Supersat 0 Posted ... Hi all i have a few questions, i want to order Air Vpn but before i do that i have a few questions 1:When i install Airvpn and Utorrent will it work, did some reading about forwarding port on the web site when i do that will i still be anonymous? 2:i have a fiber 100/100 home conection in the netherlands what speed can i espect? 3:you dont keep any logfiles, so if there is a courtorder there is nothing to handover? 4:i want to install Air vpn on one download pc in my network the rest of the computers wont use air vpn is this possible, and can is sill use external desktop conection in the same network 5: did some reading about ip leaking how can i prevent that or is this done by the program? thanx your service looks great hope that i got some positive feedback so i can order soon. Supersat, Quote Share this post Link to post
GoXRUTD7k8FfZp5jmvNK4uE6 7 Posted ... 1. https://airvpn.org/faq/#p2p + https://airvpn.org/faq/#port_forwarding4. Only devices running the VPN will have their traffic tunnelled through the secure connection. You can't run AirVPN simultaneously on more than one device at a time unless you pay for an upgrade. All other computers can function normally.5. https://airvpn.org/faq/#prevent_leaks + http://www.dnsleaktest.com/ + http://checkmytorrentip.com/ +You should set firewall rules to prevent leaks in case of unexpected VPN disconnection. This is the safest solution. We don't recommend different solutions, due to security reasons. Read the FAQ then choose the relevant forum guide. Quote Share this post Link to post
Staff 10427 Posted ... 2:i have a fiber 100/100 home conection in the netherlands what speed can i espect?Please see here:https://airvpn.org/faq#speed3:you dont keep any logfiles, so if there is a courtorder there is nothing to handover?Correct.4:i want to install Air vpn on one download pc in my network the rest of the computers wont use air vpn is this possible, and can is sill use external desktop conection in the same networkYes, it is possible, and yes, you can use external desktop connection in the same network.Kind regards Quote Share this post Link to post
