MLight 0 Posted ... Not sure if this is caused by the hotio qbittorrent container update or some other issue but when I tried to reach qbittorrent today the logs said "The file [/config/wireguard/forwarded_port] was not found. Set [VPN_AUTO_PORT_FORWARD=false] if you don't plan on providing that file yourself", which was a first. I switched that to false and chose to set the port manually in qbittorrent UI (which was already done). qBittorrent has a green globe which should indicate that the port is open and functional, but I keep getting timed out when testing on AirVPN client area. Is there any way to definitely confirm my port is open on the airvpn side? Quote Share this post Link to post
vuanhson 0 Posted ... There is Check open button on Port page, you can use it to check if the port open, or google port checker tool, or use AirVPN ipleak service, download the check torrent file then it will tell you the port is open or not. But I think the problem not about port or AirVPN side, I'll share you my research. Hotio update VPN setting all of his docker images recently, I start have problem with plex and qbittorrent (even green globe but tracker cannot see me) and was DM he over discord recently, funny thing is on same VPN configuration (I shared my conf file then deleted later), same docker setting, but his PC it working perfectly, I think problem is from my NAS and never found out why from that time to now. But today I saw your post, I think it definitely something strange happen with his image. Quote Share this post Link to post
Staff 10500 Posted ... On 1/13/2026 at 3:04 AM, MLight said: Not sure if this is caused by the hotio qbittorrent container update or some other issue but when I tried to reach qbittorrent today the logs said "The file [/config/wireguard/forwarded_port] was not found. Set [VPN_AUTO_PORT_FORWARD=false] if you don't plan on providing that file yourself", which was a first. I switched that to false and chose to set the port manually in qbittorrent UI (which was already done). qBittorrent has a green globe which should indicate that the port is open and functional, but I keep getting timed out when testing on AirVPN client area. Is there any way to definitely confirm my port is open on the airvpn side? Hello! Please make sure that the FIREWALL_VPN_INPUT_PORTS environment variable is properly set. Note that FIREWALL_VPN_INPUT_PORTS and FIREWALL_INPUT_PORTS are different variables for ports of different interfaces. See here: https://github.com/qdm12/gluetun-wiki/blob/main/setup/options/firewall.md Kind regards Quote Share this post Link to post
MLight 0 Posted ... Figured it out. Configuration must have changed at some point and had to set env variable of “VPN_AUTO_PORT_FORWARD” from false or true, to the port number itself in the docker compose file. This is based on the documentation here https://hotio.dev/containers/qbittorrent/#wireguard. Port is now recognized as open. Silly lil mistake on my end for not reading further into the docs Quote Share this post Link to post
