f.o.h.h
socks proxy connection problems
Good morning, I am having a problem with the SOCKS proxy connection.
AirVPN client works fine (TCP and UDP) and I can connect using OpenVPN GUI to air, no problem.
However, when I try to connect using the SOCKS Proxy option it is always refused.
I tried to uninstall/reinstall the OpenVPN client; I tried to generate a key from the web site here with the correct settings; I installed it into the OpenVPN config directory; I tried to open OpenVPN using 'run as Admin'; I tried to use the AirVPN client and change the 'mode' to TCP/443 with SOCKS Proxy option; I tried using the older AirVPN client 1.7.....but nothing seems to work for my SOCKS Proxy option. I even quit my firewall (Comodo) before doing all of this in case there was something in there that was blocking it but still nothing.
Like I said, everything else works fine except the SOCKS Proxy option for me.
(I am trying to open TOR Browser Bundle then use AirVPN with SOCKS Proxy).
Everything else is working.
I'm using Windows 7.
I don't know what else to do. I imagine I am missing one small thing but I can't find it! It's very frustrating.
Maybe someone can help me?
I can show you both my logs: Below is the successful connection log using OpenVPN GUI to connect to 'air' and at the bottom is my latest connection log failure:
Mon Mar 18 05:58:20 2013 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
Enter Management Password:
Mon Mar 18 05:58:20 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Mon Mar 18 05:58:20 2013 Need hold release from management interface, waiting...
Mon Mar 18 05:58:21 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Mon Mar 18 05:58:21 2013 MANAGEMENT: CMD 'state on'
Mon Mar 18 05:58:21 2013 MANAGEMENT: CMD 'log all on'
Mon Mar 18 05:58:21 2013 MANAGEMENT: CMD 'hold off'
Mon Mar 18 05:58:21 2013 MANAGEMENT: CMD 'hold release'
Mon Mar 18 05:58:21 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 05:58:21 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 05:58:21 2013 UDPv4 link local: [undef]
Mon Mar 18 05:58:21 2013 UDPv4 link remote: [AF_INET]46.165.208.65:443
Mon Mar 18 05:58:21 2013 MANAGEMENT: >STATE:1363564701,WAIT,,,
Mon Mar 18 05:58:23 2013 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Mon Mar 18 05:58:24 2013 MANAGEMENT: >STATE:1363564704,AUTH,,,
Mon Mar 18 05:58:24 2013 TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=8a1cf0d5 8c34794b
Mon Mar 18 05:58:26 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Mon Mar 18 05:58:26 2013 VERIFY OK: nsCertType=SERVER
Mon Mar 18 05:58:26 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Mon Mar 18 05:58:32 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Mar 18 05:58:32 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Mar 18 05:58:32 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Mar 18 05:58:32 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Mar 18 05:58:32 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Mon Mar 18 05:58:32 2013 [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443
Mon Mar 18 05:58:33 2013 MANAGEMENT: >STATE:1363564713,GET_CONFIG,,,
Mon Mar 18 05:58:34 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Mon Mar 18 05:58:34 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.15.174 10.4.15.173'
Mon Mar 18 05:58:34 2013 OPTIONS IMPORT: timers and/or timeouts modified
Mon Mar 18 05:58:34 2013 OPTIONS IMPORT: LZO parms modified
Mon Mar 18 05:58:34 2013 OPTIONS IMPORT: --ifconfig/up options modified
Mon Mar 18 05:58:34 2013 OPTIONS IMPORT: route options modified
Mon Mar 18 05:58:34 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Mar 18 05:58:34 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Mar 18 05:58:34 2013 MANAGEMENT: >STATE:1363564714,ASSIGN_IP,,10.4.15.174,
Mon Mar 18 05:58:34 2013 open_tun, tt->ipv6=0
Mon Mar 18 05:58:34 2013 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{5BDE9099-B8EA-4A43-8686-625DFA5ED3FD}.tap
Mon Mar 18 05:58:34 2013 TAP-Windows Driver Version 9.9
Mon Mar 18 05:58:34 2013 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.15.174/255.255.255.252 on interface {5BDE9099-B8EA-4A43-8686-625DFA5ED3FD} [DHCP-serv: 10.4.15.173, lease-time: 31536000]
Mon Mar 18 05:58:34 2013 Successful ARP Flush on interface [18] {5BDE9099-B8EA-4A43-8686-625DFA5ED3FD}
Mon Mar 18 05:58:39 2013 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Mon Mar 18 05:58:39 2013 C:\windows\system32\route.exe ADD 46.165.208.65 MASK 255.255.255.255 192.168.1.254
Mon Mar 18 05:58:39 2013 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
Mon Mar 18 05:58:39 2013 Route addition via IPAPI succeeded [adaptive]
Mon Mar 18 05:58:39 2013 C:\windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.15.173
Mon Mar 18 05:58:39 2013 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
Mon Mar 18 05:58:39 2013 C:\windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.15.173
Mon Mar 18 05:58:39 2013 MANAGEMENT: >STATE:1363564719,ADD_ROUTES,,,
Mon Mar 18 05:58:39 2013 C:\windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.15.173
Mon Mar 18 05:58:39 2013 Initialization Sequence Completed
Mon Mar 18 05:58:39 2013 MANAGEMENT: >STATE:1363564719,CONNECTED,SUCCESS,10.4.15.174,46.165.208.65
Failure log:
Mon Mar 18 05:56:11 2013 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
Mon Mar 18 05:56:11 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Mon Mar 18 05:56:11 2013 Need hold release from management interface, waiting...
Mon Mar 18 05:56:12 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Mon Mar 18 05:56:12 2013 MANAGEMENT: CMD 'state on'
Mon Mar 18 05:56:12 2013 MANAGEMENT: CMD 'log all on'
Mon Mar 18 05:56:12 2013 MANAGEMENT: CMD 'hold off'
Mon Mar 18 05:56:12 2013 MANAGEMENT: CMD 'hold release'
Mon Mar 18 05:56:12 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 9050'
Mon Mar 18 05:56:13 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 05:56:13 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 05:56:13 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050
Mon Mar 18 05:56:13 2013 MANAGEMENT: >STATE:1363564573,TCP_CONNECT,,,
Mon Mar 18 05:56:14 2013 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Mar 18 05:56:14 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Mar 18 05:56:14 2013 MANAGEMENT: >STATE:1363564574,RECONNECTING,init_instance,,
Mon Mar 18 05:56:14 2013 Restart pause, 5 second(s)
Mon Mar 18 05:56:19 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 9050'
Mon Mar 18 05:56:20 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 05:56:20 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 05:56:20 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050
Mon Mar 18 05:56:20 2013 MANAGEMENT: >STATE:1363564580,TCP_CONNECT,,,
Mon Mar 18 05:56:21 2013 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Mar 18 05:56:21 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Mar 18 05:56:21 2013 MANAGEMENT: >STATE:1363564581,RECONNECTING,init_instance,,
Mon Mar 18 05:56:21 2013 Restart pause, 5 second(s)
Mon Mar 18 05:56:26 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 9050'
Mon Mar 18 05:56:27 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 05:56:27 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 05:56:27 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050
Mon Mar 18 05:56:27 2013 MANAGEMENT: >STATE:1363564587,TCP_CONNECT,,,
Mon Mar 18 05:56:28 2013 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Mar 18 05:56:28 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Mar 18 05:56:28 2013 MANAGEMENT: >STATE:1363564588,RECONNECTING,init_instance,,
Mon Mar 18 05:56:28 2013 Restart pause, 5 second(s)
Mon Mar 18 05:56:33 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 9050'
Mon Mar 18 05:56:34 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 05:56:34 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 05:56:34 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050
Mon Mar 18 05:56:34 2013 MANAGEMENT: >STATE:1363564594,TCP_CONNECT,,,
Mon Mar 18 05:56:35 2013 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Mar 18 05:56:35 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Mar 18 05:56:35 2013 MANAGEMENT: >STATE:1363564595,RECONNECTING,init_instance,,
Mon Mar 18 05:56:35 2013 Restart pause, 5 second(s)
Mon Mar 18 05:56:40 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 9050'
Mon Mar 18 05:56:41 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 05:56:41 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 05:56:41 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050
Mon Mar 18 05:56:41 2013 MANAGEMENT: >STATE:1363564601,TCP_CONNECT,,,
Mon Mar 18 05:56:42 2013 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Mar 18 05:56:42 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Mar 18 05:56:42 2013 MANAGEMENT: >STATE:1363564602,RECONNECTING,init_instance,,
Mon Mar 18 05:56:42 2013 Restart pause, 5 second(s)
Mon Mar 18 05:56:45 2013 SIGTERM[hard,init_instance] received, process exiting
It appears that the proxy is not listening to port 9050, maybe it is listening to some other port, can you please check?
I just tried to change the port number using: right click with OpenVPN GUI settings: Manual Config, SOCKS Proxy 127.0.0.1 Port 8080 then 1234 but the same is happening.
My Firewall is still off by the way.
Mon Mar 18 07:26:45 2013 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
Mon Mar 18 07:26:45 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Mon Mar 18 07:26:45 2013 Need hold release from management interface, waiting...
Mon Mar 18 07:26:45 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Mon Mar 18 07:26:45 2013 MANAGEMENT: CMD 'state on'
Mon Mar 18 07:26:45 2013 MANAGEMENT: CMD 'log all on'
Mon Mar 18 07:26:45 2013 MANAGEMENT: CMD 'hold off'
Mon Mar 18 07:26:45 2013 MANAGEMENT: CMD 'hold release'
Mon Mar 18 07:26:45 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 1234'
Mon Mar 18 07:26:46 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 07:26:46 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 07:26:46 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:1234
Mon Mar 18 07:26:46 2013 MANAGEMENT: >STATE:1363570006,TCP_CONNECT,,,
Mon Mar 18 07:26:47 2013 TCP: connect to [AF_INET]127.0.0.1:1234 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Mar 18 07:26:47 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Mar 18 07:26:47 2013 MANAGEMENT: >STATE:1363570007,RECONNECTING,init_instance,,
Mon Mar 18 07:26:47 2013 Restart pause, 5 second(s)
Mon Mar 18 07:26:52 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 1234'
Mon Mar 18 07:26:53 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 07:26:53 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 07:26:53 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:1234
Mon Mar 18 07:26:53 2013 MANAGEMENT: >STATE:1363570013,TCP_CONNECT,,,
Mon Mar 18 07:26:54 2013 TCP: connect to [AF_INET]127.0.0.1:1234 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Mar 18 07:26:54 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Mar 18 07:26:54 2013 MANAGEMENT: >STATE:1363570014,RECONNECTING,init_instance,,
Mon Mar 18 07:26:54 2013 Restart pause, 5 second(s)
Please do not proceed randomly, there are almost 65535 ports the proxy can listen to. First, please determine (or configure) the port the proxy listens to. Then modify the OpenVPN configuration accordingly (port numbers must match).
Success! Port 9150 is working. Thanks.
For anyone else reading this with the same problem: I downloaded the SOCKS Proxy OpenVPN configuration files (.ovpn) from the AirVPN site and put it into the OpenVPN config folder on my computer (Programs folder). I changed the Proxy port in the downloaded file to 9150. Then I opened OpenVPN using Admin status, right clicked on the 2 small monitors icon and clicked 'settings', in the port box I also changed it to 9150 (to match the downloaded config file). Because I had already placed the OpenVPN config file into the config folder, I now had an option to connect to it specifically when I right clicked the 2 small monitors. I rolled over it and clicked 'connect' from the new menu. Here is my SUCCESSFUL log to prove it:
Mon Mar 18 08:22:20 2013 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
Mon Mar 18 08:22:20 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341
Mon Mar 18 08:22:20 2013 Need hold release from management interface, waiting...
Mon Mar 18 08:22:21 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341
Mon Mar 18 08:22:21 2013 MANAGEMENT: CMD 'state on'
Mon Mar 18 08:22:21 2013 MANAGEMENT: CMD 'log all on'
Mon Mar 18 08:22:21 2013 MANAGEMENT: CMD 'hold off'
Mon Mar 18 08:22:21 2013 MANAGEMENT: CMD 'hold release'
Mon Mar 18 08:22:21 2013 MANAGEMENT: CMD 'proxy SOCKS 127.0.0.1 9150'
Mon Mar 18 08:22:22 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Mar 18 08:22:22 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Mar 18 08:22:22 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150
Mon Mar 18 08:22:22 2013 MANAGEMENT: >STATE:1363573342,TCP_CONNECT,,,
Mon Mar 18 08:22:22 2013 TCP connection established with [AF_INET]127.0.0.1:9150
Mon Mar 18 08:22:23 2013 TCPv4_CLIENT link local: [undef]
Mon Mar 18 08:22:23 2013 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9150
Mon Mar 18 08:22:23 2013 MANAGEMENT: >STATE:1363573343,WAIT,,,
Mon Mar 18 08:22:24 2013 MANAGEMENT: >STATE:1363573344,AUTH,,,
Mon Mar 18 08:22:24 2013 TLS: Initial packet from [AF_INET]127.0.0.1:9150, sid=28a49c60 b5459d75
Mon Mar 18 08:22:32 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Mon Mar 18 08:22:32 2013 VERIFY OK: nsCertType=SERVER
Mon Mar 18 08:22:32 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Mon Mar 18 08:22:54 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Mar 18 08:22:54 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Mar 18 08:22:54 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Mar 18 08:22:54 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Mar 18 08:22:54 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Mon Mar 18 08:22:54 2013 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9150
Mon Mar 18 08:22:55 2013 MANAGEMENT: >STATE:1363573375,GET_CONFIG,,,
Mon Mar 18 08:22:57 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Mon Mar 18 08:22:58 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.1.86 10.5.1.85'
Mon Mar 18 08:22:58 2013 OPTIONS IMPORT: timers and/or timeouts modified
Mon Mar 18 08:22:58 2013 OPTIONS IMPORT: LZO parms modified
Mon Mar 18 08:22:58 2013 OPTIONS IMPORT: --ifconfig/up options modified
Mon Mar 18 08:22:58 2013 OPTIONS IMPORT: route options modified
Mon Mar 18 08:22:58 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Mar 18 08:22:58 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Mar 18 08:22:58 2013 MANAGEMENT: >STATE:1363573378,ASSIGN_IP,,10.5.1.86,
Mon Mar 18 08:22:58 2013 open_tun, tt->ipv6=0
Mon Mar 18 08:22:58 2013 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{5BDE9099-B8EA-4A43-8686-625DFA5ED3FD}.tap
Mon Mar 18 08:22:58 2013 TAP-Windows Driver Version 9.9
Mon Mar 18 08:22:58 2013 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.1.86/255.255.255.252 on interface {5BDE9099-B8EA-4A43-8686-625DFA5ED3FD} [DHCP-serv: 10.5.1.85, lease-time: 31536000]
Mon Mar 18 08:22:58 2013 Successful ARP Flush on interface [18] {5BDE9099-B8EA-4A43-8686-625DFA5ED3FD}
Mon Mar 18 08:23:03 2013 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Mon Mar 18 08:23:03 2013 C:\windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
Mon Mar 18 08:23:03 2013 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
Mon Mar 18 08:23:03 2013 Route addition via IPAPI succeeded [adaptive]
Mon Mar 18 08:23:03 2013 C:\windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.1.85
Mon Mar 18 08:23:03 2013 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
Mon Mar 18 08:23:03 2013 C:\windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.1.85
Mon Mar 18 08:23:03 2013 MANAGEMENT: >STATE:1363573383,ADD_ROUTES,,,
Mon Mar 18 08:23:03 2013 C:\windows\system32\route.exe ADD 10.5.0.1 MASK 255.255.255.255 10.5.1.85
Mon Mar 18 08:23:03 2013 Initialization Sequence Completed
Mon Mar 18 08:23:03 2013 MANAGEMENT: >STATE:1363573383,CONNECTED,SUCCESS,10.5.1.86,127.0.0.1
SOLVED! for some reason tor wasn't working right. i uninstalled and re installed tor and it works perfect now
hi. i followed f.o.h.h exactly like he did but i still can't connect? in openvpn where you enter the port number, what did you enter in the address box?
here's the log file:
Mon Jul 01 19:59:31 2013 OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jun  3 2013
Mon Jul 01 19:59:31 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Mon Jul 01 19:59:31 2013 Need hold release from management interface, waiting...
Mon Jul 01 19:59:31 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Mon Jul 01 19:59:32 2013 MANAGEMENT: CMD 'state on'
Mon Jul 01 19:59:32 2013 MANAGEMENT: CMD 'log all on'
Mon Jul 01 19:59:32 2013 MANAGEMENT: CMD 'hold off'
Mon Jul 01 19:59:32 2013 MANAGEMENT: CMD 'hold release'
Mon Jul 01 19:59:32 2013 MANAGEMENT: CMD 'proxy NONE  '
Mon Jul 01 19:59:33 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Jul 01 19:59:33 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150
Mon Jul 01 19:59:33 2013 MANAGEMENT: >STATE:1372733973,TCP_CONNECT,,,
Mon Jul 01 19:59:34 2013 TCP: connect to [AF_INET]127.0.0.1:9150 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Jul 01 19:59:34 2013 SIGUSR1[soft,init_instance] received, process restarting
Mon Jul 01 19:59:34 2013 MANAGEMENT: >STATE:1372733974,RECONNECTING,init_instance,,
Mon Jul 01 19:59:34 2013 Restart pause, 5 second(s)
Mon Jul 01 19:59:39 2013 MANAGEMENT: CMD 'proxy NONE  '
Mon Jul 01 19:59:40 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Jul 01 19:59:40 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150
please help. i've been stuck on this for awhile.
