mordants 5 Posted ... Setting up a FTP I am trying to setup a FTP Server so I can access it via AIRVPN I can access it locally via 192.168.1.x (locally from another pc) But when I try to access it via Airvpn IP Address it won't connect I did a forward Port using your website and opened a Port. Normally ftp is 21, but I changed that to something else. The Port I want to use, I added it to my comodo firewall as TCP/UDP so when I now try to connect to our ip address like 95.xx.xx.xx.xx port YYYY (what i setup) it won't work Any tips or suggestion? Quote Share this post Link to post
Staff 10427 Posted ... Hello! Configuring an FTP server behind our NAT is not complex but requires some care, please read here: https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1700&Itemid=142#1702 Kind regards Quote Share this post Link to post
