R0cky
AmneziaWG configuration generator
On 4/10/2026 at 8:30 PM, Staff said:
Not all programs support In CPS parameters. Eddie Android edition generates AmneziaWG profiles compliant to the latest official documentation and properly processed by the official Amnezia library latest release. Previous Amnezia 1.x specs may not support all the parameters. In the future we will offer Amnezia integration in our desktop software too. In the meantime you may try to update your software.
Hello! Like many others, I use native software to connect to your servers. I would very much like to see the ability to obtain a configuration for the AmneziaWG protocol in the config generator. Will this feature be implemented, and if so, when?
Yes, it is definitely planned, but we can't give you a definite ETA.
In the meantime, if you have an Android device or an Android emulator, you can use Eddie Android edition to generate configuration files (you can export them to any other system directly from Eddie's "Export" or "Open with" functions) or the Amnezia configuration patcher by @zimbabwe https://github.com/zimbabwe303/awg_conf_patch
Eddie Android edition includes 30+ CPS pre-sets of real web sites, so this is the recommended solution currently to bypass blocks.
