Hello guys.
My setup is like this on openwrt:
My torrenting Interface -> Policy Based Routing -> Wireguard interface
Then I have a port forward set to redirect connections in TCP and UDP from my torrenting port (forwarded on airvpn) to my local qbitorrent mashine.
In general this setup works fine, though for some reason it SOMETIMES switches the IP address to some random country that isnt even owned by airvpn (from whois info). This makes no sense since i have only one peer configured that is to a single airvpn server.
Does anyone have any idea how to fix this? I have problems with my private tracker since they see this secondary Ip address and on that one port forwarding isnt enabled for some reason.
If the private tracker IP address ended inside some geo-routing for whatever reason (accessibility, or because it is inside some address block that necessitates geo-routing) this behavior would get an explanation. Please disable geo-routing on your AirVPN account DNS panel by switching "AirVPN anti-geolocation system" combo box to "Not active", start a new connection and verify whether the problem disappears or not.
Thank you very much. I think this fixed my problem!
have a great day and again thank you for the great and quick support!!
