abirato
port forwarding
I can't get port forwarding working, whether connected to airvpn or not. Does airvpn change anything in windows7 install to block my forwarding?
The Air client is portable, it is not installed in the system. OpenVPN installation does not change anything pertaining to port forwarding.
If you could be more specific, we should be able to provide you with additional support.
