anwnymos
Port Forwarding > No route to host (113)
Have a working wireguard client AirVPN connection from my host and I set up port forwarding in order to allow incoming connections to a specific port.
When I press "Test open" I get the result: No route to host (113)
I think this error message hasn't anything to do with my setup specifics (open ports, firewall rules etc) but with the fact that the VPN peer I connect to cannot route traffic to the internal allocated address 10.x.x.x.
Am I missing something here?
(I can provide specifics but would prefer not to do it in public)
Actually what you say is plausible, although puzzling. Please try to generate a new key in your AirVPN account "Devices" panel, adjust the "device" linked to the forwarded port accordingly and connect with the new key. Check whether the problem gets resolved or not. The new key will give you a different VPN IP address and this test could provide some clue.
