b0n
ANSWERED New User: WireGuard > Error: Failed to start: not running
I decided to move over to AirVPN from Nord because of consistent and constant issues.
I installed Eddie, I have WireGuard installed.
I am unable to connect to ANY server, as I see the issue "WireGuard > Error: Failed to start: not running"
I have looked for the same error, only to find a single post with no responses from 2023.
https://airvpn.org/forums/topic/56687-wireguard-error-failed-to-start-not-running/
I have tried different protocols, allowing v4 & v6, read the FAQ, read LZ1's "Guide To Getting Started + Links For Advanced Users" and done due diligence checking other posts.
To clarify: I also was unable to connect via OpenVPN options, however that would be a different topic.
I would appreciate any assistance.
I 2025.03.31 10:28:48 - Session starting.
I 2025.03.31 10:28:49 - Checking authorization ...
. 2025.03.31 10:28:49 - IPv6 disabled with packet filtering.
! 2025.03.31 10:28:49 - Connecting to Paikauhale (United States of America, New York City)
. 2025.03.31 10:28:49 - Routes, add 198.44.136.254/32 for interface "Ethernet 6".
. 2025.03.31 10:28:49 - WireGuard > Setup start
E 2025.03.31 10:29:00 - WireGuard > Error: Failed to start: not running
. 2025.03.31 10:29:00 - WireGuard > Stopping
. 2025.03.31 10:29:00 - WireGuard > Completed
! 2025.03.31 10:29:00 - Disconnecting
. 2025.03.31 10:29:00 - Routes, delete 198.44.136.254/32 for interface "Ethernet 6".
. 2025.03.31 10:29:00 - Routes, skipped for 2607:9000:a000:28:c238:f61e:8b51:165b : IPv6 blocked.
. 2025.03.31 10:29:00 - IPv6 restored with packet filtering.
. 2025.03.31 10:29:00 - Collect network information
. 2025.03.31 10:29:01 - Connection terminated.
I 2025.03.31 10:29:04 - Checking authorization ...
. 2025.03.31 10:29:04 - IPv6 disabled with packet filtering.
! 2025.03.31 10:29:04 - Connecting to Unukalhai (United States of America, New York City)
. 2025.03.31 10:29:04 - Routes, add 198.44.136.246/32 for interface "Ethernet 6".
. 2025.03.31 10:29:04 - WireGuard > Setup start
E 2025.03.31 10:29:15 - WireGuard > Error: Failed to start: not running
. 2025.03.31 10:29:15 - WireGuard > Stopping
. 2025.03.31 10:29:15 - WireGuard > Completed
! 2025.03.31 10:29:15 - Disconnecting
. 2025.03.31 10:29:15 - Routes, delete 198.44.136.246/32 for interface "Ethernet 6".
. 2025.03.31 10:29:15 - Routes, skipped for 2607:9000:a000:27:6c15:311d:d436:7a5f : IPv6 blocked.
. 2025.03.31 10:29:15 - IPv6 restored with packet filtering.
. 2025.03.31 10:29:15 - Collect network information
. 2025.03.31 10:29:16 - Connection terminated.
I 2025.03.31 10:29:19 - Checking authorization ...
. 2025.03.31 10:29:19 - IPv6 disabled with packet filtering.
! 2025.03.31 10:29:19 - Connecting to Muliphein (United States of America, New York City)
. 2025.03.31 10:29:19 - Routes, add 198.44.136.238/32 for interface "Ethernet 6".
. 2025.03.31 10:29:19 - WireGuard > Setup start
! 2025.03.31 10:29:19 - Disconnecting
E 2025.03.31 10:29:30 - WireGuard > Error: Failed to start: not running
. 2025.03.31 10:29:30 - WireGuard > Stopping
. 2025.03.31 10:29:30 - WireGuard > Completed
. 2025.03.31 10:29:30 - Routes, delete 198.44.136.238/32 for interface "Ethernet 6".
. 2025.03.31 10:29:30 - Routes, skipped for 2607:9000:a000:26:61c7:6339:c4d1:e618 : IPv6 blocked.
. 2025.03.31 10:29:30 - IPv6 restored with packet filtering.
. 2025.03.31 10:29:30 - Collect network information
. 2025.03.31 10:29:30 - Connection terminated.
I 2025.03.31 10:29:30 - Cancel requested.
! 2025.03.31 10:29:30 - Session terminated.
Edited ... by b0n
Clarity / More information
Same issue. I also come from nord as well.
I may try a VM soon with no vpn ever previously installed. Will report back if i hear anything back from support, or if the VM connection worked.
. 2025.04.04 18:55:24 - Eddie version: 2.24.6 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: 10.0.19045.0, Framework: v4.0.30319
. 2025.04.04 18:55:24 - Command line arguments (1): path="home"
. 2025.04.04 18:55:24 - Collect network information
. 2025.04.04 18:55:25 - Reading options from C:\Users\Administrator\AppData\Local\Eddie\default.profile
. 2025.04.04 18:55:26 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.1 4 Jun 2024, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2025.04.04 18:55:26 - SSH - Version: OpenSSH_for_Windows_8.1p1, LibreSSL 3.0.2 (C:\Windows\System32\OpenSSH\\ssh.exe)
. 2025.04.04 18:55:26 - SSL - Version: 5.69 (C:\Program Files\AirVPN\stunnel.exe)
I 2025.04.04 18:55:26 - Ready
. 2025.04.04 18:55:28 - Collect information about AirVPN completed
I 2025.04.04 18:55:48 - Checking login ...
! 2025.04.04 18:55:49 - Logged in.
I 2025.04.04 18:55:50 - Session starting.
. 2025.04.04 18:55:51 - Activation of Network Lock - Windows Filtering Platform
. 2025.04.04 18:55:51 - Waiting for latency tests (2 to go)
I 2025.04.04 18:55:53 - Checking authorization ...
! 2025.04.04 18:55:54 - Connecting to Guniibuu (United States of America, Phoenix, Arizona)
. 2025.04.04 18:55:54 - Routes, add 198.44.133.70/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 18:55:55 - WireGuard > Setup start
E 2025.04.04 18:56:06 - WireGuard > Error: Failed to start: not running
. 2025.04.04 18:56:06 - WireGuard > Stopping
! 2025.04.04 18:56:06 - Disconnecting
. 2025.04.04 18:56:10 - WireGuard > Completed
. 2025.04.04 18:56:11 - Routes, delete 198.44.133.70/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 18:56:11 - Collect network information
. 2025.04.04 18:56:11 - Connection terminated.
I 2025.04.04 18:56:14 - Checking authorization ...
! 2025.04.04 18:56:15 - Connecting to Xamidimura (United States of America, Los Angeles)
. 2025.04.04 18:56:15 - Routes, add 198.54.129.46/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 18:56:16 - WireGuard > Setup start
E 2025.04.04 18:56:27 - WireGuard > Error: Failed to start: not running
. 2025.04.04 18:56:27 - WireGuard > Stopping
! 2025.04.04 18:56:27 - Disconnecting
. 2025.04.04 18:56:31 - WireGuard > Completed
. 2025.04.04 18:56:32 - Routes, delete 198.54.129.46/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 18:56:32 - Collect network information
. 2025.04.04 18:56:32 - Connection terminated.
I 2025.04.04 18:56:35 - Checking authorization ...
! 2025.04.04 18:56:36 - Connecting to Sarin (United States of America, Los Angeles)
. 2025.04.04 18:56:36 - Routes, add 198.54.129.62/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 18:56:37 - WireGuard > Setup start
! 2025.04.04 18:56:39 - Disconnecting
E 2025.04.04 18:56:48 - WireGuard > Error: Failed to start: not running
. 2025.04.04 18:56:48 - WireGuard > Stopping
. 2025.04.04 18:56:52 - WireGuard > Completed
. 2025.04.04 18:56:53 - Routes, delete 198.54.129.62/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 18:56:53 - Collect network information
. 2025.04.04 18:56:53 - Connection terminated.
I 2025.04.04 18:56:53 - Cancel requested.
. 2025.04.04 18:56:53 - Deactivation of Network Lock
! 2025.04.04 18:56:53 - Session terminated.
I also encountered this issue, but fortunately, I resolved it. I found that it's related to a system driver problem. For WireGuard to run, it requires the `wireguard.sys` driver. However, Eddie does not create `wireguard.sys` when there are other versions of `wintun.sys` in the system folder, which causes it to fail—quite strange.
The solution is to delete all `wintun.sys` and `wireguard.sys` files in the `C:\windows\system32\drivers\` directory, then use a cleanup tool to scan the registry. After restarting your computer, open Eddie, first select the WireGuard protocol (port 51820) to connect to the server, and then switch to the OpenVPN protocol to connect again. This ensures both drivers are installed correctly.
In Eddie 2.24.6, WireGuard uses `wireguard.sys`, while OpenVPN uses `wintun.sys`. Hope this helps you solve the problem!
@b0n
On top of the previous excellent answer by @EMULE (thank you, we'll examine your analysis to improve the software) please make sure that any Radmin Famatech related software is NOT running when you run Eddie. Also consider to disable this interface:
Quote
when you want to use AirVPN.
Same problem here, but... I can't delete the file, it requires trustedinstaller permission... no solution works, I'm running Windows 10 Home... it can be a limitation from the system, i'm not running the pro version....
