IsraSamuelsson 0 Posted ... is possible to use another company pptp + open vpn you? without shutting down the PPTP? why some pptp VPNs usually most "famous" companies that save logs pptp shutting .... would be to save the original ip? do you have any doors closed on your servers? thank you Quote Share this post Link to post
Staff 10478 Posted ... is possible to use another company pptp + open vpn you?without shutting down the PPTP?Hello!PPTP uses a control channel over TCP and a GRE tunnel operating to encapsulate PPP packets, so there are issues in making connections over OpenVPN over PPTP, or over PPTP over OpenVPN. The quickest way to achieve that is probably running PPTP in a host and OpenVPN in a guest OS (VM).why some pptp VPNsusually most "famous" companies that save logspptp shutting .... would be to save the original ip?Sorry, we don't understand, can you please elaborate?do you have any doors closed on your servers?Of course we take every care and we do our utmost best NOT to have (hidden) open backdoors on our servers and we check constantly against vulnerabilities. Running only open source software helps that a lot.Kind regards Quote Share this post Link to post
