HorseClaws
sorry, an error occured - options reverted to default
Posted Image
it may seem the obvious answer but can i fix this with a (clean) install?
at the moment AVPN behaves as if it were a portable program and shows this error every time i start it up.
b.t.w. it still will not keep it's settings and will not start with windblows 7 automatically.
now i was testing Norton 360 a while (not using it anymore) and i read that it may have caused problems.
Actually, the Air client is portable.
It's not possible to make the Air client connect automatically at Windows 7 startup. You need to use OpenVPN directly to do that.
then the error was within openVPN - i uninstalled it - downloaded a fresh version from you (including a fresh AirVPN.exe) and the problem is now solved with the new installation.
thanks for your attention and reply.
