Not connected, Your IP: 216.73.216.124
asere27
i can't to connecting
hola
i'am new in this forums my english isn't good,
so i can't connecting whith airvpn..somebody can tellme porque
hola
Your account is authorized to access all the VPN servers. Can you please tell us your OS and which client you run to connect to a server?
yes my account is ok..yesterday ok,today not, i don't now why,,mi os is w 7..
note: i pay today for 3 mouths
mi os is w7 and used firefox..yesterday are everithing ok..but today no,,i pay today 3 mouths,mi account is ok
We confirm you that your account is just fine, it is on Premium status and authorized to access all the VPN servers.
Can you please send us your Air client connection logs? After you have tried a connection to any VPN server with the Air client, right-click on the Air dock icon (a white cloud on a blue sky if connected, on a gray sky if disconnected) and select "Logs". A window will pop up. Click on "Copy to clipboard", finally paste here. Logs are very important for troubleshooting.
hola:
29/03/2013 - 8.00 AirVPN client version: 1,8
29/03/2013 - 8.00 Reading options from C:\Users\ruiz\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
29/03/2013 - 8.00 OpenVPN bundle version: OpenVPN 2.3.0
29/03/2013 - 8.00 OpenVPN current version: OpenVPN 2.3.0
29/03/2013 - 8.00 Ready.
29/03/2013 - 8.01 Login...
29/03/2013 - 8.01 Login success.
29/03/2013 - 8.01 Contacting service...
29/03/2013 - 8.01 Connecting...
29/03/2013 - 8.01 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
29/03/2013 - 8.01 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
29/03/2013 - 8.01 Socket Buffers: R=[8192->8192] S=[8192->8192]
29/03/2013 - 8.01 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050
29/03/2013 - 8.01 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.02 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.03 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.04 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.05 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.06 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.07 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.08 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.09 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.10 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.11 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.12 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.13 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.14 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.15 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.16 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.17 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
29/03/2013 - 8.17 Disconnecting...
29/03/2013 - 8.17 Disconnected.
It seems that your local proxy is not running, or maybe it's not listening to port 9050. What proxy are you running? Is it a TOR proxy?
yes ,how can i do,to resolved this problem
Please make sure that:
- the TOR proxy is running before you launch OpenVPN
- the TOR proxy is listening to port 9050 (check the SocksPort, not the ControlPort)
- you pick a TCP port for OpenVPN connection (TOR proxy does not support UDP)
