Staff 10407 Posted ... "airvpn.org" blocked (DNS poisoning)Solution: hosts file edit OpenVPN connections are frequently disrupted (reported in Shangai and Beijing)Solution: OpenVPN over SSL works just fine UNCONFIRMED: momentary blocks of Internet domestic lines if a high percentage of encrypted traffic is detected 1 GransenOr reacted to this Quote Share this post Link to post
mhalen 2 Posted ... UNCONFIRMED: momentary blocks of Internet domestic lines if a high percentage of encrypted traffic is detected what is the solution for us if something like that was to happen? Quote Share this post Link to post
Staff 10407 Posted ... UNCONFIRMED: momentary blocks of Internet domestic lines if a high percentage of encrypted traffic is detected what is the solution for us if something like that was to happen? Hello, mix unencrypted and unimportant traffic with encrypted traffic. However, this problem is still unconfirmed and we might delete it, do you have something to add or note about it? If so, feel free to update the thread. Kind regards Quote Share this post Link to post
zhang888 1067 Posted ... Dear AirvPN team, I think it would be a great feature for most China located users to have a background script that downloads random files from public HTTP mirrors, for example Linux OS distributions.That way the Great Firewall counts the ratio between encrypted and non-encrypted traffic and since naturally the ISOs are over 1GB of size, a single download per day should be enough for most users. A simple bash script that saves a file to /dev/null can be done even now, but a better feature would be possibly implementing it in the Air client. "Camouflage mode" 1 Edmusdvew reacted to this Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Staff 10407 Posted ... @zhang888 Hello, you talk about a ratio, do you have some verified information and/or any more detail about that? Kind regards Quote Share this post Link to post
dadapuma 0 Posted ... Does anyone in China have suggestions on servers and configurations to use? I am currently trying all sorts of configurations using Tunnelblick, but most of them won't get past the "Making TCP connection" stage. I've been primarily testing out servers in Canada and the United States, though I've also tested some UK and Singapore servers. I've been trying regular VPN options, as well as SSH and SSL tunnels. So far, I haven't been able to connect at all using SSH and SSL tunnel configurations, even though that seems to be what's recommended for China. Am I doing something wrong here? Or has someone figured out that magic configuration that works really well? Quote Share this post Link to post
Staff 10407 Posted ... Hello, tested and working connections in China are OpenVPN over SSL and OpenVPN over SSH. You must not use Tunnelblick because it does not support this OpenVPN feature, please run OpenVPN directly: https://airvpn.org/topic/9325-development-of-os-x-airvpn-client Best performance is achieved on Singapore servers. Kind regards Quote Share this post Link to post
rootless 1 Posted ... UNCONFIRMED: momentary blocks of Internet domestic lines if a high percentage of encrypted traffic is detected what is the solution for us if something like that was to happen? Hello, mix unencrypted and unimportant traffic with encrypted traffic. However, this problem is still unconfirmed and we might delete it, do you have something to add or note about it? If so, feel free to update the thread. Kind regardsI am not experiencing interruption and I am running almost all encrypted traffic from inside China. Quote Share this post Link to post
jplun585 0 Posted ... I am experiencing DNS redirection to China Telecom when I try to contact a bad url either through a browser or through ping even while connected to AirVPN with SSL, after a DNS flush, and using google DNS servers. My hosts files are clean. Wireshark captures show TCP connections to Chinese IP addresses directly after 8.8.8.8 or 8.8.4.4 DNS Standard query response ... No such name... then I get redirected to malware containing sites. Any suggestions? Quote Share this post Link to post
Staff 10407 Posted ... I am experiencing DNS redirection to China Telecom when I try to contact a bad url either through a browser or through ping even while connected to AirVPN with SSL, after a DNS flush, and using google DNS servers. My hosts files are clean. Wireshark captures show TCP connections to Chinese IP addresses directly after 8.8.8.8 or 8.8.4.4 DNS Standard query response ... No such name... then I get redirected to malware containing sites. Any suggestions? Possible expanation: you're querying the DNS servers outside the tunnel. Anyway you don't provide enough data to tell you anything more useful. Please open a ticket to get support from us. Specify OS exact version and include logs of your client. Kind regards Quote Share this post Link to post
jplun585 0 Posted ... The behavior appears to be rectified by engaging network lock, but it is still interesting that my vpn IP was reaching out to Chinese IPs. Quote Share this post Link to post
