qwortz
allowprivatenetwork only allows from Class A to Class A, B to B and C to C
hi,
I am using bluetit with allowprivatenetwork=yes. In nft this creates the Input rules, with according Output rules:
              ip saddr 192.168.0.0/16 ip daddr 192.168.0.0/16 counter packets 4359261 bytes 100522180956 accept
              ip saddr 169.254.0.0/16 ip daddr 169.254.0.0/16 counter packets 0 bytes 0 accept
              ip saddr 10.0.0.0/8 ip daddr 10.0.0.0/8 counter packets 1101 bytes 115928 accept
              ip saddr 172.16.0.0/12 ip daddr 172.16.0.0/12 counter packets 0 bytes 0 accept
but I am coming from a vpn-endpoint on 10.0.0.0/8 and cant login to my server on the 192.168.0.0/16 with those rules.
Could you please allow connections from all private LANs to all private LANs? Fixing this with scripts in the systemd-unitfile is a bit annoying.
@qwortz
Well, allowing IP forwarding between different subnets could be deemed as beyond the scope of the allowprivatenetwork directive and could be criticized as a source of hazard. We will consider the matter carefully.
But you allow IP forwarding from every i.e. 10.x.x.x  subnet to any other. The classes are just numbers and have no technical differentiation, I think enforcing this arbitrary seperation has no technical value (imo :) )
I see that the setting is supposed to allow local access (i.e. home network to a NAS)  by defining that you only have i.e. 192.168.x.x subnets in your "household", but this seems like an assumption on your part that does not add security. RFC1918 networks are not routed to the internet automatically, so allowing clients to connect to them does not bring any risks that they don´t have with your assumptions.
Edited ... by qwortz
more arguments
ideal would be allowing people to input an array of my home networks and allow sending between those. this would be more defined than the current way, more "secure" and flexible.
No, do not get confused by the VPN subnet on the virtual interface. Thank you for your suggestions, they will be considered.
you take the one detail that is mistunderstandable (I ment any 10.x to any other 10.x via the "ip saddr 10.0.0.0/8 ip daddr 10.0.0.0/8 accept" rule).
don´t get me wrong, thanks for your answer, but this sounds like a shut up and we won´t 🤐.
Hope you still got my points :)
Thanks for the service!
