fafhouse
How to Verify RPM package with GPG key?
Apologies if this is obvious or has been answered before, but I was unable to find what I was looking for online or in the forums. I can verify the SHA and MD5 sums for the RPM package just fine, but how can I verify via the supplied key? Even after importing the key trying to verify the signature of the RPM package fails. I'm not the best with RPM so I'm likely missing something obvious, but any help would be greatly appreciated. Thanks!
~ $ sudo rpm --import https://eddie.website/repository/keys/eddie_maintainer_gpg.key -vvv
D: loading keyring from rpmdb
D: opening  db index       /usr/lib/sysimage/rpm/Packages.db mode=0x0
D: opening  db index       /usr/lib/sysimage/rpm/Index.db mode=0x0
D: opening  db index       Name tag=1000
D: opening  db index       Basenames tag=1117
D: opening  db index       Group tag=1016
D: opening  db index       Requirename tag=1049
D: opening  db index       Providename tag=1047
D: opening  db index       Conflictname tag=1054
D: opening  db index       Obsoletename tag=1090
D: opening  db index       Triggername tag=1066
D: opening  db index       Dirnames tag=1118
D: opening  db index       Installtid tag=1128
D: opening  db index       Sigmd5 tag=261
D: opening  db index       Sha1header tag=269
D: opening  db index       Filetriggername tag=5069
D: opening  db index       Transfiletriggername tag=5079
D: opening  db index       Recommendname tag=5046
D: opening  db index       Suggestname tag=5049
D: opening  db index       Supplementname tag=5052
D: opening  db index       Enhancename tag=5055
D:  read h#    1179
Header SHA256 digest: OK
Header SHA1 digest: OK
D: added key gpg-pubkey-f3f033b1-5d5e777a to keyring
D:  read h#    8133
D: added key gpg-pubkey-1abd1afb-450ef738 to keyring
D:  read h#   40293
D: added key gpg-pubkey-66de8ddf-5811982a to keyring
D: added subkey 0 of main key gpg-pubkey-66de8ddf-5811982a to keyring
D: added subkey 1 of main key gpg-pubkey-66de8ddf-5811982a to keyring
D:  read h#   74820
D: added key gpg-pubkey-287a0027-682477e3 to keyring
D:  read h#   97570
D: added key gpg-pubkey-3fa1d6ce-67c856ee to keyring
D:  read h#   97571
D: added key gpg-pubkey-39db7c82-66c5d91a to keyring
D:  read h#   97572
D: added key gpg-pubkey-09d9ea69-68595a8c to keyring
D:  read h#   97680
D: added key gpg-pubkey-29b700a4-6a17fa38 to keyring
D:  read h#  101022
D: added key gpg-pubkey-8a239aec-69833e8e to keyring
D: added subkey 0 of main key gpg-pubkey-8a239aec-69833e8e to keyring
D: closed   db index       Enhancename
D: closed   db index       Supplementname
D: closed   db index       Suggestname
D: closed   db index       Recommendname
D: closed   db index       Transfiletriggername
D: closed   db index       Filetriggername
D: closed   db index       Sha1header
D: closed   db index       Sigmd5
D: closed   db index       Installtid
D: closed   db index       Dirnames
D: closed   db index       Triggername
D: closed   db index       Obsoletename
D: closed   db index       Conflictname
D: closed   db index       Providename
D: closed   db index       Requirename
D: closed   db index       Group
D: closed   db index       Basenames
D: closed   db index       Name
D: closed   db index       /usr/lib/sysimage/rpm/Index.db
D: closed   db index       /usr/lib/sysimage/rpm/Packages.db
~ $ sudo rpm -Kvv eddie-ui_2.24.6_linux_x64_opensuse.rpm
D:  read h#    1179
D:  read h#    8133
D:  read h#   40293
D:  read h#   74820
D:  read h#   97570
D:  read h#   97571
D:  read h#   97572
D:  read h#   97680
D:  read h#  101022
eddie-ui_2.24.6_linux_x64_opensuse.rpm:
    Header V4 RSA/SHA512 Signature, key ID 400d7698: NOKEY
    Payload SHA256 digest: OK
    MD5 digest: OK
I see the same thing as well on Fedora (and yes I did import the key):
eddie-ui_2.24.6_linux_x64_fedora.rpm:
   Header OpenPGP V4 RSA/SHA512 signature, key ID 513efc94400d7698: NOKEY
   Legacy OpenPGP V4 RSA/SHA512 signature, key ID 513efc94400d7698: NOKEY
