stallard 0 Posted ... Hi All, I have qbittorrent on TrueNAS, run by an arr stack. Qbittorrent seems to upload/seed ok, until I tried a private tracker- and they indicate my port is closed. And I have no leechers, so I suppose that's true. So I decided to test, with the results below. Seems my port is actually closed? Odd that some torrents are seeding. Kind of lost now... the tracker list in qBit says that the trackers are working- but there are 0 peers. Does this make any sense to anyone? Thanks for any tips...I'm not even sure if I'm asking the right questions. Quote Share this post Link to post
Staff 10500 Posted ... @stallard Hello! At least one error is visible: remote port number differs from local port number. Due to how a torrent program works you must configure matching remote and local ports (for additional details please read the FAQ). Just delete the "local" field of your remote port in your AirVPN account port panel, adjust qBittorrent listening port accordingly, re-start both VPN connection and qBittorrent and follow this checklist: https://airvpn.org/forums/topic/66388-port-forwarding/?tab=comments#comment-243305 Additional tips for the errors you get: Error 111 (connection refused): the connection has been actively reset by the destination system (the client, in this case your system) through a TCP RST Error 110: no reply from the destination system (client), the sent packet has been silently dropped Further information on p2p programs: https://airvpn.org/faq/p2p/ Kind regards Quote Share this post Link to post
