Brernner
[UNCONFIRMED] Cygni falling
Cygni falling several times why?
maintenance? failures?
put more servers in sweden
Cygni That walketh not reliable
We have not had any failure or interruption of service on Cygni. The server performs very well and the latency times in a 10 countries continuous check are very good. https://airvpn.org/pingmatrix
Swedish infrastructure is largely oversized at the moment, in relation to clients numbers and bandwidth requests.
Any other feedback on Cygni from different premium users?
Hey!
I can't confirm this so far. Connecting from germany, getting good speeds (20 mbit), decent ping (60ms) and no packet loss so far. Seems like everything is working as it should.
That other guy probably has some other issues not related to the server itself.
Some further testing, especially downloading a torrent + watching a stream resulted in significant bandwidth usage with resulted in intermittent packet loss of up to ~25%.
Symptoms were that the stream was lagging and the upload in the torrent client was extremely low/nonexistent during these periods.
I blame the distance from germany to sweden though. It's probably got nothing to do with the server itself.
Also, I was using UDP ...
Hope this helps.
there is certainly something strange going on with cygini
they have a 20 ms bump in their internal network right now
they also route traffic in a strange way
example if you want to send traffic to telia in sweden they route the traffic through frankfurt
Been connected to Cygni all day, doing work on several servers as well as watching Streams and listening to streamed music. No issues whatsoever.
