Not connected, Your IP: 216.73.216.102
IsraSamuelsson
Abuses and court order
What happens when someone is committing some abuse
servers in sweden?
how have you guys know what is the ip?
as they do to stop the abuse?
and what happens if you have a valid court order
some contry ? will spend the logs?
deliver the HDS?
already received some order validates????
what happened?
servers in sweden?
deliver the HDS?
what happened?
We don't keep logs so we can't give away information that we do not have.
We can only say that until now no Air customer identity has ever been disclosed.
but what is
Collected statistics and history about my sessions: yes or no ?
collect from a VPN session is: Timestamp (date and server time) of the connection to us, duration of the connection, IP address used for the connection and bytes transferred.?? what saves?
Allow display of your username / login in public statistics ?? yes or no exatemente what is this?
thank you
but what is
It's a feature disabled by default. It can be enabled for your commodity or help us troubleshoot problems. It records date, time, duration and bytes exchanged for each user session. It is not possible to enable IP logging or any other logging.
It tells the system to display or not your login name in the servers monitor top data (on the right of the page), only for active sessions. It is disabled by default.
https://airvpn.org/status
