Not connected, Your IP: 216.73.216.114
So I am unable to connect.
I don't know what is happening.
Here is the log.
Please help but understand that I am not versed on this and what it means.
Regards.
. 2026.04.25 17:46:49 - Connection terminated.
I 2026.04.25 17:46:52 - Checking authorization ...
. 2026.04.25 17:46:53 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 17:46:53 - Connecting to Alhena (Canada, Toronto, Ontario)
. 2026.04.25 17:46:53 - Routes, skipped for 162.219.176.5 : IPv4 Net gateway not available.
. 2026.04.25 17:46:53 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 17:46:53 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 17:46:53 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 17:46:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:46:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:46:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:46:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:46:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]162.219.176.5:443
. 2026.04.25 17:46:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 17:46:53 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 17:46:53 - OpenVPN > UDP link remote: [AF_INET]162.219.176.5:443
. 2026.04.25 17:46:53 - OpenVPN > TLS: Initial packet from [AF_INET]162.219.176.5:443, sid=f87b860c f4e11a67
. 2026.04.25 17:47:26 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2026.04.25 17:47:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 17:47:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2026.04.25 17:47:31 - Disconnecting
. 2026.04.25 17:47:31 - Routes, skipped for 162.219.176.5 : IPv4 Net gateway not available.
. 2026.04.25 17:47:31 - Connection terminated.
I 2026.04.25 17:47:34 - Checking authorization ...
. 2026.04.25 17:47:35 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 17:47:35 - Connecting to Regulus (Canada, Toronto, Ontario)
. 2026.04.25 17:47:35 - Routes, skipped for 184.75.221.37 : IPv4 Net gateway not available.
. 2026.04.25 17:47:35 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 17:47:35 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 17:47:35 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 17:47:35 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:47:35 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:47:35 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:47:35 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:47:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.37:443
. 2026.04.25 17:47:35 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 17:47:35 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 17:47:35 - OpenVPN > UDP link remote: [AF_INET]184.75.221.37:443
. 2026.04.25 17:47:35 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.37:443, sid=de4fdcd5 40e2b5fe
. 2026.04.25 17:47:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 17:47:35 - OpenVPN > VERIFY KU OK
. 2026.04.25 17:47:35 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 17:47:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 17:47:35 - OpenVPN > VERIFY EKU OK
. 2026.04.25 17:47:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Regulus, emailAddress=info@airvpn.org
. 2026.04.25 17:47:35 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 17:47:35 - OpenVPN > [Regulus] Peer Connection Initiated with [AF_INET]184.75.221.37:443
. 2026.04.25 17:47:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.26.1,dhcp-option DNS6 fde6:7a:7d20:181a::1,tun-ipv6,route-gateway 10.28.26.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:181a::106d/64 fde6:7a:7d20:181a::1,ifconfig 10.28.26.111 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2026.04.25 17:47:35 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 17:47:35 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.28.26.1'
. 2026.04.25 17:47:35 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:181a::1'
. 2026.04.25 17:47:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 17:47:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 17:47:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 17:47:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 17:47:35 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 17:47:35 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 17:47:35 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 17:47:35 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 17:47:35 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:47:35 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:47:35 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 17:47:35 - OpenVPN > open_tun
. 2026.04.25 17:47:35 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 17:47:36 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.28.26.111 255.255.255.0
. 2026.04.25 17:47:36 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 17:47:36 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 17:47:36 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:47:36 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:181a::106d/128 store=active
. 2026.04.25 17:47:36 - OpenVPN > add_route_ipv6(fde6:7a:7d20:181a::/64 -> fde6:7a:7d20:181a::106d metric 0) dev Eddie
. 2026.04.25 17:47:36 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:181a::/64 51 fe80::8 store=active
. 2026.04.25 17:47:36 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 17:47:36 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 17:47:36 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:47:36 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 17:47:36 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 17:47:36 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 17:47:36 - DNS leak protection with packet filtering enabled.
. 2026.04.25 17:47:37 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.28.26.1)
. 2026.04.25 17:47:37 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:181a::1)
. 2026.04.25 17:47:37 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:47:38 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:47:38 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:47:38 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:47:39 - Routes, add 184.75.221.35/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:47:39 - Routes, add 2606:6080:1001:e:2e9c:bad5:dbdd:84ea/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:47:39 - Flushing DNS
I 2026.04.25 17:47:39 - Checking route IPv4
. 2026.04.25 17:48:49 - Checking route (4° try)
. 2026.04.25 17:49:14 - Checking route (5° try)
E 2026.04.25 17:49:35 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 17:49:35 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 17:49:35 - Above log line repeated 17 times more
! 2026.04.25 17:49:35 - Disconnecting
. 2026.04.25 17:49:35 - Sending soft termination signal
. 2026.04.25 17:49:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 17:49:39 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 17:49:39 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:181a::/64)
. 2026.04.25 17:49:39 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:181a::/64 51 fe80::8 store=active
. 2026.04.25 17:49:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:181a::106d store=active
. 2026.04.25 17:49:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.28.26.111 store=active
. 2026.04.25 17:49:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 17:49:40 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:40 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:41 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:41 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:41 - Routes, skipped for 184.75.221.37 : IPv4 Net gateway not available.
. 2026.04.25 17:49:41 - Routes, delete 184.75.221.35/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:42 - Routes, delete 2606:6080:1001:e:2e9c:bad5:dbdd:84ea/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:42 - Routes, skipped for 184.75.221.37 : IPv4 Net gateway not available.
. 2026.04.25 17:49:42 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:49:42 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:49:42 - DNS leak protection with packet filtering disabled.
. 2026.04.25 17:49:42 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 17:49:42 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 17:49:42 - Connection terminated.
I 2026.04.25 17:49:45 - Checking authorization ...
. 2026.04.25 17:49:46 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 17:49:46 - Connecting to Alkurhah (Canada, Toronto, Ontario)
. 2026.04.25 17:49:46 - Routes, skipped for 184.75.221.205 : IPv4 Net gateway not available.
. 2026.04.25 17:49:46 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 17:49:46 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 17:49:46 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 17:49:46 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:49:46 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:49:46 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:49:46 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:49:46 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.205:443
. 2026.04.25 17:49:46 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 17:49:46 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 17:49:46 - OpenVPN > UDP link remote: [AF_INET]184.75.221.205:443
. 2026.04.25 17:49:46 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.205:443, sid=966fa547 ffd42bce
. 2026.04.25 17:49:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 17:49:46 - OpenVPN > VERIFY KU OK
. 2026.04.25 17:49:46 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 17:49:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 17:49:46 - OpenVPN > VERIFY EKU OK
. 2026.04.25 17:49:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alkurhah, emailAddress=info@airvpn.org
. 2026.04.25 17:49:46 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 17:49:46 - OpenVPN > [Alkurhah] Peer Connection Initiated with [AF_INET]184.75.221.205:443
. 2026.04.25 17:49:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.6.218.1,dhcp-option DNS6 fde6:7a:7d20:2da::1,tun-ipv6,route-gateway 10.6.218.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:2da::1099/64 fde6:7a:7d20:2da::1,ifconfig 10.6.218.155 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2026.04.25 17:49:46 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 17:49:46 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.6.218.1'
. 2026.04.25 17:49:46 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:2da::1'
. 2026.04.25 17:49:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 17:49:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 17:49:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 17:49:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 17:49:46 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 17:49:46 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 17:49:46 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 17:49:46 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 17:49:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:49:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:49:46 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 17:49:46 - OpenVPN > open_tun
. 2026.04.25 17:49:46 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 17:49:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.6.218.155 255.255.255.0
. 2026.04.25 17:49:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 17:49:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 17:49:47 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:49:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:2da::1099/128 store=active
. 2026.04.25 17:49:47 - OpenVPN > add_route_ipv6(fde6:7a:7d20:2da::/64 -> fde6:7a:7d20:2da::1099 metric 0) dev Eddie
. 2026.04.25 17:49:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:2da::/64 51 fe80::8 store=active
. 2026.04.25 17:49:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 17:49:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 17:49:47 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:49:47 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 17:49:47 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 17:49:47 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 17:49:47 - DNS leak protection with packet filtering enabled.
. 2026.04.25 17:49:48 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.6.218.1)
. 2026.04.25 17:49:48 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:2da::1)
. 2026.04.25 17:49:48 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:49 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:49 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:49 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:50 - Routes, add 184.75.221.203/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:50 - Routes, add 2606:6080:1001:16:3492:5f11:f1fb:66ae/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:49:50 - Flushing DNS
I 2026.04.25 17:49:50 - Checking route IPv4
. 2026.04.25 17:51:00 - Checking route (4° try)
. 2026.04.25 17:51:25 - Checking route (5° try)
E 2026.04.25 17:51:46 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 17:51:46 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 17:51:46 - Above log line repeated 10 times more
! 2026.04.25 17:51:46 - Disconnecting
. 2026.04.25 17:51:46 - Sending soft termination signal
. 2026.04.25 17:51:49 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 17:51:51 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 17:51:51 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:2da::/64)
. 2026.04.25 17:51:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:2da::/64 51 fe80::8 store=active
. 2026.04.25 17:51:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:2da::1099 store=active
. 2026.04.25 17:51:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.6.218.155 store=active
. 2026.04.25 17:51:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 17:51:52 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:51:53 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:51:53 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:51:53 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:51:53 - Routes, skipped for 184.75.221.205 : IPv4 Net gateway not available.
. 2026.04.25 17:51:54 - Routes, delete 184.75.221.203/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:51:54 - Routes, delete 2606:6080:1001:16:3492:5f11:f1fb:66ae/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:51:54 - Routes, skipped for 184.75.221.205 : IPv4 Net gateway not available.
. 2026.04.25 17:51:54 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:51:54 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:51:54 - DNS leak protection with packet filtering disabled.
. 2026.04.25 17:51:55 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 17:51:55 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 17:51:55 - Connection terminated.
. 2026.04.25 17:51:58 - Waiting for latency tests (254 to go)
. 2026.04.25 17:51:59 - Waiting for latency tests (14 to go)
. 2026.04.25 17:52:00 - Waiting for latency tests (5 to go)
I 2026.04.25 17:52:02 - Checking authorization ...
. 2026.04.25 17:52:02 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 17:52:02 - Connecting to Mintaka (Canada, Toronto, Ontario)
. 2026.04.25 17:52:02 - Routes, skipped for 184.75.223.221 : IPv4 Net gateway not available.
. 2026.04.25 17:52:03 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 17:52:03 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 17:52:03 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 17:52:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:52:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:52:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:52:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:52:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.221:443
. 2026.04.25 17:52:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 17:52:03 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 17:52:03 - OpenVPN > UDP link remote: [AF_INET]184.75.223.221:443
. 2026.04.25 17:52:03 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.221:443, sid=93757b47 272ec4cf
. 2026.04.25 17:52:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 17:52:03 - OpenVPN > VERIFY KU OK
. 2026.04.25 17:52:03 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 17:52:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 17:52:03 - OpenVPN > VERIFY EKU OK
. 2026.04.25 17:52:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mintaka, emailAddress=info@airvpn.org
. 2026.04.25 17:52:03 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 17:52:03 - OpenVPN > [Mintaka] Peer Connection Initiated with [AF_INET]184.75.223.221:443
. 2026.04.25 17:52:03 - OpenVPN > SENT CONTROL [Mintaka]: 'PUSH_REQUEST' (status=1)
. 2026.04.25 17:52:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.26.1,dhcp-option DNS6 fde6:7a:7d20:141a::1,tun-ipv6,route-gateway 10.24.26.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:141a::10cb/64 fde6:7a:7d20:141a::1,ifconfig 10.24.26.205 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2026.04.25 17:52:03 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 17:52:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.24.26.1'
. 2026.04.25 17:52:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:141a::1'
. 2026.04.25 17:52:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 17:52:03 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 17:52:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 17:52:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 17:52:03 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 17:52:03 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 17:52:03 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 17:52:03 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 17:52:03 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:52:03 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:52:03 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 17:52:03 - OpenVPN > open_tun
. 2026.04.25 17:52:03 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 17:52:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.24.26.205 255.255.255.0
. 2026.04.25 17:52:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 17:52:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 17:52:04 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:52:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:141a::10cb/128 store=active
. 2026.04.25 17:52:04 - OpenVPN > add_route_ipv6(fde6:7a:7d20:141a::/64 -> fde6:7a:7d20:141a::10cb metric 0) dev Eddie
. 2026.04.25 17:52:04 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:141a::/64 51 fe80::8 store=active
. 2026.04.25 17:52:04 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 17:52:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 17:52:04 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:52:04 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 17:52:04 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 17:52:04 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 17:52:04 - DNS leak protection with packet filtering enabled.
. 2026.04.25 17:52:04 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.24.26.1)
. 2026.04.25 17:52:04 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:141a::1)
. 2026.04.25 17:52:05 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:52:05 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:52:06 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:52:06 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:52:07 - Routes, add 184.75.223.219/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:52:07 - Routes, add 2606:6080:1002:7:def:437f:f6fa:7759/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:52:07 - Flushing DNS
I 2026.04.25 17:52:07 - Checking route IPv4
. 2026.04.25 17:53:16 - Checking route (4° try)
. 2026.04.25 17:53:41 - Checking route (5° try)
E 2026.04.25 17:54:02 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 17:54:02 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 17:54:02 - Above log line repeated 8 times more
! 2026.04.25 17:54:02 - Disconnecting
. 2026.04.25 17:54:02 - Sending soft termination signal
. 2026.04.25 17:54:06 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 17:54:07 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 17:54:07 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:141a::/64)
. 2026.04.25 17:54:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:141a::/64 51 fe80::8 store=active
. 2026.04.25 17:54:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:141a::10cb store=active
. 2026.04.25 17:54:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.24.26.205 store=active
. 2026.04.25 17:54:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 17:54:08 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:09 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:09 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:09 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:09 - Routes, skipped for 184.75.223.221 : IPv4 Net gateway not available.
. 2026.04.25 17:54:10 - Routes, delete 184.75.223.219/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:10 - Routes, delete 2606:6080:1002:7:def:437f:f6fa:7759/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:10 - Routes, skipped for 184.75.223.221 : IPv4 Net gateway not available.
. 2026.04.25 17:54:10 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:54:10 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:54:10 - DNS leak protection with packet filtering disabled.
. 2026.04.25 17:54:10 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 17:54:10 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 17:54:10 - Connection terminated.
I 2026.04.25 17:54:13 - Checking authorization ...
. 2026.04.25 17:54:14 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 17:54:14 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2026.04.25 17:54:14 - Routes, skipped for 184.75.214.165 : IPv4 Net gateway not available.
. 2026.04.25 17:54:14 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 17:54:14 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 17:54:14 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 17:54:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:54:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:54:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:54:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:54:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.214.165:443
. 2026.04.25 17:54:14 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 17:54:14 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 17:54:14 - OpenVPN > UDP link remote: [AF_INET]184.75.214.165:443
. 2026.04.25 17:54:16 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.214.165:443, sid=84fd3333 e8f6710d
. 2026.04.25 17:54:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 17:54:17 - OpenVPN > VERIFY KU OK
. 2026.04.25 17:54:17 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 17:54:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 17:54:17 - OpenVPN > VERIFY EKU OK
. 2026.04.25 17:54:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cephei, emailAddress=info@airvpn.org
. 2026.04.25 17:54:17 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 17:54:17 - OpenVPN > [Cephei] Peer Connection Initiated with [AF_INET]184.75.214.165:443
. 2026.04.25 17:54:17 - OpenVPN > SENT CONTROL [Cephei]: 'PUSH_REQUEST' (status=1)
. 2026.04.25 17:54:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.13.122.1,dhcp-option DNS6 fde6:7a:7d20:97a::1,tun-ipv6,route-gateway 10.13.122.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:97a::1021/64 fde6:7a:7d20:97a::1,ifconfig 10.13.122.35 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2026.04.25 17:54:17 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 17:54:17 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.13.122.1'
. 2026.04.25 17:54:17 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:97a::1'
. 2026.04.25 17:54:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 17:54:17 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 17:54:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 17:54:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 17:54:17 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 17:54:17 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 17:54:17 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 17:54:17 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 17:54:17 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:54:17 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:54:17 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 17:54:17 - OpenVPN > open_tun
. 2026.04.25 17:54:17 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 17:54:17 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.13.122.35 255.255.255.0
. 2026.04.25 17:54:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 17:54:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 17:54:18 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:54:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:97a::1021/128 store=active
. 2026.04.25 17:54:18 - OpenVPN > add_route_ipv6(fde6:7a:7d20:97a::/64 -> fde6:7a:7d20:97a::1021 metric 0) dev Eddie
. 2026.04.25 17:54:18 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:97a::/64 51 fe80::8 store=active
. 2026.04.25 17:54:18 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 17:54:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 17:54:18 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:54:18 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 17:54:18 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 17:54:18 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 17:54:18 - DNS leak protection with packet filtering enabled.
. 2026.04.25 17:54:18 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.13.122.1)
. 2026.04.25 17:54:18 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:97a::1)
. 2026.04.25 17:54:19 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:19 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:20 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:20 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:20 - Routes, add 184.75.214.163/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:21 - Routes, add 2606:6080:1001:c:1d9a:8f36:e174:d7c5/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:54:21 - Flushing DNS
I 2026.04.25 17:54:21 - Checking route IPv4
. 2026.04.25 17:55:30 - Checking route (4° try)
. 2026.04.25 17:55:55 - Checking route (5° try)
E 2026.04.25 17:56:16 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 17:56:16 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 17:56:16 - Above log line repeated 16 times more
! 2026.04.25 17:56:16 - Disconnecting
. 2026.04.25 17:56:16 - Sending soft termination signal
. 2026.04.25 17:56:19 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 17:56:21 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 17:56:21 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:97a::/64)
. 2026.04.25 17:56:21 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:97a::/64 51 fe80::8 store=active
. 2026.04.25 17:56:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:97a::1021 store=active
. 2026.04.25 17:56:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.13.122.35 store=active
. 2026.04.25 17:56:21 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 17:56:22 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:22 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:23 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:23 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:23 - Routes, skipped for 184.75.214.165 : IPv4 Net gateway not available.
. 2026.04.25 17:56:24 - Routes, delete 184.75.214.163/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:24 - Routes, delete 2606:6080:1001:c:1d9a:8f36:e174:d7c5/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:24 - Routes, skipped for 184.75.214.165 : IPv4 Net gateway not available.
. 2026.04.25 17:56:24 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:56:24 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:56:24 - DNS leak protection with packet filtering disabled.
. 2026.04.25 17:56:24 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 17:56:24 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 17:56:24 - Connection terminated.
I 2026.04.25 17:56:27 - Checking authorization ...
. 2026.04.25 17:56:28 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 17:56:28 - Connecting to Agena (Canada, Toronto, Ontario)
. 2026.04.25 17:56:28 - Routes, skipped for 184.75.223.213 : IPv4 Net gateway not available.
. 2026.04.25 17:56:28 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 17:56:28 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 17:56:28 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 17:56:28 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:56:28 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:56:28 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:56:28 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:56:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.213:443
. 2026.04.25 17:56:28 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 17:56:28 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 17:56:28 - OpenVPN > UDP link remote: [AF_INET]184.75.223.213:443
. 2026.04.25 17:56:28 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.213:443, sid=e7171b53 5db86834
. 2026.04.25 17:56:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 17:56:28 - OpenVPN > VERIFY KU OK
. 2026.04.25 17:56:28 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 17:56:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 17:56:28 - OpenVPN > VERIFY EKU OK
. 2026.04.25 17:56:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Agena, emailAddress=info@airvpn.org
. 2026.04.25 17:56:28 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 17:56:28 - OpenVPN > [Agena] Peer Connection Initiated with [AF_INET]184.75.223.213:443
. 2026.04.25 17:56:29 - OpenVPN > SENT CONTROL [Agena]: 'PUSH_REQUEST' (status=1)
. 2026.04.25 17:56:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.218.1,dhcp-option DNS6 fde6:7a:7d20:da::1,tun-ipv6,route-gateway 10.4.218.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:da::1024/64 fde6:7a:7d20:da::1,ifconfig 10.4.218.38 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2026.04.25 17:56:29 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 17:56:29 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.4.218.1'
. 2026.04.25 17:56:29 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:da::1'
. 2026.04.25 17:56:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 17:56:29 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 17:56:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 17:56:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 17:56:29 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 17:56:29 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 17:56:29 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 17:56:29 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 17:56:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:56:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:56:29 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 17:56:29 - OpenVPN > open_tun
. 2026.04.25 17:56:29 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 17:56:30 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.4.218.38 255.255.255.0
. 2026.04.25 17:56:30 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 17:56:30 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 17:56:30 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:56:30 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:da::1024/128 store=active
. 2026.04.25 17:56:30 - OpenVPN > add_route_ipv6(fde6:7a:7d20:da::/64 -> fde6:7a:7d20:da::1024 metric 0) dev Eddie
. 2026.04.25 17:56:30 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:da::/64 51 fe80::8 store=active
. 2026.04.25 17:56:30 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 17:56:30 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 17:56:30 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:56:30 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 17:56:30 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 17:56:30 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 17:56:30 - DNS leak protection with packet filtering enabled.
. 2026.04.25 17:56:30 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.4.218.1)
. 2026.04.25 17:56:30 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:da::1)
. 2026.04.25 17:56:31 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:31 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:32 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:32 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:33 - Routes, add 184.75.223.211/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:33 - Routes, add 2606:6080:1002:6:f780:efa6:f9d2:3459/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:56:33 - Flushing DNS
I 2026.04.25 17:56:33 - Checking route IPv4
. 2026.04.25 17:57:42 - Checking route (4° try)
. 2026.04.25 17:58:07 - Checking route (5° try)
E 2026.04.25 17:58:28 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 17:58:28 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 17:58:28 - Above log line repeated 4 times more
! 2026.04.25 17:58:28 - Disconnecting
. 2026.04.25 17:58:28 - Sending soft termination signal
. 2026.04.25 17:58:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 17:58:33 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 17:58:33 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:da::/64)
. 2026.04.25 17:58:33 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:da::/64 51 fe80::8 store=active
. 2026.04.25 17:58:33 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:da::1024 store=active
. 2026.04.25 17:58:33 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.4.218.38 store=active
. 2026.04.25 17:58:33 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 17:58:34 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:34 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:35 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:35 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:35 - Routes, skipped for 184.75.223.213 : IPv4 Net gateway not available.
. 2026.04.25 17:58:36 - Routes, delete 184.75.223.211/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:36 - Routes, delete 2606:6080:1002:6:f780:efa6:f9d2:3459/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:36 - Routes, skipped for 184.75.223.213 : IPv4 Net gateway not available.
. 2026.04.25 17:58:36 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:58:36 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 17:58:36 - DNS leak protection with packet filtering disabled.
. 2026.04.25 17:58:36 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 17:58:36 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 17:58:36 - Connection terminated.
I 2026.04.25 17:58:39 - Checking authorization ...
. 2026.04.25 17:58:40 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 17:58:40 - Connecting to Alwaid (Canada, Toronto, Ontario)
. 2026.04.25 17:58:40 - Routes, skipped for 184.75.221.109 : IPv4 Net gateway not available.
. 2026.04.25 17:58:40 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 17:58:40 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 17:58:40 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 17:58:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:58:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:58:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 17:58:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 17:58:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.109:443
. 2026.04.25 17:58:40 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 17:58:40 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 17:58:40 - OpenVPN > UDP link remote: [AF_INET]184.75.221.109:443
. 2026.04.25 17:58:40 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.109:443, sid=cdbde049 11285cce
. 2026.04.25 17:58:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 17:58:40 - OpenVPN > VERIFY KU OK
. 2026.04.25 17:58:40 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 17:58:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 17:58:40 - OpenVPN > VERIFY EKU OK
. 2026.04.25 17:58:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alwaid, emailAddress=info@airvpn.org
. 2026.04.25 17:58:40 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 17:58:40 - OpenVPN > [Alwaid] Peer Connection Initiated with [AF_INET]184.75.221.109:443
. 2026.04.25 17:58:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.154.1,dhcp-option DNS6 fde6:7a:7d20:49a::1,tun-ipv6,route-gateway 10.8.154.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:49a::1061/64 fde6:7a:7d20:49a::1,ifconfig 10.8.154.99 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2026.04.25 17:58:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 17:58:41 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.154.1'
. 2026.04.25 17:58:41 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:49a::1'
. 2026.04.25 17:58:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 17:58:41 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 17:58:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 17:58:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 17:58:41 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 17:58:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 17:58:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 17:58:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 17:58:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:58:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 17:58:41 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 17:58:41 - OpenVPN > open_tun
. 2026.04.25 17:58:41 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 17:58:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.8.154.99 255.255.255.0
. 2026.04.25 17:58:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 17:58:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 17:58:41 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:58:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:49a::1061/128 store=active
. 2026.04.25 17:58:41 - OpenVPN > add_route_ipv6(fde6:7a:7d20:49a::/64 -> fde6:7a:7d20:49a::1061 metric 0) dev Eddie
. 2026.04.25 17:58:41 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:49a::/64 51 fe80::8 store=active
. 2026.04.25 17:58:41 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 17:58:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 17:58:41 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 17:58:41 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 17:58:42 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 17:58:42 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 17:58:42 - DNS leak protection with packet filtering enabled.
. 2026.04.25 17:58:42 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.8.154.1)
. 2026.04.25 17:58:42 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:49a::1)
. 2026.04.25 17:58:42 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:43 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:43 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:44 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:44 - Routes, add 184.75.221.107/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:44 - Routes, add 2606:6080:1001:30:5f94:f242:c829:1017/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 17:58:44 - Flushing DNS
I 2026.04.25 17:58:45 - Checking route IPv4
. 2026.04.25 17:59:54 - Checking route (4° try)
. 2026.04.25 18:00:19 - Checking route (5° try)
E 2026.04.25 18:00:40 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 18:00:40 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 18:00:40 - Above log line repeated 8 times more
! 2026.04.25 18:00:40 - Disconnecting
. 2026.04.25 18:00:40 - Sending soft termination signal
. 2026.04.25 18:00:43 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 18:00:45 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 18:00:45 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:49a::/64)
. 2026.04.25 18:00:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:49a::/64 51 fe80::8 store=active
. 2026.04.25 18:00:45 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:49a::1061 store=active
. 2026.04.25 18:00:45 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.8.154.99 store=active
. 2026.04.25 18:00:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 18:00:46 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:46 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:47 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:47 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:47 - Routes, skipped for 184.75.221.109 : IPv4 Net gateway not available.
. 2026.04.25 18:00:47 - Routes, delete 184.75.221.107/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:48 - Routes, delete 2606:6080:1001:30:5f94:f242:c829:1017/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:48 - Routes, skipped for 184.75.221.109 : IPv4 Net gateway not available.
. 2026.04.25 18:00:48 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:00:48 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:00:48 - DNS leak protection with packet filtering disabled.
. 2026.04.25 18:00:48 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 18:00:48 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 18:00:48 - Connection terminated.
I 2026.04.25 18:00:51 - Checking authorization ...
. 2026.04.25 18:00:52 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 18:00:52 - Connecting to Avior (Canada, Toronto, Ontario)
. 2026.04.25 18:00:52 - Routes, skipped for 184.75.223.237 : IPv4 Net gateway not available.
. 2026.04.25 18:00:52 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 18:00:52 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 18:00:52 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 18:00:52 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:00:52 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:00:52 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:00:52 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:00:52 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.237:443
. 2026.04.25 18:00:52 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 18:00:52 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 18:00:52 - OpenVPN > UDP link remote: [AF_INET]184.75.223.237:443
. 2026.04.25 18:00:54 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.237:443, sid=87d0561d 83d8c7d9
. 2026.04.25 18:00:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 18:00:54 - OpenVPN > VERIFY KU OK
. 2026.04.25 18:00:54 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 18:00:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 18:00:54 - OpenVPN > VERIFY EKU OK
. 2026.04.25 18:00:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Avior, emailAddress=info@airvpn.org
. 2026.04.25 18:00:54 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 18:00:54 - OpenVPN > [Avior] Peer Connection Initiated with [AF_INET]184.75.223.237:443
. 2026.04.25 18:00:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.10.250.1,dhcp-option DNS6 fde6:7a:7d20:6fa::1,tun-ipv6,route-gateway 10.10.250.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:6fa::106f/64 fde6:7a:7d20:6fa::1,ifconfig 10.10.250.113 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2026.04.25 18:00:55 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 18:00:55 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.10.250.1'
. 2026.04.25 18:00:55 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:6fa::1'
. 2026.04.25 18:00:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 18:00:55 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 18:00:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 18:00:55 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 18:00:55 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 18:00:55 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 18:00:55 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 18:00:55 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 18:00:55 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:00:55 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:00:55 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 18:00:55 - OpenVPN > open_tun
. 2026.04.25 18:00:55 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 18:00:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.10.250.113 255.255.255.0
. 2026.04.25 18:00:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 18:00:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 18:00:55 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:00:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:6fa::106f/128 store=active
. 2026.04.25 18:00:55 - OpenVPN > add_route_ipv6(fde6:7a:7d20:6fa::/64 -> fde6:7a:7d20:6fa::106f metric 0) dev Eddie
. 2026.04.25 18:00:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:6fa::/64 51 fe80::8 store=active
. 2026.04.25 18:00:56 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 18:00:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 18:00:56 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:00:56 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 18:00:56 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 18:00:56 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 18:00:56 - DNS leak protection with packet filtering enabled.
. 2026.04.25 18:00:56 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.10.250.1)
. 2026.04.25 18:00:56 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:6fa::1)
. 2026.04.25 18:00:57 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:57 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:58 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:58 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:59 - Routes, add 184.75.223.235/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:59 - Routes, add 2606:6080:1002:9:ffc4:b9c1:20ad:82f9/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:00:59 - Flushing DNS
I 2026.04.25 18:00:59 - Checking route IPv4
. 2026.04.25 18:02:08 - Checking route (4° try)
. 2026.04.25 18:02:34 - Checking route (5° try)
E 2026.04.25 18:02:55 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 18:02:55 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 18:02:55 - Above log line repeated 18 times more
! 2026.04.25 18:02:55 - Disconnecting
. 2026.04.25 18:02:55 - Sending soft termination signal
. 2026.04.25 18:02:58 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 18:02:59 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 18:02:59 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:6fa::/64)
. 2026.04.25 18:02:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:6fa::/64 51 fe80::8 store=active
. 2026.04.25 18:02:59 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:6fa::106f store=active
. 2026.04.25 18:02:59 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.10.250.113 store=active
. 2026.04.25 18:02:59 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 18:03:00 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:00 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:01 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:01 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:01 - Routes, skipped for 184.75.223.237 : IPv4 Net gateway not available.
. 2026.04.25 18:03:01 - Routes, delete 184.75.223.235/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:02 - Routes, delete 2606:6080:1002:9:ffc4:b9c1:20ad:82f9/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:02 - Routes, skipped for 184.75.223.237 : IPv4 Net gateway not available.
. 2026.04.25 18:03:02 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:03:02 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:03:02 - DNS leak protection with packet filtering disabled.
. 2026.04.25 18:03:02 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 18:03:02 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 18:03:02 - Connection terminated.
I 2026.04.25 18:03:05 - Checking authorization ...
. 2026.04.25 18:03:06 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 18:03:06 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2026.04.25 18:03:06 - Routes, skipped for 184.75.223.205 : IPv4 Net gateway not available.
. 2026.04.25 18:03:06 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 18:03:06 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 18:03:06 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 18:03:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:03:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:03:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:03:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:03:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.205:443
. 2026.04.25 18:03:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 18:03:06 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 18:03:06 - OpenVPN > UDP link remote: [AF_INET]184.75.223.205:443
. 2026.04.25 18:03:06 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.205:443, sid=a12a8735 887deafc
. 2026.04.25 18:03:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 18:03:06 - OpenVPN > VERIFY KU OK
. 2026.04.25 18:03:06 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 18:03:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 18:03:06 - OpenVPN > VERIFY EKU OK
. 2026.04.25 18:03:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tyl, emailAddress=info@airvpn.org
. 2026.04.25 18:03:06 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 18:03:06 - OpenVPN > [Tyl] Peer Connection Initiated with [AF_INET]184.75.223.205:443
. 2026.04.25 18:03:06 - OpenVPN > SENT CONTROL [Tyl]: 'PUSH_REQUEST' (status=1)
. 2026.04.25 18:03:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.218.1,dhcp-option DNS6 fde6:7a:7d20:1bda::1,tun-ipv6,route-gateway 10.31.218.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1bda::1053/64 fde6:7a:7d20:1bda::1,ifconfig 10.31.218.85 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2026.04.25 18:03:06 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 18:03:06 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.31.218.1'
. 2026.04.25 18:03:06 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1bda::1'
. 2026.04.25 18:03:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 18:03:06 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 18:03:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 18:03:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 18:03:06 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 18:03:06 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 18:03:06 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 18:03:06 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 18:03:06 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:03:06 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:03:06 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 18:03:06 - OpenVPN > open_tun
. 2026.04.25 18:03:06 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 18:03:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.31.218.85 255.255.255.0
. 2026.04.25 18:03:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 18:03:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 18:03:07 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:03:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:1bda::1053/128 store=active
. 2026.04.25 18:03:07 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1bda::/64 -> fde6:7a:7d20:1bda::1053 metric 0) dev Eddie
. 2026.04.25 18:03:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1bda::/64 51 fe80::8 store=active
. 2026.04.25 18:03:07 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 18:03:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 18:03:07 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:03:07 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 18:03:07 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 18:03:07 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 18:03:07 - DNS leak protection with packet filtering enabled.
. 2026.04.25 18:03:08 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.31.218.1)
. 2026.04.25 18:03:08 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:1bda::1)
. 2026.04.25 18:03:08 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:09 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:09 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:09 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:10 - Routes, add 184.75.223.203/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:10 - Routes, add 2606:6080:1002:5:a1ba:b510:7908:829e/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:03:10 - Flushing DNS
I 2026.04.25 18:03:10 - Checking route IPv4
. 2026.04.25 18:04:20 - Checking route (4° try)
. 2026.04.25 18:04:45 - Checking route (5° try)
E 2026.04.25 18:05:06 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 18:05:06 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 18:05:06 - Above log line repeated 18 times more
! 2026.04.25 18:05:06 - Disconnecting
. 2026.04.25 18:05:06 - Sending soft termination signal
. 2026.04.25 18:05:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 18:05:10 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 18:05:10 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1bda::/64)
. 2026.04.25 18:05:10 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1bda::/64 51 fe80::8 store=active
. 2026.04.25 18:05:11 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:1bda::1053 store=active
. 2026.04.25 18:05:11 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.31.218.85 store=active
. 2026.04.25 18:05:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 18:05:11 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:12 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:12 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:13 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:13 - Routes, skipped for 184.75.223.205 : IPv4 Net gateway not available.
. 2026.04.25 18:05:13 - Routes, delete 184.75.223.203/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:13 - Routes, delete 2606:6080:1002:5:a1ba:b510:7908:829e/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:13 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:05:13 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:05:13 - DNS leak protection with packet filtering disabled.
. 2026.04.25 18:05:14 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 18:05:14 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 18:05:14 - Connection terminated.
I 2026.04.25 18:05:17 - Checking authorization ...
. 2026.04.25 18:05:17 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 18:05:17 - Connecting to Elgafar (Canada, Toronto, Ontario)
. 2026.04.25 18:05:17 - Routes, skipped for 198.44.157.61 : IPv4 Net gateway not available.
. 2026.04.25 18:05:18 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 18:05:18 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 18:05:18 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 18:05:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:05:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:05:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:05:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:05:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]198.44.157.61:443
. 2026.04.25 18:05:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 18:05:18 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 18:05:18 - OpenVPN > UDP link remote: [AF_INET]198.44.157.61:443
. 2026.04.25 18:05:18 - OpenVPN > TLS: Initial packet from [AF_INET]198.44.157.61:443, sid=937a0ab1 4fefae6f
. 2026.04.25 18:05:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 18:05:18 - OpenVPN > VERIFY KU OK
. 2026.04.25 18:05:18 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 18:05:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 18:05:18 - OpenVPN > VERIFY EKU OK
. 2026.04.25 18:05:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Elgafar, emailAddress=info@airvpn.org
. 2026.04.25 18:05:18 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 18:05:18 - OpenVPN > [Elgafar] Peer Connection Initiated with [AF_INET]198.44.157.61:443
. 2026.04.25 18:05:18 - OpenVPN > SENT CONTROL [Elgafar]: 'PUSH_REQUEST' (status=1)
. 2026.04.25 18:05:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.78.154.1,dhcp-option DNS6 fde6:7a:7d20:4a9a::1,tun-ipv6,route-gateway 10.78.154.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4a9a::106f/64 fde6:7a:7d20:4a9a::1,ifconfig 10.78.154.113 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2026.04.25 18:05:18 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 18:05:18 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.78.154.1'
. 2026.04.25 18:05:18 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4a9a::1'
. 2026.04.25 18:05:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 18:05:18 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 18:05:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 18:05:18 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 18:05:18 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 18:05:18 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 18:05:18 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 18:05:18 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 18:05:18 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:05:18 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:05:18 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 18:05:18 - OpenVPN > open_tun
. 2026.04.25 18:05:18 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 18:05:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.78.154.113 255.255.255.0
. 2026.04.25 18:05:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 18:05:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 18:05:19 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:05:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:4a9a::106f/128 store=active
. 2026.04.25 18:05:19 - OpenVPN > add_route_ipv6(fde6:7a:7d20:4a9a::/64 -> fde6:7a:7d20:4a9a::106f metric 0) dev Eddie
. 2026.04.25 18:05:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:4a9a::/64 51 fe80::8 store=active
. 2026.04.25 18:05:19 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 18:05:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 18:05:19 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:05:19 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 18:05:19 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 18:05:19 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 18:05:19 - DNS leak protection with packet filtering enabled.
. 2026.04.25 18:05:19 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.78.154.1)
. 2026.04.25 18:05:20 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:4a9a::1)
. 2026.04.25 18:05:20 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:20 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:21 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:21 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:22 - Routes, add 198.44.157.162/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:22 - Routes, add 2607:9000:600:22:ac5e:c05a:ff67:b587/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:05:22 - Flushing DNS
I 2026.04.25 18:05:22 - Checking route IPv4
. 2026.04.25 18:06:31 - Checking route (4° try)
. 2026.04.25 18:06:57 - Checking route (5° try)
E 2026.04.25 18:07:18 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2026.04.25 18:07:18 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 18:07:18 - Above log line repeated 20 times more
! 2026.04.25 18:07:18 - Disconnecting
. 2026.04.25 18:07:18 - Sending soft termination signal
. 2026.04.25 18:07:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 18:07:23 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 18:07:23 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:4a9a::/64)
. 2026.04.25 18:07:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:4a9a::/64 51 fe80::8 store=active
. 2026.04.25 18:07:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:4a9a::106f store=active
. 2026.04.25 18:07:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.78.154.113 store=active
. 2026.04.25 18:07:23 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 18:07:24 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:24 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:24 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:25 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:25 - Routes, skipped for 198.44.157.61 : IPv4 Net gateway not available.
. 2026.04.25 18:07:25 - Routes, delete 198.44.157.162/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:26 - Routes, delete 2607:9000:600:22:ac5e:c05a:ff67:b587/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:26 - Routes, skipped for 198.44.157.61 : IPv4 Net gateway not available.
. 2026.04.25 18:07:26 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:07:26 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:07:26 - DNS leak protection with packet filtering disabled.
. 2026.04.25 18:07:26 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 18:07:26 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 18:07:26 - Connection terminated.
. 2026.04.25 18:07:29 - Waiting for latency tests (254 to go)
. 2026.04.25 18:07:30 - Waiting for latency tests (228 to go)
. 2026.04.25 18:07:31 - Waiting for latency tests (2 to go)
I 2026.04.25 18:07:33 - Checking authorization ...
. 2026.04.25 18:07:34 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel #2)"
! 2026.04.25 18:07:34 - Connecting to Chamukuy (Canada, Toronto, Ontario)
. 2026.04.25 18:07:34 - Routes, skipped for 198.44.157.133 : IPv4 Net gateway not available.
. 2026.04.25 18:07:34 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2026.04.25 18:07:34 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2026.04.25 18:07:34 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2026.04.25 18:07:34 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:07:34 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:07:34 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2026.04.25 18:07:34 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2026.04.25 18:07:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]198.44.157.133:443
. 2026.04.25 18:07:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2026.04.25 18:07:34 - OpenVPN > UDP link local: (not bound)
. 2026.04.25 18:07:34 - OpenVPN > UDP link remote: [AF_INET]198.44.157.133:443
. 2026.04.25 18:07:34 - OpenVPN > TLS: Initial packet from [AF_INET]198.44.157.133:443, sid=c7565b12 5e4a2a33
. 2026.04.25 18:07:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2026.04.25 18:07:34 - OpenVPN > VERIFY KU OK
. 2026.04.25 18:07:34 - OpenVPN > Validating certificate extended key usage
. 2026.04.25 18:07:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2026.04.25 18:07:34 - OpenVPN > VERIFY EKU OK
. 2026.04.25 18:07:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chamukuy, emailAddress=info@airvpn.org
. 2026.04.25 18:07:34 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2026.04.25 18:07:34 - OpenVPN > [Chamukuy] Peer Connection Initiated with [AF_INET]198.44.157.133:443
. 2026.04.25 18:07:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.68.154.1,dhcp-option DNS6 fde6:7a:7d20:409a::1,tun-ipv6,route-gateway 10.68.154.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:409a::1081/64 fde6:7a:7d20:409a::1,ifconfig 10.68.154.131 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2026.04.25 18:07:34 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2026.04.25 18:07:34 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.68.154.1'
. 2026.04.25 18:07:34 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:409a::1'
. 2026.04.25 18:07:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2026.04.25 18:07:34 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2026.04.25 18:07:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2026.04.25 18:07:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2026.04.25 18:07:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2026.04.25 18:07:34 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2026.04.25 18:07:34 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2026.04.25 18:07:34 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2026.04.25 18:07:34 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:07:34 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2026.04.25 18:07:34 - OpenVPN > interactive service msg_channel=0
. 2026.04.25 18:07:34 - OpenVPN > open_tun
. 2026.04.25 18:07:34 - OpenVPN > wintun device [Eddie] opened
. 2026.04.25 18:07:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.68.154.131 255.255.255.0
. 2026.04.25 18:07:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2026.04.25 18:07:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2026.04.25 18:07:35 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:07:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 51 fde6:7a:7d20:409a::1081/128 store=active
. 2026.04.25 18:07:35 - OpenVPN > add_route_ipv6(fde6:7a:7d20:409a::/64 -> fde6:7a:7d20:409a::1081 metric 0) dev Eddie
. 2026.04.25 18:07:35 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:409a::/64 51 fe80::8 store=active
. 2026.04.25 18:07:35 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2026.04.25 18:07:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 51 all
. 2026.04.25 18:07:35 - OpenVPN > IPv6 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2026.04.25 18:07:35 - OpenVPN > Initialization Sequence Completed
. 2026.04.25 18:07:35 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2026.04.25 18:07:35 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2026.04.25 18:07:35 - DNS leak protection with packet filtering enabled.
. 2026.04.25 18:07:36 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.68.154.1)
. 2026.04.25 18:07:36 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:409a::1)
. 2026.04.25 18:07:36 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:37 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:37 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:37 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:38 - Routes, add 198.44.157.178/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:38 - Routes, add 2607:9000:600:23:4ad4:e968:c493:fc24/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:07:38 - Flushing DNS
I 2026.04.25 18:07:38 - Checking route IPv4
. 2026.04.25 18:08:48 - Checking route (4° try)
. 2026.04.25 18:09:09 - OpenVPN > write UDP: Unknown error (code=10065)
. 2026.04.25 18:09:09 - Above log line repeated 13 times more
! 2026.04.25 18:09:09 - Disconnecting
. 2026.04.25 18:09:09 - Sending soft termination signal
. 2026.04.25 18:09:12 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2026.04.25 18:09:13 - OpenVPN > Closing TUN/TAP interface
. 2026.04.25 18:09:13 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:409a::/64)
. 2026.04.25 18:09:13 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:409a::/64 51 fe80::8 store=active
. 2026.04.25 18:09:13 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 51 fde6:7a:7d20:409a::1081 store=active
. 2026.04.25 18:09:13 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 51 10.68.154.131 store=active
. 2026.04.25 18:09:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2026.04.25 18:09:14 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:09:14 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:09:14 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:09:15 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:09:15 - Routes, skipped for 198.44.157.133 : IPv4 Net gateway not available.
. 2026.04.25 18:09:15 - Routes, delete 198.44.157.178/32 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:09:15 - Routes, delete 2607:9000:600:23:4ad4:e968:c493:fc24/128 for interface "Eddie (Wintun Userspace Tunnel #2)".
. 2026.04.25 18:09:15 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:09:15 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2026.04.25 18:09:15 - DNS leak protection with packet filtering disabled.
. 2026.04.25 18:09:16 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2026.04.25 18:09:16 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2026.04.25 18:09:16 - Connection terminated.
I 2026.04.25 18:09:16 - Cancel requested.
! 2026.04.25 18:09:16 - Session terminated.
. 2026.04.25 18:16:10 - Collect information about AirVPN completed
. 2026.04.25 18:46:12 - Collect information about AirVPN completed
! 2026.04.25 18:57:05 - Deactivation of Network Lock
Edited ... by Tech Jedi Alex
Apply LOG format to logs
Please close Eddie, reopen, retry a connection, then provide a system report:.
