Not connected, Your IP: 216.73.216.177
mordants
[SOLVED] Upgrade from AirVPN 1.7 to AirVPN 1.8 and OpenVPN 2.3 Having Issues
Everything works when I use AirVPN 1.7 with 2.2.2
When I upgraded to be compliant I am able to get the Login screen and connect but it hangs
Any suggestion as to what is going on?
All my Commodo Firewall rule as same configuration as for 1.7.
Only thing I see is something called Socket Buffers 8192 -> 8192. No idea what that is.
Something up UDPvlink no idea what that is either
2/27/2013 - 8:17 PM AirVPN client version: 1.8
2/27/2013 - 8:17 PM Reading options from C:\Users\xyz\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
2/27/2013 - 8:17 PM OpenVPN bundle version: OpenVPN 2.3.0
2/27/2013 - 8:17 PM OpenVPN current version: OpenVPN 2.3.0
2/27/2013 - 8:17 PM Ready.
2/27/2013 - 8:17 PM Login...
2/27/2013 - 8:17 PM Login success.
2/27/2013 - 8:17 PM Contacting service...
2/27/2013 - 8:17 PM Connecting...
2/27/2013 - 8:17 PM OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
2/27/2013 - 8:17 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
2/27/2013 - 8:17 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
2/27/2013 - 8:17 PM UDPv4 link local: [undef]
2/27/2013 - 8:17 PM UDPv4 link remote: [AF_INET]95.211.191.33:443
2/27/2013 - 8:18 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2/27/2013 - 8:18 PM TLS Error: TLS handshake failed
2/27/2013 - 8:18 PM SIGUSR1[soft,tls-error] received, process restarting
2/27/2013 - 8:18 PM Restart pause, 2 second(s)
2/27/2013 - 8:18 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
2/27/2013 - 8:18 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
2/27/2013 - 8:18 PM UDPv4 link local: [undef]
2/27/2013 - 8:18 PM UDPv4 link remote: [AF_INET]95.211.191.33:443
Apparently something is blocking outgoing OpenVPN packets. Please make sure that the new openvpn.exe you are running is not blocked by your firewall or any other program.
Thank you kindly.
Noticed that when I got a pop earlier saying, do you trust this application or run it as web browser all the time. I had clicked run it....which failed
I removed those rules, and redid open vpn and everything worked great!!!
