MFransson
Problem connecting
I am getting this text after trying connecting to server (tried 2 different servers).
"An attempt was made to access a socket in a way forbidden by its access permissions 127.0.0.1:3100"
When I press OK, it stays "Checking..." and nothing happens. Only way to close it, is from task manager.
Now when trying again, I always get the "Already connected" message. I have had the "Already connected" message few times before, but this time it just stays like that, no matter if I exit the program, wait few minutes etc.
Only way I am able to connect, is when I restart the computer and disable Comodo firewall for few moments just before connecting.
I am not very experienced user, but I believe I managed to setup the firewall correctly, as I have been using AirVpn about a month and haven't got problems like this before.
1.04.2013 - 22:33 AirVPN client version: 1,8
1.04.2013 - 22:33 Reading options from C:\Users\(o_o)\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
1.04.2013 - 22:33 OpenVPN bundle version: OpenVPN 2.3.0
1.04.2013 - 22:33 OpenVPN current version: OpenVPN 2.3.0
1.04.2013 - 22:33 Ready.
1.04.2013 - 22:33 Login...
1.04.2013 - 22:33 Login success.
1.04.2013 - 22:33 Contacting service...
1.04.2013 - 22:33 Connecting...
1.04.2013 - 22:33 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
1.04.2013 - 22:33 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
1.04.2013 - 22:33 Socket Buffers: R=[8192->8192] S=[8192->8192]
1.04.2013 - 22:33 UDPv4 link local: [undef]
1.04.2013 - 22:33 UDPv4 link remote: [AF_INET]95.211.191.33:443
1.04.2013 - 22:33 TLS: Initial packet from [AF_INET]95.211.191.33:443, sid=ff0757e2 24d1ac14
1.04.2013 - 22:33 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
1.04.2013 - 22:33 VERIFY OK: nsCertType=SERVER
1.04.2013 - 22:33 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
1.04.2013 - 22:33 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
1.04.2013 - 22:33 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
1.04.2013 - 22:33 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
1.04.2013 - 22:33 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
1.04.2013 - 22:33 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
1.04.2013 - 22:33 [server] Peer Connection Initiated with [AF_INET]95.211.191.33:443
1.04.2013 - 22:33 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
1.04.2013 - 22:33 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.0.198 10.4.0.197'
1.04.2013 - 22:33 OPTIONS IMPORT: timers and/or timeouts modified
1.04.2013 - 22:33 OPTIONS IMPORT: LZO parms modified
1.04.2013 - 22:33 OPTIONS IMPORT: --ifconfig/up options modified
1.04.2013 - 22:33 OPTIONS IMPORT: route options modified
1.04.2013 - 22:33 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
1.04.2013 - 22:33 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
1.04.2013 - 22:33 open_tun, tt->ipv6=0
1.04.2013 - 22:33 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{A0690B2D-192D-45B8-A208-7ACF861F2300}.tap
1.04.2013 - 22:33 TAP-Windows Driver Version 9.9
1.04.2013 - 22:33 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.198/255.255.255.252 on interface {A0690B2D-192D-45B8-A208-7ACF861F2300} [DHCP-serv: 10.4.0.197, lease-time: 31536000]
1.04.2013 - 22:33 Successful ARP Flush on interface [18] {A0690B2D-192D-45B8-A208-7ACF861F2300}
1.04.2013 - 22:33 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
1.04.2013 - 22:33 C:\Windows\system32\route.exe ADD 95.211.191.33 MASK 255.255.255.255 192.168.0.1
1.04.2013 - 22:33 ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=12]
1.04.2013 - 22:33 Route addition via IPAPI failed [adaptive]
1.04.2013 - 22:33 Route addition fallback to route.exe
1.04.2013 - 22:33 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
1.04.2013 - 22:33 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.197
1.04.2013 - 22:33 ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=18]
1.04.2013 - 22:33 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.197
1.04.2013 - 22:33 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.0.197
1.04.2013 - 22:33 Initialization Sequence Completed
1.04.2013 - 22:33 Starting Management Interface...
1.04.2013 - 22:33 An attempt was made to access a socket in a way forbidden by its access permissions 127.0.0.1:3100
1.04.2013 - 22:34 Checking...
1.04.2013 - 22:34 Retrieve statistics...
Probably Comodo Firewall and/or Defense+ (HIPS) and/or Sandbox modules are preventing airvpn.exe and/or openvpn.exe to run with full administrator privileges. Please make sure that both programs are "Trusted Applications" and that they are not forced to run in a sandbox (a very useful feature of Comodo, but in this case both programs needs administrator privileges to run properly, they can't run in a sandbox).
If the problem persists although both executables are trusted and not sandboxed, please send us a screenshot of your Global Rules and a screenshot of your Network Zones.
[EDIT] Maybe you have already solved the problem? At the moment of this writing, your account is successfully connected to some Air server and is successfully exchanging data in/out.
When I restart the computer and disable the Comodo Firewall before starting the airvpn, then I am able to connect and can turn on the Firewall right after that. But now I also got disconnected an hour later.
Both airvpn.exe and openvpn.exe are marked as "Trusted Applications".
Uploaded screenshots here:
http://s7.postimg.org/c5gba49a3/Global_Rules.jpg
http://s9.postimg.org/ya8lypq5r/Network_Zones.jpg
This started today and I have not made any changes in meanwhile.
PS! Perhaps this also helps. At the moment I tried tor browser, and it also does not connect.
The log files shows "Warning from libevent: evsig_init: socketpair: Permission denied [WSAEACCESS]"
The Global Rules and Network Zones look just fine.
As a side note, you might like to add to your [airvpn.org] Network Zone the IP 212.117.180.25 (another frontend), so that if the NL frontend fails, your system will be able to use the other one. Remember to add the appropriate lines in your hosts file as well:
85.17.207.151 airvpn.org
212.117.180.25 airvpn.org
The problem should be somewhere else in Comodo (maybe in the Application Rules, maybe in the Defense+ authorizations). Please re-check your Application Rules to see whether some system application has been blocked. Also, try to see Comodo event logs when you try a VPN connection (feel free to send them to us as well) to check whether Comodo firewall is blocking something it should not.
the above quoted line makes me suspect that it might be a problem related to the Windows DHCP client service and/or to the driver handling TAP-Win32 virtual interface. Can you please check that the DHCP client (not server) service is active and running, and that Comodo is not blocking any Windows system application? Probably I'm wrong but it's worth a check.
pj
