Not connected, Your IP: 216.73.216.63
DirtAddsHP
Connect keeps timing out, OpenVPN client reporting high upload rate
Recently (last 2 weeks) i have been experiencing issues with my VPN connection timing out and coming back without disconnecting. I noticed in the client a weird upload reading when this is the case... is this a bug or known issue? See attached for screenshot.
It's not a bug we're aware of, and anyway the connection is performed and maintained by OpenVPN (the Air client is an OpenVPN wrapper with some additional commodities).
Just after the problem has occurred, can you please send us the client logs?
2/22/2013 - 7:24 PM Local Options hash (VER=V4): '22188c5b'
2/22/2013 - 7:24 PM Expected Remote Options hash (VER=V4): 'a8f55717'
2/22/2013 - 7:24 PM UDPv4 link local: [undef]
2/22/2013 - 7:24 PM UDPv4 link remote: 95.211.169.3:443
2/22/2013 - 7:24 PM TLS: Initial packet from 95.211.169.3:443, sid=3d5e8328 47fde685
2/22/2013 - 7:24 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2/22/2013 - 7:24 PM VERIFY OK: nsCertType=SERVER
2/22/2013 - 7:24 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2/22/2013 - 7:24 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 7:24 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 7:24 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 7:24 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 7:24 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2/22/2013 - 7:24 PM [server] Peer Connection Initiated with 95.211.169.3:443
2/22/2013 - 7:24 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2/22/2013 - 7:24 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.18.174 10.4.18.173'
2/22/2013 - 7:24 PM OPTIONS IMPORT: timers and/or timeouts modified
2/22/2013 - 7:24 PM OPTIONS IMPORT: LZO parms modified
2/22/2013 - 7:24 PM OPTIONS IMPORT: --ifconfig/up options modified
2/22/2013 - 7:24 PM OPTIONS IMPORT: route options modified
2/22/2013 - 7:24 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2/22/2013 - 7:24 PM ROUTE default_gateway=192.168.100.2
2/22/2013 - 7:24 PM TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{70D0126B-A4A8-49E2-8C88-52B83A9E8BBC}.tap
2/22/2013 - 7:24 PM TAP-Win32 Driver Version 9.9
2/22/2013 - 7:24 PM TAP-Win32 MTU=1500
2/22/2013 - 7:24 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.18.174/255.255.255.252 on interface {70D0126B-A4A8-49E2-8C88-52B83A9E8BBC} [DHCP-serv: 10.4.18.173, lease-time: 31536000]
2/22/2013 - 7:24 PM Successful ARP Flush on interface [16] {70D0126B-A4A8-49E2-8C88-52B83A9E8BBC}
2/22/2013 - 7:24 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
2/22/2013 - 7:24 PM C:\WINDOWS\system32\route.exe ADD 95.211.169.3 MASK 255.255.255.255 192.168.100.2
2/22/2013 - 7:24 PM Warning: route gateway is ambiguous: 192.168.100.2 (2 matches)
2/22/2013 - 7:24 PM Route addition via IPAPI failed [adaptive]
2/22/2013 - 7:24 PM Route addition fallback to route.exe
2/22/2013 - 7:24 PM OK!
2/22/2013 - 7:24 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.18.173
2/22/2013 - 7:24 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
2/22/2013 - 7:24 PM Route addition via IPAPI succeeded [adaptive]
2/22/2013 - 7:24 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.18.173
2/22/2013 - 7:24 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.18.173
2/22/2013 - 7:24 PM Initialization Sequence Completed
2/22/2013 - 7:24 PM Starting Management Interface...
2/22/2013 - 7:24 PM Checking...
2/22/2013 - 7:24 PM Retrieve statistics...
2/22/2013 - 7:24 PM Connected.
2/22/2013 - 7:26 PM Replay-window backtrack occurred [1]
2/22/2013 - 7:32 PM Replay-window backtrack occurred [2]
2/22/2013 - 7:50 PM Replay-window backtrack occurred [3]
2/22/2013 - 7:50 PM Replay-window backtrack occurred [11]
2/22/2013 - 7:51 PM Replay-window backtrack occurred [13]
2/22/2013 - 7:51 PM Replay-window backtrack occurred [14]
2/22/2013 - 7:51 PM Replay-window backtrack occurred [20]
2/22/2013 - 7:51 PM Replay-window backtrack occurred [21]
2/22/2013 - 7:52 PM Replay-window backtrack occurred [23]
2/22/2013 - 7:53 PM Replay-window backtrack occurred [25]
2/22/2013 - 7:54 PM Replay-window backtrack occurred [27]
2/22/2013 - 7:54 PM Replay-window backtrack occurred [30]
2/22/2013 - 7:57 PM Replay-window backtrack occurred [33]
2/22/2013 - 8:01 PM Replay-window backtrack occurred [34]
2/22/2013 - 8:03 PM Replay-window backtrack occurred [36]
2/22/2013 - 8:04 PM Replay-window backtrack occurred [40]
2/22/2013 - 8:10 PM Replay-window backtrack occurred [49]
2/22/2013 - 8:13 PM Replay-window backtrack occurred [70]
2/22/2013 - 8:13 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760831 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 8:13 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760832 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 8:13 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760833 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 8:13 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760834 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 8:13 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760835 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 8:24 PM TLS: soft reset sec=0 bytes=6998830773/0 pkts=5269201/0
2/22/2013 - 8:24 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2/22/2013 - 8:24 PM VERIFY OK: nsCertType=SERVER
2/22/2013 - 8:24 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2/22/2013 - 8:24 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 8:24 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 8:24 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 8:24 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 8:24 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2/22/2013 - 8:35 PM [server] Inactivity timeout (--ping-restart), restarting
2/22/2013 - 8:35 PM TCP/UDP: Closing socket
2/22/2013 - 8:35 PM Re-connecting...
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.18.173
2/22/2013 - 8:35 PM Route deletion via IPAPI succeeded [adaptive]
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe DELETE 95.211.169.3 MASK 255.255.255.255 192.168.100.2
2/22/2013 - 8:35 PM Warning: route gateway is ambiguous: 192.168.100.2 (2 matches)
2/22/2013 - 8:35 PM Route deletion via IPAPI failed [adaptive]
2/22/2013 - 8:35 PM Route deletion fallback to route.exe
2/22/2013 - 8:35 PM OK!
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.18.173
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.18.173
2/22/2013 - 8:35 PM Closing TUN/TAP interface
2/22/2013 - 8:35 PM SIGUSR1[soft,ping-restart] received, process restarting
2/22/2013 - 8:35 PM Restart pause, 2 second(s)
2/22/2013 - 8:35 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
2/22/2013 - 8:35 PM LZO compression initialized
2/22/2013 - 8:35 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2/22/2013 - 8:35 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
2/22/2013 - 8:35 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2/22/2013 - 8:35 PM Local Options hash (VER=V4): '22188c5b'
2/22/2013 - 8:35 PM Expected Remote Options hash (VER=V4): 'a8f55717'
2/22/2013 - 8:35 PM UDPv4 link local: [undef]
2/22/2013 - 8:35 PM UDPv4 link remote: 95.211.169.3:443
2/22/2013 - 8:35 PM TLS: Initial packet from 95.211.169.3:443, sid=1903e58b d36aed6d
2/22/2013 - 8:35 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2/22/2013 - 8:35 PM VERIFY OK: nsCertType=SERVER
2/22/2013 - 8:35 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2/22/2013 - 8:35 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 8:35 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 8:35 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 8:35 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 8:35 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2/22/2013 - 8:35 PM [server] Peer Connection Initiated with 95.211.169.3:443
2/22/2013 - 8:35 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2/22/2013 - 8:35 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.18.174 10.4.18.173'
2/22/2013 - 8:35 PM OPTIONS IMPORT: timers and/or timeouts modified
2/22/2013 - 8:35 PM OPTIONS IMPORT: LZO parms modified
2/22/2013 - 8:35 PM OPTIONS IMPORT: --ifconfig/up options modified
2/22/2013 - 8:35 PM OPTIONS IMPORT: route options modified
2/22/2013 - 8:35 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2/22/2013 - 8:35 PM ROUTE default_gateway=192.168.100.2
2/22/2013 - 8:35 PM TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{70D0126B-A4A8-49E2-8C88-52B83A9E8BBC}.tap
2/22/2013 - 8:35 PM TAP-Win32 Driver Version 9.9
2/22/2013 - 8:35 PM TAP-Win32 MTU=1500
2/22/2013 - 8:35 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.18.174/255.255.255.252 on interface {70D0126B-A4A8-49E2-8C88-52B83A9E8BBC} [DHCP-serv: 10.4.18.173, lease-time: 31536000]
2/22/2013 - 8:35 PM Successful ARP Flush on interface [16] {70D0126B-A4A8-49E2-8C88-52B83A9E8BBC}
2/22/2013 - 8:35 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe ADD 95.211.169.3 MASK 255.255.255.255 192.168.100.2
2/22/2013 - 8:35 PM Route addition via IPAPI failed [adaptive]
2/22/2013 - 8:35 PM Route addition fallback to route.exe
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.18.173
2/22/2013 - 8:35 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
2/22/2013 - 8:35 PM Route addition via IPAPI succeeded [adaptive]
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.18.173
2/22/2013 - 8:35 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.18.173
2/22/2013 - 8:35 PM Initialization Sequence Completed
2/22/2013 - 8:35 PM Starting Management Interface...
2/22/2013 - 8:35 PM Checking...
2/22/2013 - 8:35 PM Retrieve statistics...
2/22/2013 - 8:35 PM Connected.
2/22/2013 - 9:35 PM TLS: soft reset sec=0 bytes=2467503741/0 pkts=2181994/0
2/22/2013 - 9:35 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2/22/2013 - 9:35 PM VERIFY OK: nsCertType=SERVER
2/22/2013 - 9:35 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2/22/2013 - 9:35 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 9:35 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 9:35 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 9:35 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 9:35 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2/22/2013 - 10:35 PM TLS: tls_process: killed expiring key
2/22/2013 - 10:35 PM TLS: soft reset sec=0 bytes=193211216/0 pkts=336750/0
2/22/2013 - 10:35 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2/22/2013 - 10:35 PM VERIFY OK: nsCertType=SERVER
2/22/2013 - 10:35 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2/22/2013 - 10:35 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 10:35 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 10:35 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2/22/2013 - 10:35 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2/22/2013 - 10:35 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2/22/2013 - 10:36 PM Replay-window backtrack occurred [115]
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3875 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3876 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3879 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3880 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3881 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3882 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3883 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3884 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3885 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3886 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3887 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3889 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3890 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3891 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3892 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3895 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3896 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3897 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3898 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3900 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3901 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3902 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3903 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3904 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3905 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3906 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3907 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
2/22/2013 - 10:36 PM Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
There are various issues on the logs... can you please try to install the latest OpenVPN release (if you have not already done so) and use the 1.8 Air client version, both available here:
https://airvpn.org/windows
If you are already running OpenVPN 2.3.0, please try to uninstall it completely and re-install it, making sure to authorize the installer to install all the drivers.
Also, please test a connection to a TCP port, in order to correct the significant packet replay you're currently experiencing. Finally, test different servers.
Hello Admin,
Thank you for the tip on updating the VPN client, that has seemed to stop the packet replay errors. I ran a TCP test though my ISP and then though the VPN. It found my MTU a little low (around 1400) when connected to the VPN but when direct though ISP it is fine. Is that something i should correct?
Hello Admin,
If you get packet fragmentation yes, you should correct the issue on the client side. If not, you don't need any modification. Please send us again your client connection logs (after some minutes the connection is established) if you still experience packet fragmentation, so that we can suggest you how to optimize the connection.
Just wanted to say I have what sounds like the same thing:
screen: http://i.imgur.com/PPryDak.jpg?1
It manifests as v. high upload traffic straight off after connecting to server. Connection doesn't actually work either...
And CPU hog apparently. (see image).
I'm on Windows 8 if that is relevant. I shall follow the advice given at start of thread and see where I get but just wanted to say "me too" haha
Hello Nos4r2,
Yep that is what my client used to look like, i was using getting a reading of 42k kB/sec.. since i have updated my client i have not seen this issue since. I did not check my task manager maybe it was though the roof.. good looking out!
Can you run through exactly what you did?
I uninstalled Openvpn and then reinstalled it. No difference.
Problem persists on different servers.
I should also state that the upload speeds there are much faster than my connection. false readings - weird
