sunnymorning
recently getting connection dropouts aka softresets every hour !
01/21/2013 - 7:59 AM Route: Waiting for TUN/TAP interface to come up...
01/21/2013 - 7:59 AM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
01/21/2013 - 8:00 AM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
01/21/2013 - 8:00 AM Route: Waiting for TUN/TAP interface to come up...
01/21/2013 - 8:00 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
01/21/2013 - 8:00 AM C:\Windows\system32\route.exe ADD 94.185.85.170 MASK 255.255.255.255 195.142.43.69
01/21/2013 - 8:00 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
01/21/2013 - 8:00 AM Route addition via IPAPI succeeded [adaptive]
01/21/2013 - 8:00 AM C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.6.37
01/21/2013 - 8:00 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
01/21/2013 - 8:00 AM C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.6.37
01/21/2013 - 8:00 AM C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.6.37
01/21/2013 - 8:00 AM Initialization Sequence Completed
01/21/2013 - 8:00 AM Starting Management Interface...
01/21/2013 - 8:00 AM Checking...
01/21/2013 - 8:00 AM Retrieve statistics...
01/21/2013 - 8:00 AM Connected.
01/21/2013 - 8:01 AM Disconnecting...
01/21/2013 - 8:01 AM SIGTERM received, sending exit notification to peer
01/21/2013 - 8:01 AM C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.6.37
01/21/2013 - 8:01 AM Route deletion via IPAPI succeeded [adaptive]
01/21/2013 - 8:01 AM C:\Windows\system32\route.exe DELETE 94.185.85.170 MASK 255.255.255.255 195.142.43.69
01/21/2013 - 8:01 AM C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.6.37
01/21/2013 - 8:01 AM C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.6.37
01/21/2013 - 8:01 AM Closing TUN/TAP interface
01/21/2013 - 8:01 AM SIGTERM[hard,] received, process exiting
01/21/2013 - 8:01 AM Disconnected.
01/21/2013 - 8:01 AM Login...
01/21/2013 - 8:01 AM Unable to connect to the remote server
01/21/2013 - 8:02 AM Login...
01/21/2013 - 8:02 AM Login success.
01/21/2013 - 8:02 AM Contacting service...
01/21/2013 - 8:02 AM Connecting...
01/21/2013 - 8:02 AM OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
01/21/2013 - 8:02 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
01/21/2013 - 8:02 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
01/21/2013 - 8:02 AM UDPv4 link local: [undef]
01/21/2013 - 8:02 AM UDPv4 link remote: [AF_INET]178.248.30.131:443
01/21/2013 - 8:02 AM TLS: Initial packet from [AF_INET]178.248.30.131:443, sid=dc5c18ae 88d1849d
01/21/2013 - 8:02 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
01/21/2013 - 8:02 AM VERIFY OK: nsCertType=SERVER
01/21/2013 - 8:02 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
01/21/2013 - 8:02 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 8:02 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 8:02 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 8:02 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 8:02 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
01/21/2013 - 8:02 AM [server] Peer Connection Initiated with [AF_INET]178.248.30.131:443
01/21/2013 - 8:02 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
01/21/2013 - 8:02 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.3.150 10.4.3.149'
01/21/2013 - 8:02 AM OPTIONS IMPORT: timers and/or timeouts modified
01/21/2013 - 8:02 AM OPTIONS IMPORT: LZO parms modified
01/21/2013 - 8:02 AM OPTIONS IMPORT: --ifconfig/up options modified
01/21/2013 - 8:02 AM OPTIONS IMPORT: route options modified
01/21/2013 - 8:02 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
01/21/2013 - 8:02 AM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
01/21/2013 - 8:02 AM open_tun, tt->ipv6=0
01/21/2013 - 8:02 AM TAP-WIN32 device [AirVpn or Mullvad] opened: \\.\Global\{FA782FAD-72D8-4DC0-A2F3-6500F671DD0D}.tap
01/21/2013 - 8:02 AM TAP-Windows Driver Version 9.9
01/21/2013 - 8:02 AM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.150/255.255.255.252 on interface {FA782FAD-72D8-4DC0-A2F3-6500F671DD0D} [DHCP-serv: 10.4.3.149, lease-time: 31536000]
01/21/2013 - 8:02 AM Successful ARP Flush on interface [17] {FA782FAD-72D8-4DC0-A2F3-6500F671DD0D}
01/21/2013 - 8:02 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
01/21/2013 - 8:02 AM C:\Windows\system32\route.exe ADD 178.248.30.131 MASK 255.255.255.255 195.142.43.69
01/21/2013 - 8:02 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
01/21/2013 - 8:02 AM Route addition via IPAPI succeeded [adaptive]
01/21/2013 - 8:02 AM C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.149
01/21/2013 - 8:02 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
01/21/2013 - 8:02 AM C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.149
01/21/2013 - 8:02 AM C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.149
01/21/2013 - 8:02 AM Initialization Sequence Completed
01/21/2013 - 8:02 AM Starting Management Interface...
01/21/2013 - 8:02 AM Checking...
01/21/2013 - 8:03 AM Retrieve statistics...
01/21/2013 - 8:03 AM Connected.
01/21/2013 - 9:02 AM TLS: soft reset sec=0 bytes=319280059/0 pkts=344460/0
01/21/2013 - 9:02 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
01/21/2013 - 9:02 AM VERIFY OK: nsCertType=SERVER
01/21/2013 - 9:02 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
01/21/2013 - 9:02 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 9:02 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 9:02 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 9:02 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 9:02 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
01/21/2013 - 9:48 AM [server] Inactivity timeout (--ping-restart), restarting
01/21/2013 - 9:48 AM C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.3.149
01/21/2013 - 9:48 AM Route deletion via IPAPI succeeded [adaptive]
01/21/2013 - 9:48 AM C:\Windows\system32\route.exe DELETE 178.248.30.131 MASK 255.255.255.255 195.142.43.69
01/21/2013 - 9:48 AM C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.3.149
01/21/2013 - 9:48 AM C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.3.149
01/21/2013 - 9:48 AM Closing TUN/TAP interface
01/21/2013 - 9:48 AM SIGUSR1[soft,ping-restart] received, process restarting
01/21/2013 - 9:48 AM Restart pause, 2 second(s)
01/21/2013 - 9:48 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
01/21/2013 - 9:48 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
01/21/2013 - 9:48 AM UDPv4 link local: [undef]
01/21/2013 - 9:48 AM UDPv4 link remote: [AF_INET]178.248.30.131:443
01/21/2013 - 9:48 AM TLS: Initial packet from [AF_INET]178.248.30.131:443, sid=5b382041 62372b5f
01/21/2013 - 9:48 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
01/21/2013 - 9:48 AM VERIFY OK: nsCertType=SERVER
01/21/2013 - 9:48 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
01/21/2013 - 9:49 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 9:49 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 9:49 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 9:49 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 9:49 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
01/21/2013 - 9:49 AM [server] Peer Connection Initiated with [AF_INET]178.248.30.131:443
01/21/2013 - 9:49 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
01/21/2013 - 9:49 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.3.150 10.4.3.149'
01/21/2013 - 9:49 AM OPTIONS IMPORT: timers and/or timeouts modified
01/21/2013 - 9:49 AM OPTIONS IMPORT: LZO parms modified
01/21/2013 - 9:49 AM OPTIONS IMPORT: --ifconfig/up options modified
01/21/2013 - 9:49 AM OPTIONS IMPORT: route options modified
01/21/2013 - 9:49 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
01/21/2013 - 9:49 AM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
01/21/2013 - 9:49 AM open_tun, tt->ipv6=0
01/21/2013 - 9:49 AM TAP-WIN32 device [AirVpn or Mullvad] opened: \\.\Global\{FA782FAD-72D8-4DC0-A2F3-6500F671DD0D}.tap
01/21/2013 - 9:49 AM TAP-Windows Driver Version 9.9
01/21/2013 - 9:49 AM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.150/255.255.255.252 on interface {FA782FAD-72D8-4DC0-A2F3-6500F671DD0D} [DHCP-serv: 10.4.3.149, lease-time: 31536000]
01/21/2013 - 9:49 AM Successful ARP Flush on interface [17] {FA782FAD-72D8-4DC0-A2F3-6500F671DD0D}
01/21/2013 - 9:49 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
01/21/2013 - 9:49 AM C:\Windows\system32\route.exe ADD 178.248.30.131 MASK 255.255.255.255 195.142.43.69
01/21/2013 - 9:49 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
01/21/2013 - 9:49 AM Route addition via IPAPI succeeded [adaptive]
01/21/2013 - 9:49 AM C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.149
01/21/2013 - 9:49 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
01/21/2013 - 9:49 AM C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.149
01/21/2013 - 9:49 AM C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.149
01/21/2013 - 9:49 AM Initialization Sequence Completed
01/21/2013 - 9:49 AM Starting Management Interface...
01/21/2013 - 9:49 AM Checking...
01/21/2013 - 9:49 AM Retrieve statistics...
01/21/2013 - 9:49 AM Connected.
01/21/2013 - 10:49 AM TLS: soft reset sec=0 bytes=43043030/0 pkts=58037/0
01/21/2013 - 10:49 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
01/21/2013 - 10:49 AM VERIFY OK: nsCertType=SERVER
01/21/2013 - 10:49 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
01/21/2013 - 10:49 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 10:49 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 10:49 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
01/21/2013 - 10:49 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
01/21/2013 - 10:49 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
what is going on this has been going like this for the last couple of days
Every hour the TLS key is renegotiated for additional security. During SSL/TLS rekeying, there is a transition-window parameter that permits overlap between old and new key usage, so there is no time pressure or latency bottleneck during SSL/TLS renegotiations (and the tunnel is never broken).
http://openvpn.net/index.php/open-source/documentation/security-overview.html
That said, your logs show two problems: in one case, the TUN/TAP interface did not come up properly. If this problem persists (but in the remaining part of the logs the problem does not occur anymore), it is recommended that you uninstall OpenVPN and you install the new OpenVPN 2.3.0 (see https://airvpn.org/windows to update the Air client as well). Upgrade to new client 1.8 and OpenVPN 2.3.0 is highly recommended if you run Windows 8.
The second problem is showed in the following log line:
which suggests a momentary connection drop from your ISP or (unlikely, unless you live in a human rights hostile country) an active disruption of OpenVPN connection.
im already using your latest 1.8 airvpn client before i removed the old 1.7 , as you can see from the connection logs as it shows the new openvpn version
thanks for clearing that up btw, ill let you know if i notice any connection dropouts and post the airvpn log then again , just making sure everythings ok , nice to see your working on the client software
Very well. Don't forget that a TLS soft reset is not a connection dropout and does not slow down your connection in any way, on the contrary it's a good security feature (you can disable it or change the soft reset time period, but we strongly recommend you keep it enabled and not higher than 60 minutes).
