ego.nymous
Speed issues with Eddie 2.24.6
After updating to the latest version, I can only achieve a tenth of the normal speed - barely 10mb/s. The highest server speed rating is also only 2 stars instead of the usual 5 stars.
I never changed anything in the configuration. Is there anything I need to bear in mind with the new version?
Eddie 2.24.6 connects over WireGuard by default, whereas all the previous stable versions by default launched OpenVPN 2. Please try to set virtual network interface MTU to 1280 bytes. You can do it in Eddie's "Preferences" > "WireGuard" window. Re-start the connection to apply the change and check whether performance improves. If it does not improve, try to go back to OpenVPN. You can do it in Eddie's "Preferences" > "Protocols" window.
Thanks for the quick response. Unfortunately, neither of those worked. I found an old 2.16 version, and the speed is much faster with that one.
Any other advice on what I could try?
KR
KR
Very puzzling, 2.16 uses archaic libraries and OpenVPN versions. Can you tell us your Operating System name and version?
Windows 11, version 24H2
KR
