fawkesguy
Port forwarding for Xbox
I have port forwarding enabled, and it's working for my web server and webcam, but I can't get it setup for Xbox Live. Xbox Live needs port 3074 UDP & TCP opened. I have my AirVPN forwarded port set to UDP & TCP, local port 3074. I've also tried it without setting the local port. Doesn't work either way. I'm also using DNAT. Below is what's in my firewall. The Xbox is 192.168.1.50 I've deleted the entries for the web server and webcam.
iptables -I FORWARD -i br0 -o tun1 -j ACCEPT
iptables -I FORWARD -i tun1 -o br0 -j ACCEPT
iptables -I FORWARD -i br0 -o eth0 -j DROP
iptables -I INPUT -i tun1 -j REJECT
iptables -t nat -A POSTROUTING -o tun1 -j MASQUERADE
iptables -t nat -I PREROUTING -i tun1 -p tcp --dport 2127 -j DNAT --to-destination 192.168.1.50
iptables -t nat -I PREROUTING -i tun1 -p udp --dport 2127 -j DNAT --to-destination 192.168.1.50
Anyone know how I can get Xbox Live running? I'd like to keep the Xbox going through the VPN.
This is a copy & paste of an e-mail from the support team you should have received a few minutes ago, this admins pastes it here for general knowledge:
The rule
might be right or wrong (it depends on your setup) try to delete it for testing purposes (only after you have corrected another rule, see below).
Why the above rules are duplicated? Maybe the Xbox needs UDP packets as well, try to change the second one to:
(note "-p udp" instead of "-p tcp" on the second rule)
AirVPN Support Team
The rule
Is fine. That drops all connections if the VPN goes down. Tested and working.
The 2nd DNAT line is a typo. It is actually correct in my firewall - one line for tcp, one for udp.
Still doesn't work.
Any suggestions?
I have DDWRT setup using assigned IP's via my PS3 MAC address then use the built in OpenVPN policy routing to just route my PS3 outside the VPN. I have no reason to hide my PS3 traffic. Works better outside the VPN anyway. Pretty simple to setup.
Under the Services>Services tab in DDWRT I have a Static Lease for my PS3 MAC address setup so it gets the same IP address every time. Then under the Services>VPN tab I have under "OpenVPN client" in the Policy based Routing box I just plugged in the IP address that I set for the PS3 in the Static Lease table. I checked using the PS3 browser what its IP location was using an IP determining webite. It shows my ISP as being correct and the location being correct proving it is indeed routed outside the VPN.
Found that to be much easier than setting up a routing table.
That would work, except I have the following line in my firewall: "iptables -I FORWARD -i br0 -o eth0 -j DROP" which stops traffic outside of the tunnel from accessing the Internet. I do that so if the VPN goes down, no devices on my network have Internet access. If you know of a way I can maintain that while allowing a single IP to bypass the VPN, that would solve my one remaining issue! If anyone has any ideas, please let me know.
Thanks!
Hi, whats your IPTABLES firewall script for your webserver? im struggling to get any port forwarding working.
This is my current script:
iptables -t nat -I PREROUTING -i tun1 -p tcp --dport 53540 -j DNAT --to-destination 192.168.1.3:4080
iptables -t nat -I PREROUTING -i tun1 -p udp --dport 53540 -j DNAT --to-destination 192.168.1.3:4080
There is a NAS web gui that runs on port 4080 behind my DD-WRT router so it should ALWAYS respond to requests. I can connect to the airVPN just fine. Im sure my script isnt right somewhere.
Help!!!
im also trying with an xbox but im unsure as to why its not working i forwarded the local ports and in my firewall and a rule to allow incoming and outgoing connections for the port they generate but i still have nat error when testing
