qoeisvpkby
Tunnelblick Connection to AirVPN Servers with Tor Fails
Problem:
Tunnelblick can not establish a connection to AirVPN servers or the connection can be established but disconnects immediately when the Tor Browser Bundle is active.
As the following forum posts have already stated, your instructions on connecting to AirVPN servers with Tor does not work anymore with Tunnelblick.
Each of these posts belongs to different forum topics and none of them offers a complete solution.
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=54&limit=6&limitstart=24&Itemid=142#8279
https://airvpn.org/index.php?option=com_kunena&func=view&catid=2&id=4704&Itemid=142#5192
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=4394&Itemid=142#4394
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=2912&Itemid=142#2912
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=2052&Itemid=142#2052
Here are the steps that I followed:
Clean installed Mac OS X 10.8.3
Installed and launched Tor Browser Bundle 2.3.25-5 64-Bit
Logged in to AirVPN website and created the OpenVPN configuration files with the settings Connection Mode: Direct, protocol TCP, port 443 and Proxy: SOCKS, 127.0.0.1, 9150 (Since the version 2.3.25-4, Tor Browser Bundle has set the SOCKS port to 9150 on all platforms.)
Installed Tunnelblick 3.3beta36 with the provided configuration files
I have tried connecting to different AirVPN servers but that does not work. Also I disabled the Monitor network settings option in Tunnelblick VPN Details window but that does not help either.
Here is the Tunnelblick log (I tried to attach it as a .txt but that function did not work on Chrome.):
2013-03-30 08:51:26 *Tunnelblick: OS X 10.8.3; Tunnelblick 3.3beta36 (build 3228)
2013-03-30 08:51:26 *Tunnelblick: Attempting connection with AirVPN_GB-Bootis_TCP-443 using shadow copy; Set nameserver = 1; monitoring connection
2013-03-30 08:51:26 *Tunnelblick: openvpnstart start AirVPN_GB-Bootis_TCP-443.tblk 1337 1 0 1 0 305 -atADGNWradsgnw
2013-03-30 08:51:26 *Tunnelblick: openvpnstart log:
Loading tun.kext
OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
/Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn
--cd
/Library/Application Support/Tunnelblick/Users/User/AirVPN_GB-Bootis_TCP-443.tblk/Contents/Resources
--daemon
--management
127.0.0.1
1337
--config
/Library/Application Support/Tunnelblick/Users/User/AirVPN_GB-Bootis_TCP-443.tblk/Contents/Resources/config.ovpn
--log
/Library/Application Support/Tunnelblick/Logs/-SUsers-SUser-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN_GB--Bootis_TCP--443.tblk-SContents-SResources-Sconfig.ovpn.1_0_1_0_305.1337.openvpn.log
--management-query-passwords
--management-hold
--script-security
2
--up
/Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw
--down
/Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw
--up-restart
2013-03-30 08:51:26 *Tunnelblick: Established communication with OpenVPN
2013-03-30 08:51:26 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Feb 14 2013
2013-03-30 08:51:26 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2013-03-30 08:51:26 Need hold release from management interface, waiting...
2013-03-30 08:51:26 MANAGEMENT: Client connected from 127.0.0.1:1337
2013-03-30 08:51:26 MANAGEMENT: CMD 'pid'
2013-03-30 08:51:26 MANAGEMENT: CMD 'state on'
2013-03-30 08:51:26 MANAGEMENT: CMD 'state'
2013-03-30 08:51:26 MANAGEMENT: CMD 'bytecount 1'
2013-03-30 08:51:26 MANAGEMENT: CMD 'hold release'
2013-03-30 08:51:26 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-03-30 08:51:26 LZO compression initialized
2013-03-30 08:51:26 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-03-30 08:51:26 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-03-30 08:51:26 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-03-30 08:51:26 Local Options hash (VER=V4): '958c5492'
2013-03-30 08:51:26 Expected Remote Options hash (VER=V4): '79ef4284'
2013-03-30 08:51:26 Attempting to establish TCP connection with 127.0.0.1:9150 [nonblock]
2013-03-30 08:51:26 MANAGEMENT: >STATE:1364633486,TCP_CONNECT,,,
2013-03-30 08:51:26 *Tunnelblick: openvpnstart starting OpenVPN:
* /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Library/Application Support/Tunnelblick/Users/User/AirVPN_GB-Bootis_TCP-443.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Users/User/AirVPN_GB-Bootis_TCP-443.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-SUser-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN_GB--Bootis_TCP--443.tblk-SContents-SResources-Sconfig.ovpn.1_0_1_0_305.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --up-restart
2013-03-30 08:51:27 TCP connection established with 127.0.0.1:9150
2013-03-30 08:51:28 TCPv4_CLIENT link local: [undef]
2013-03-30 08:51:28 TCPv4_CLIENT link remote: 127.0.0.1:9150
2013-03-30 08:51:28 MANAGEMENT: >STATE:1364633488,WAIT,,,
2013-03-30 08:51:28 MANAGEMENT: >STATE:1364633488,AUTH,,,
2013-03-30 08:51:28 TLS: Initial packet from 127.0.0.1:9150, sid=2648e68e e16801ed
2013-03-30 08:51:32 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-03-30 08:51:32 VERIFY OK: nsCertType=SERVER
2013-03-30 08:51:32 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-03-30 08:51:42 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-03-30 08:51:42 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-03-30 08:51:42 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-03-30 08:51:42 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-03-30 08:51:42 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-03-30 08:51:42 [server] Peer Connection Initiated with 127.0.0.1:9150
2013-03-30 08:51:44 MANAGEMENT: >STATE:1364633504,GET_CONFIG,,,
2013-03-30 08:51:45 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-03-30 08:51:45 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.5.74 10.5.5.73'
2013-03-30 08:51:45 OPTIONS IMPORT: timers and/or timeouts modified
2013-03-30 08:51:45 OPTIONS IMPORT: LZO parms modified
2013-03-30 08:51:45 OPTIONS IMPORT: --ifconfig/up options modified
2013-03-30 08:51:45 OPTIONS IMPORT: route options modified
2013-03-30 08:51:45 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-03-30 08:51:45 ROUTE default_gateway=192.168.1.254
2013-03-30 08:51:45 TUN/TAP device /dev/tun0 opened
2013-03-30 08:51:45 MANAGEMENT: >STATE:1364633505,ASSIGN_IP,,10.5.5.74,
2013-03-30 08:51:45 /sbin/ifconfig tun0 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2013-03-30 08:51:45 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-03-30 08:51:45 /sbin/ifconfig tun0 10.5.5.74 10.5.5.73 mtu 1500 netmask 255.255.255.255 up
2013-03-30 08:51:45 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw tun0 1500 1560 10.5.5.74 10.5.5.73 init
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: Retrieved from OpenVPN: name server(s) [ 10.5.0.1 ], search domain(s) [ ] and SMB server(s) [ ] and using default domain name [ openvpn ]
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG:
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_CONFIG = No such key
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_CONFIG = No such key
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 192.168.1.254 192.168.1.254 } }
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_CONFIG = No such key
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_DNS_DN = openvpn; DYN_DNS_SA = 10.5.0.1; DYN_DNS_SD =
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_SMB_NN = ; DYN_SMB_WG = ; DYN_SMB_WA =
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_DN = ; MAN_DNS_SA = ; MAN_DNS_SD =
2013-03-30 08:51:47 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_NN = ; MAN_SMB_WG = ; MAN_SMB_WA =
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG:
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_DN = ; CUR_DNS_SA = 192.168.1.254 192.168.1.254; CUR_DNS_SD =
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_NN = ; CUR_SMB_WG = ; CUR_SMB_WA =
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: ServerAddresses were not aggregated because running on OS X 10.6 or higher
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually and 'Prepend domain name to search domains' was not selected
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_DNS_DN = openvpn; FIN_DNS_SA = 10.5.0.1; FIN_DNS_SD = openvpn
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_SMB_NN = ; FIN_SMB_WG = ; FIN_SMB_WA =
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: OS X 10.8 or higher, so will modify DNS settings using Setup: in addition to State:
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_DNS = ; SKP_DNS_SA = ; SKP_DNS_SD = ; SKP_DNS_DN =
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SETUP_DNS =
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SMB = #; SKP_SMB_NN = #; SKP_SMB_WG = #; SKP_SMB_WA = #
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: /etc/resolve = nameserver 192.168.1.254 nameserver 192.168.1.254
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configuration changes:
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: ServerAddresses 10.5.0.1
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: SearchDomains openvpn
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: DomainName openvpn
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: ServerAddresses 10.5.0.1
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: SearchDomains openvpn
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: DomainName openvpn
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: NetBIOSName
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: Workgroup
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: WINSAddresses
2013-03-30 08:51:48 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Pause for configuration changes to be propagated to State:/Network/Global/DNS and .../SMB
2013-03-30 08:51:49 /sbin/route add -net 127.0.0.1 192.168.1.254 255.255.255.255
add net 127.0.0.1: gateway 192.168.1.254
2013-03-30 08:51:49 /sbin/route add -net 0.0.0.0 10.5.5.73 128.0.0.0
add net 0.0.0.0: gateway 10.5.5.73
2013-03-30 08:51:49 /sbin/route add -net 128.0.0.0 10.5.5.73 128.0.0.0
add net 128.0.0.0: gateway 10.5.5.73
2013-03-30 08:51:49 MANAGEMENT: >STATE:1364633509,ADD_ROUTES,,,
2013-03-30 08:51:49 /sbin/route add -net 10.5.0.1 10.5.5.73 255.255.255.255
add net 10.5.0.1: gateway 10.5.5.73
2013-03-30 08:51:49 Initialization Sequence Completed
2013-03-30 08:51:49 MANAGEMENT: >STATE:1364633509,CONNECTED,SUCCESS,10.5.5.74,127.0.0.1
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG:
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configurations as read back after changes:
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.5.0.1 } }
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../SMB = No such key
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.5.0.1 } }
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../SMB = No such key
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.5.0.1 } }
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/SMB = No such key
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Expected by process-network-changes:
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.5.0.1 } }
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/SMB = <dictionary> { TunnelblickNoSuchKey : true }
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: DEBUG: /etc/resolve = search openvpn nameserver 10.5.0.1
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and SMB configurations for later use
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with leasewatch
2013-03-30 08:51:49 *Tunnelblick client.up.tunnelblick.sh: Flushed the DNS Cache
2013-03-30 08:52:24 *Tunnelblick: After 30.0 seconds, gave up trying to fetch IP address information using the ipInfo host's name after connecting.
2013-03-30 08:52:24 *Tunnelblick leasewatch: A system configuration change was ignored because it was not relevant
2013-03-30 08:52:50 [server] Inactivity timeout (--ping-restart), restarting
2013-03-30 08:52:50 TCP/UDP: Closing socket
2013-03-30 08:52:50 /sbin/route delete -net 10.5.0.1 10.5.5.73 255.255.255.255
delete net 10.5.0.1: gateway 10.5.5.73
2013-03-30 08:52:50 /sbin/route delete -net 127.0.0.1 192.168.1.254 255.255.255.255
delete net 127.0.0.1: gateway 192.168.1.254
2013-03-30 08:52:50 /sbin/route delete -net 0.0.0.0 10.5.5.73 128.0.0.0
delete net 0.0.0.0: gateway 10.5.5.73
2013-03-30 08:52:50 /sbin/route delete -net 128.0.0.0 10.5.5.73 128.0.0.0
delete net 128.0.0.0: gateway 10.5.5.73
2013-03-30 08:52:50 Closing TUN/TAP interface
2013-03-30 08:52:50 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw tun0 1500 1560 10.5.5.74 10.5.5.73 init
No such key
2013-03-30 08:52:50 SIGUSR1[soft,ping-restart] received, process restarting
2013-03-30 08:52:50 MANAGEMENT: >STATE:1364633570,RECONNECTING,ping-restart,,
2013-03-30 08:52:50 MANAGEMENT: CMD 'hold release'
2013-03-30 08:52:50 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-03-30 08:52:50 LZO compression initialized
2013-03-30 08:52:50 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-03-30 08:52:50 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-03-30 08:52:50 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-03-30 08:52:50 Local Options hash (VER=V4): '958c5492'
2013-03-30 08:52:50 Expected Remote Options hash (VER=V4): '79ef4284'
2013-03-30 08:52:50 Attempting to establish TCP connection with 127.0.0.1:9150 [nonblock]
2013-03-30 08:52:50 MANAGEMENT: >STATE:1364633570,TCP_CONNECT,,,
2013-03-30 08:52:50 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-03-30 08:52:50 *Tunnelblick client.down.tunnelblick.sh: DEBUG: Removing 'Setup:' DNS key
2013-03-30 08:52:50 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and SMB configurations
2013-03-30 08:52:50 *Tunnelblick client.down.tunnelblick.sh: DEBUG: /etc/resolve = nameserver 192.168.1.254 nameserver 192.168.1.254
2013-03-30 08:52:50 *Tunnelblick client.down.tunnelblick.sh: Flushed the DNS Cache
2013-03-30 08:52:51 TCP connection established with 127.0.0.1:9150
2013-03-30 08:52:56 recv_socks_reply: TCP port read timeout expired: Operation now in progress (errno=36)
2013-03-30 08:52:56 TCP/UDP: Closing socket
2013-03-30 08:52:56 SIGTERM[soft,init_instance] received, process exiting
2013-03-30 08:52:56 MANAGEMENT: >STATE:1364633576,EXITING,init_instance,,
Problem:
That's correct, Tunnelblick does not seem to support properly OpenVPN connections over a socks proxy. Unfortunately we are currently not aware of any solution to this problem, it does not depend on us in any way.
Thank you for your response.
I would be happy if you could answer the questions below if you have any related information.
Does any previous version of Tunnelblick support OpenVPN connections over a SOCKS proxy?
Does Viscosity support OpenVPN connections over a SOCKS proxy?
Do you know any Mac VPN client which supports OpenVPN connections over a SOCKS proxy?
P.S.
The image file which is attached to my previous post has nothing to do with the post. I was just testing with a different file format after many unsuccessful .txt attachment attempts. When I saw the published post, I have realized that the files were attached but not displayed by the browser properly. Admin is free to delete the attachment.
Here are the answers to my own questions which were asked in the previous post.
No, no previous version of Tunnelblick does support OpenVPN connections over a SOCKS proxy. Also Tunnelblick will not provide this function in the the near future. Here is the developer's response:
Unless someone submits code to do this and it can be tested thoroughly it won't be added any time in the foreseeable future as I don't have the expertise to do it.
https://groups.google.com/forum/?fromgroups=#!topic/tunnelblick-discuss/_1Q1a2qZ9d4
No, Viscosity does not support OpenVPN connections over a SOCKS proxy. No future plans either. Developer's response:
I'm afraid this is probably something you're better off directing to the Tor community, as we don't have much experience with Tor.
http://www.sparklabs.com/forum/viewtopic.php?f=3&t=1133
No, there is no other OpenVPN client that works on Mac platform.
