Greyzy 1 Posted ... Hello, I have problems loggin in to certain servers. On startup I have OpenVPN log into Ophiuchi and that's usually working. But when I log off and then try to log into other servers (using OpenVPN) I only get a connection to a few of them. Some others don't work. I setup COMODO and OpenVPN according to the info I found here, but I must admit that I am not familiar with the specifics of the whole connection topic, so please help me as detailed as you can (or ask questions as specific as possible). I am running WIN7-Ultimate (64 bit) with SP1. I also run COMODO, Malawarebyte's AntiMalware and MS Essentials. Following is a log of what shows up in the OpenVPN window (I inserted the lines with the server names). Please let me know if you need more information (and how I need to proceed to get it for you). Thanks a lot, Greyzy >>> START OF LOG <<< ==================== Orionis - UDP 443 ==================== Fri Jan 25 08:19:49 2013 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Fri Jan 25 08:19:49 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Fri Jan 25 08:19:50 2013 LZO compression initialized Fri Jan 25 08:19:50 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Fri Jan 25 08:19:50 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Fri Jan 25 08:19:50 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Fri Jan 25 08:19:50 2013 Local Options hash (VER=V4): '22188c5b' Fri Jan 25 08:19:50 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Fri Jan 25 08:19:50 2013 UDPv4 link local: [undef] Fri Jan 25 08:19:50 2013 UDPv4 link remote: 95.211.98.154:443 Fri Jan 25 08:20:50 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Fri Jan 25 08:20:50 2013 TLS Error: TLS handshake failed Fri Jan 25 08:20:50 2013 TCP/UDP: Closing socket Fri Jan 25 08:20:50 2013 SIGUSR1[soft,tls-error] received, process restarting Fri Jan 25 08:20:50 2013 Restart pause, 2 second(s) Fri Jan 25 08:20:52 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Fri Jan 25 08:20:52 2013 LZO compression initialized Fri Jan 25 08:20:52 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Fri Jan 25 08:20:52 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Fri Jan 25 08:20:52 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Fri Jan 25 08:20:52 2013 Local Options hash (VER=V4): '22188c5b' Fri Jan 25 08:20:52 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Fri Jan 25 08:20:52 2013 UDPv4 link local: [undef] Fri Jan 25 08:20:52 2013 UDPv4 link remote: 95.211.98.154:443 ====================== Cassiopeia - UDP 443 ====================== Fri Jan 25 08:22:20 2013 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Fri Jan 25 08:22:20 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Fri Jan 25 08:22:20 2013 LZO compression initialized Fri Jan 25 08:22:20 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Fri Jan 25 08:22:20 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Fri Jan 25 08:22:20 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Fri Jan 25 08:22:20 2013 Local Options hash (VER=V4): '22188c5b' Fri Jan 25 08:22:20 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Fri Jan 25 08:22:20 2013 UDPv4 link local: [undef] Fri Jan 25 08:22:20 2013 UDPv4 link remote: 31.193.12.98:443 Fri Jan 25 08:23:20 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Fri Jan 25 08:23:20 2013 TLS Error: TLS handshake failed Fri Jan 25 08:23:20 2013 TCP/UDP: Closing socket Fri Jan 25 08:23:20 2013 SIGUSR1[soft,tls-error] received, process restarting Fri Jan 25 08:23:20 2013 Restart pause, 2 second(s) Fri Jan 25 08:23:22 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Fri Jan 25 08:23:22 2013 LZO compression initialized Fri Jan 25 08:23:22 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Fri Jan 25 08:23:22 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Fri Jan 25 08:23:22 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Fri Jan 25 08:23:22 2013 Local Options hash (VER=V4): '22188c5b' Fri Jan 25 08:23:22 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Fri Jan 25 08:23:22 2013 UDPv4 link local: [undef] Fri Jan 25 08:23:22 2013 UDPv4 link remote: 31.193.12.98:443 >>> END OF LOG <<< Quote Share this post Link to post
Staff 10717 Posted ... Hello,I have problems loggin in to certain servers. On startup I have OpenVPN log into Ophiuchi and that's usually working. But when I log off and then try to log into other servers (using OpenVPN) I only get a connection to a few of them. Some others don't work.I setup COMODO and OpenVPN according to the info I found here, but I must admit that I am not familiar with the specifics of the whole connection topic, so please help me as detailed as you can (or ask questions as specific as possible).I am running WIN7-Ultimate (64 bit) with SP1. I also run COMODO, Malawarebyte's AntiMalware and MS Essentials.Hello!Something is blocking UDP packets to some of our servers. It may be Malwarebytes, which is known to block indiscriminately thousands of IP addresses (including the IP address of our main frontend), please try to disable it and re-test the connections.Kind regards Quote Share this post Link to post
Greyzy 1 Posted ... I will give it a try, but I had "blocking of websites" in Anti-Malware set to "OFF". In another post I read something about not getting logged off properly so that the next server thinks I am still logged in at another server. Could that have something to do with my problem? Thanks! Quote Share this post Link to post
Staff 10717 Posted ... I will give it a try, but I had "blocking of websites" in Anti-Malware set to "OFF".In another post I read something about not getting logged off properly so that the next server thinks I am still logged in at another server. Could that have something to do with my problem?Thanks!Hello!No, it's unrelated. In that case you would notice an AUTH_FAILED message in the logs. Your logs, on the contrary, show that the UDP packets don't even get out of your device. If it's not Malwarebytes, there must be something else blocking them in your machine. Please note that switching Blocking websites to OFF might not be sufficient (it depends on what Malwarebytes means for blocking websites), because here we see an IP block.Kind regards Quote Share this post Link to post
Greyzy 1 Posted ... Hi, the problem occurred again. I was connected to one server. Then I wanted to switch to another one, so I disconnected and then tried to connect to the next one. This didn't work. I then terminated AntiMalware and also switched off Microsoft Security Essentials. After that I tried to connect to the server again, but no success. The second one didn't work either. Only the third one (Aquiliae) worked. I hope the following log helps: >>> START OF LOG <<< ======================= Orionis - UDP 443 ======================= Sat Jan 26 13:54:06 2013 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Sat Jan 26 13:54:06 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sat Jan 26 13:54:06 2013 LZO compression initialized Sat Jan 26 13:54:06 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Sat Jan 26 13:54:06 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Sat Jan 26 13:54:06 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Sat Jan 26 13:54:06 2013 Local Options hash (VER=V4): '22188c5b' Sat Jan 26 13:54:06 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Sat Jan 26 13:54:06 2013 UDPv4 link local: [undef] Sat Jan 26 13:54:06 2013 UDPv4 link remote: 95.211.98.154:443 Sat Jan 26 13:55:06 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Sat Jan 26 13:55:06 2013 TLS Error: TLS handshake failed Sat Jan 26 13:55:06 2013 TCP/UDP: Closing socket Sat Jan 26 13:55:06 2013 SIGUSR1[soft,tls-error] received, process restarting Sat Jan 26 13:55:06 2013 Restart pause, 2 second(s) Sat Jan 26 13:55:08 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sat Jan 26 13:55:08 2013 LZO compression initialized Sat Jan 26 13:55:08 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Sat Jan 26 13:55:08 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Sat Jan 26 13:55:08 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Sat Jan 26 13:55:08 2013 Local Options hash (VER=V4): '22188c5b' Sat Jan 26 13:55:08 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Sat Jan 26 13:55:08 2013 UDPv4 link local: [undef] Sat Jan 26 13:55:08 2013 UDPv4 link remote: 95.211.98.154:443 ======================= Cassiopeia - UDP 443 ======================= Sat Jan 26 13:56:10 2013 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Sat Jan 26 13:56:10 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sat Jan 26 13:56:11 2013 LZO compression initialized Sat Jan 26 13:56:11 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Sat Jan 26 13:56:11 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Sat Jan 26 13:56:11 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Sat Jan 26 13:56:11 2013 Local Options hash (VER=V4): '22188c5b' Sat Jan 26 13:56:11 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Sat Jan 26 13:56:11 2013 UDPv4 link local: [undef] Sat Jan 26 13:56:11 2013 UDPv4 link remote: 31.193.12.98:443 Sat Jan 26 13:57:11 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Sat Jan 26 13:57:11 2013 TLS Error: TLS handshake failed Sat Jan 26 13:57:11 2013 TCP/UDP: Closing socket Sat Jan 26 13:57:11 2013 SIGUSR1[soft,tls-error] received, process restarting Sat Jan 26 13:57:11 2013 Restart pause, 2 second(s) Sat Jan 26 13:57:13 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sat Jan 26 13:57:13 2013 LZO compression initialized Sat Jan 26 13:57:13 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Sat Jan 26 13:57:13 2013 Socket Buffers: R=[8192->8192] S=[8192->8192] Sat Jan 26 13:57:13 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Sat Jan 26 13:57:13 2013 Local Options hash (VER=V4): '22188c5b' Sat Jan 26 13:57:13 2013 Expected Remote Options hash (VER=V4): 'a8f55717' Sat Jan 26 13:57:13 2013 UDPv4 link local: [undef] Sat Jan 26 13:57:13 2013 UDPv4 link remote: 31.193.12.98:443 >>> END OF LOG <<< In case I need to verify or change any setting on my PC then please let me know where exactly. Other than COMODO I am not aware of any other program that might interfere with the connection. Would a screenshot of the task manager help in any way (if so, which tabs)? Thanks, Greyzy Quote Share this post Link to post
Staff 10717 Posted ... Hello! Yes, that confirms what you were told, unfortunately there's something in your machine that blocks UDP packets toward some IP addresses. Until you don't find the "guilty" program you will always have the problem. Try to boot with a minimal setup, no third-party programs etc., and try UDP connections. Then start re-enabling your programs one by one, each time trying an UDP connection, until you find the responsible one. Kind regards Quote Share this post Link to post
