Markjones 0 Posted ... hello 01 Close the program window it disconnects to disable this? 02 or have some protection to disable the vpn in accidents? 03 It Is Possible to join a server with 100% or drops the connection? 04 What program do you recommend shutdown thanks Quote Share this post Link to post
Staff 10432 Posted ... hello01 Close the program window it disconnects to disable this?Hello!You must keep OpenVPN running (or the Air client running) to keep the connection, there's no alternative.02 or have some protectionto disable the vpn in accidents?Of course! Can you tell us your OS (solutions vary according to systems)?03 It Is Possible to join a server with 100%or drops the connection?It is possible. We have evaluated a system which rejects connections if a server is at capacity, but all in all we currently prefer to leave total freedom to our users choices.04 What program do you recommend shutdownCan you please elaborate (this admin does not understand the question)?Kind regards Quote Share this post Link to post
Markjones 0 Posted ... hi i use windows seven Which use protection? Quote Share this post Link to post
Staff 10432 Posted ... hi i use windows seven Which use protection?Hello!This is probably what you're looking for:https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=3405&Itemid=142If your question has been misunderstood please do not hesitate to contact us again.Kind regards Quote Share this post Link to post
