VariableEntity1 0 Posted ... Two questions: 1) When I start the app to "Generate a static OpenVPN Key" I get the error: Cannot Open Shared Secret File c:\program files\openVPN\ for write. Access Denied. Terminating Program Due To Fatal Error 2) I ran the DNS leak test at DNSleaktest.com, and it states "Hello from Sweden!" but when I click on the "check for DNS leaks icon, the page shows an IP address in Sweden at the top, but then it also shows a 3 Comcast IP addresses, and one is from the city in which I live. Does this mean the VPN is not working correctly? Thank you. 1 Dodeordishiob reacted to this Quote Share this post Link to post
Staff 10711 Posted ... Two questions:1) When I start the app to "Generate a static OpenVPN Key" I get the error: Cannot Open Shared Secret File c:\program files\openVPN\ for write. Access Denied. Terminating Program Due To Fatal ErrorHello!It's a permission problem. Anyway, you must not generate a key. Your key is generated by our servers and can be downloaded through the configuration generator (menu "Member Area"->"Access without our client").2) I ran the DNS leak test at DNSleaktest.com, and it states "Hello from Sweden!" but when I click on the "check for DNS leaks icon, the page shows an IP address in Sweden at the top, but then it also shows a 3 Comcast IP addresses, and one is from the city in which I live. Does this mean the VPN is not working correctly?It only means that your system suffers of DNS leaks, please see here to fix:https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=9049&Itemid=142#9051Kind regards Quote Share this post Link to post
