 TLS_ERROR: BIO read tls_read_plaintext error: error:0D078094:asn1 encoding routines:ASN1_ITEM_EX_D2I:sequence length mismatch: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error: error:1409000D:SSL routines:SSL3_GET_SERVER_CERTIFICATE:ASN1 lib 2013-06-01 - 14:20 TLS Error: TLS object -> incoming plaintext read error 2013-06-01 - 14:20 TLS Error: TLS handshake failed 2013-06-01 - 14:20 SIGUSR1[soft,tls-error] received, process restarting 2013-06-01 - 14:20 Restart pause, 2 second(s) I have disabled Windows Firewall, router firewall and kaspersky firewall. I did reinstall all the softwer without UAC and Kaspersky AV activated and ofc. on admin rights. This isnt ISP because OpenVPN & AirVPN works as it should on my laptop in the same network, i also did tried connect via other ports then udp. Do you have any ideas what it might be? Please, help! Quote Share this post Link to post
Staff 10432 Posted ... Hello! This isnt ISP because OpenVPN & AirVPN works as it should on my laptop in the same network, i also did tried connect via other ports then udp. So it must be something specific in that computer. Do you notice, on this computer, any problem with SSL certificates/keys (https sites not connecting, SMTP over SSL/TLS...)? Kind regards Quote Share this post Link to post
g4life666 0 Posted ... Thanks for your reply, at first you should take a look on SS below:http://imageshack.us/a/img153/5732/capturezkp.png It looks like there are problems with TAP-Windows Adapter, i did reinstall OpenVPN with newest version and problem still occurs, i dont know how i may fix it.I didnt notice any problems with SSL, it works fine. Quote Share this post Link to post
Staff 10432 Posted ... Hello! If the screenshot is taken while OpenVPN is running, can you please check that the adapter is enabled? Kind regards Quote Share this post Link to post
g4life666 0 Posted ... I did take screenshot while OpenVPN was NOT running, aslo i already check if something will change while i start OpenVPN, answer is - no, still TAP Adapter is "unplugged", any ideas? Quote Share this post Link to post
Staff 10432 Posted ... Hello! Please enable it. If you see that it is already enabled, disable it and then enable it (this will force an adapter reset). Also, if the problem persists we would recommend that you contact at your convenience Microsoft support, you have enough data to receive a proper support from Microsoft. Kind regards Quote Share this post Link to post
g4life666 0 Posted ... It doesnt help me at all - i mean reset TAP-Windows Adapter. Last question, i think that uninstalling all software and then cleaning registry could help. As you can see on ss TAP-Windows Adapter is also called "V9" - it could be problem with drivers or few adapters already installed. Could you tell me where to look for info about TAP-Windows adapter and OpenVPN in Windows 7 Registry? I might be wrong, but i dont want to reinstall system again, trust me ;\ Quote Share this post Link to post
Staff 10432 Posted ... Hello! Simply uninstalling OpenVPN is the fastest procedure to remove the driver. Alternatively, please see here:https://community.openvpn.net/openvpn/wiki/ManagingWindowsTAPDrivers Kind regards Quote Share this post Link to post
g4life666 0 Posted ... It doesnt help me at all, im really dissapointed. Quote Share this post Link to post
g4life666 0 Posted ... While im trying to connect VIA TCP: 2013-06-08 - 17:25 AirVPN client version: 1,8 2013-06-08 - 17:25 Reading options from C:\Users\root\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 2013-06-08 - 17:25 OpenVPN bundle version: OpenVPN 2.3.0 2013-06-08 - 17:25 OpenVPN current version: OpenVPN 2.2.2 2013-06-08 - 17:25 Ready. 2013-06-08 - 17:25 Login... 2013-06-08 - 17:25 Login success. 2013-06-08 - 17:25 Contacting service... 2013-06-08 - 17:25 Connecting... 2013-06-08 - 17:25 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 2013-06-08 - 17:25 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2013-06-08 - 17:25 LZO compression initialized 2013-06-08 - 17:25 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ] 2013-06-08 - 17:25 Socket Buffers: R=[8192->8192] S=[8192->8192] 2013-06-08 - 17:25 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ] 2013-06-08 - 17:25 Local Options hash (VER=V4): '958c5492' 2013-06-08 - 17:25 Expected Remote Options hash (VER=V4): '79ef4284' 2013-06-08 - 17:25 Attempting to establish TCP connection with 31.193.12.74:80 2013-06-08 - 17:25 TCP connection established with 31.193.12.74:80 2013-06-08 - 17:25 TCPv4_CLIENT link local: [undef] 2013-06-08 - 17:25 TCPv4_CLIENT link remote: 31.193.12.74:80 2013-06-08 - 17:25 TLS: Initial packet from 31.193.12.74:80, sid=cd1bcbbe 9924a596 2013-06-08 - 17:25 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 2013-06-08 - 17:25 VERIFY OK: nsCertType=SERVER 2013-06-08 - 17:25 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 2013-06-08 - 17:26 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-06-08 - 17:26 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-06-08 - 17:26 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-06-08 - 17:26 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-06-08 - 17:26 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 2013-06-08 - 17:26 [server] Peer Connection Initiated with 31.193.12.74:80 2013-06-08 - 17:26 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2013-06-08 - 17:26 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.7.0.1,comp-lzo no,route 10.7.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.7.2.202 10.7.2.201' 2013-06-08 - 17:26 OPTIONS IMPORT: timers and/or timeouts modified 2013-06-08 - 17:26 OPTIONS IMPORT: LZO parms modified 2013-06-08 - 17:26 OPTIONS IMPORT: --ifconfig/up options modified 2013-06-08 - 17:26 OPTIONS IMPORT: route options modified 2013-06-08 - 17:26 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2013-06-08 - 17:26 ROUTE default_gateway=192.168.1.1 2013-06-08 - 17:26 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D3451D16-D5B4-4184-AF5E-D2B352127D40}.tap 2013-06-08 - 17:26 TAP-Win32 Driver Version 9.9 2013-06-08 - 17:26 TAP-Win32 MTU=1500 2013-06-08 - 17:26 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.7.2.202/255.255.255.252 on interface {D3451D16-D5B4-4184-AF5E-D2B352127D40} [DHCP-serv: 10.7.2.201, lease-time: 31536000] 2013-06-08 - 17:26 Successful ARP Flush on interface [17] {D3451D16-D5B4-4184-AF5E-D2B352127D40} 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 Route: Waiting for TUN/TAP interface to come up... 2013-06-08 - 17:26 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 2013-06-08 - 17:26 C:\WINDOWS\system32\route.exe ADD 31.193.12.74 MASK 255.255.255.255 192.168.1.1 2013-06-08 - 17:26 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 2013-06-08 - 17:26 Route addition via IPAPI succeeded [adaptive] 2013-06-08 - 17:26 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.7.2.201 2013-06-08 - 17:26 Warning: route gateway is not reachable on any active network adapters: 10.7.2.201 2013-06-08 - 17:26 Route addition via IPAPI failed [adaptive] 2013-06-08 - 17:26 Route addition fallback to route.exe 2013-06-08 - 17:26 OK! 2013-06-08 - 17:26 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.7.2.201 2013-06-08 - 17:26 Warning: route gateway is not reachable on any active network adapters: 10.7.2.201 2013-06-08 - 17:26 Route addition via IPAPI failed [adaptive] 2013-06-08 - 17:26 Route addition fallback to route.exe 2013-06-08 - 17:26 OK! 2013-06-08 - 17:26 C:\WINDOWS\system32\route.exe ADD 10.7.0.1 MASK 255.255.255.255 10.7.2.201 2013-06-08 - 17:26 Warning: route gateway is not reachable on any active network adapters: 10.7.2.201 2013-06-08 - 17:26 Route addition via IPAPI failed [adaptive] 2013-06-08 - 17:26 Route addition fallback to route.exe 2013-06-08 - 17:26 OK! 2013-06-08 - 17:26 SYSTEM ROUTING TABLE 2013-06-08 - 17:26 .1 p=0 i=11 t=4 pr=3 a=5446 h=0 m=20/0/0/0/0 2013-06-08 - 17:26 201 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0 2013-06-08 - 17:26 10.7.2.201 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0 2013-06-08 - 17:26 255 192.168.1.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0 2013-06-08 - 17:26 .0.1 p=0 i=1 t=3 pr=3 a=7435 h=0 m=306/0/0/0/0 2013-06-08 - 17:26 127.0.0.1 p=0 i=1 t=3 pr=3 a=7435 h=0 m=306/0/0/0/0 2013-06-08 - 17:26 55.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=7435 h=0 m=306/0/0/0/0 2013-06-08 - 17:26 2.201 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0 2013-06-08 - 17:26 69.254.205.67 p=0 i=17 t=3 pr=3 a=248 h=0 m=286/0/0/0/0 2013-06-08 - 17:26 5.255 169.254.205.67 p=0 i=17 t=3 pr=3 a=248 h=0 m=286/0/0/0/0 2013-06-08 - 17:26 55.255 169.254.205.67 p=0 i=17 t=3 pr=3 a=248 h=0 m=286/0/0/0/0 2013-06-08 - 17:26 192.168.1.101 p=0 i=11 t=3 pr=3 a=5446 h=0 m=276/0/0/0/0 2013-06-08 - 17:26 .255 192.168.1.101 p=0 i=11 t=3 pr=3 a=5446 h=0 m=276/0/0/0/0 2013-06-08 - 17:26 .255 192.168.1.101 p=0 i=11 t=3 pr=3 a=5446 h=0 m=276/0/0/0/0 2013-06-08 - 17:26 .0.1 p=0 i=1 t=3 pr=3 a=7435 h=0 m=306/0/0/0/0 2013-06-08 - 17:26 68.1.101 p=0 i=11 t=3 pr=3 a=5446 h=0 m=276/0/0/0/0 2013-06-08 - 17:26 54.205.67 p=0 i=17 t=3 pr=3 a=258 h=0 m=286/0/0/0/0 2013-06-08 - 17:26 55.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=7435 h=0 m=306/0/0/0/0 2013-06-08 - 17:26 55.255 192.168.1.101 p=0 i=11 t=3 pr=3 a=5446 h=0 m=276/0/0/0/0 2013-06-08 - 17:26 55.255 169.254.205.67 p=0 i=17 t=3 pr=3 a=258 h=0 m=286/0/0/0/0 2013-06-08 - 17:26 SYSTEM ADAPTER LIST 2013-06-08 - 17:26 TAP-Windows Adapter V9 2013-06-08 - 17:26 Index = 17 2013-06-08 - 17:26 184-AF5E-D2B352127D40} 2013-06-08 - 17:26 .255.0.0 2013-06-08 - 17:26 MAC = 00:ff:d3:45:1d:16 2013-06-08 - 17:26 55.255.255 2013-06-08 - 17:26 .255.255.255 2013-06-08 - 17:26 at Jun 08 17:26:40 2013 2013-06-08 - 17:26 ed Sep 30 13:31:48 1970 2013-06-08 - 17:26 DNS SERV = 2013-06-08 - 17:26 MAC Bridge Miniport 2013-06-08 - 17:26 Index = 18 2013-06-08 - 17:26 7FD-9B1B-428A1FFA5E01} 2013-06-08 - 17:26 IP = 0.0.0.0/0.0.0.0 2013-06-08 - 17:26 MAC = 6e:f0:49:96:58:5e 2013-06-08 - 17:26 55.255.255.255 2013-06-08 - 17:26 DHCP SERV = 2013-06-08 - 17:26 at Jun 08 17:26:40 2013 2013-06-08 - 17:26 hu Jan 01 01:00:00 1970 2013-06-08 - 17:26 DNS SERV = 2013-06-08 - 17:26 Controller 2013-06-08 - 17:26 Index = 11 2013-06-08 - 17:26 37F-8209-530AC3B1D0FF} 2013-06-08 - 17:26 255.255.0 2013-06-08 - 17:26 MAC = 6c:f0:49:96:58:5e 2013-06-08 - 17:26 55.255.255.255 2013-06-08 - 17:26 /255.255.255.255 2013-06-08 - 17:26 at Jun 08 16:55:53 2013 2013-06-08 - 17:26 hu Jan 01 01:00:00 1970 2013-06-08 - 17:26 255.255.255.255 86.63.64.48/255.255.255.255 2013-06-08 - 17:26 Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) 2013-06-08 - 17:26 Starting Management Interface... 2013-06-08 - 17:26 Checking... 2013-06-08 - 17:26 Retrieve statistics... 2013-06-08 - 17:26 Connected. It seems like im connected, but still anywhere i go i see my real IP. Please, help me! Its really annoying, i cant use your services for 6 days now... Quote Share this post Link to post
g4life666 0 Posted ... I finally figure it out, i did install Viscosity and it worked instead of OpenVPN. Quote Share this post Link to post
eric white 0 Posted ... i cant log into my client but i could log into the site....i am a new user what should i do? Quote Share this post Link to post
