Not connected, Your IP: 216.73.216.14
r0dman
Can't portforward for emule
Just start using your services and after reading all the posts about portforward still can´t get high ID in emule.
Tried testing the TCP port I forwarded with http://www.t1shopper.com/tools/port-scan/ but it gives the message 94.46.8.*** isn't responding on port 45754.
Can you help me?
I turned the firewall off (did try it last night and didn't work..) and got one port to work, the other ones still shows not responding and with a grey badge
94.46.8.*** isn't responding on port 20718 ().
94.46.8.*** isn't responding on port 6602 ().
Thanks for the help
edit: Now port 6602 is working fine.. port 20718 is still unreachable. Should I try another port?
