jonthomas 0 Posted ... First off I am a new first time member and so far am very pleased with your service. I would like you to verify that I have set up comodo correctly and was unsure if there were a more direct method of contacting you or if I should just post screen shots here? also I have tried to install open vpn 2.3.0 and when i launch the airvpn client it claims it doesn't see it and installs version 2.2.2? do have any thoughts on this? Thank you for your time. Quote Share this post Link to post
Staff 10336 Posted ... First off I am a new first time member and so far am very pleased with your service. I would like you to verify that I have set up comodo correctly and was unsure if there were a more direct method of contacting you or if I should just post screen shots here?Hello!Thank you for your subscription!You can post Comodo global rules and network zones screenshots here or through the "Contact us" form or send us via mail to info@airvpn.org, as you prefer.also I have tried to install open vpn 2.3.0 and when i launch the airvpn client it claims it doesn't see it and installs version 2.2.2?do have any thoughts on this?Please download the following client versions. For 64 bit systems:https://airvpn.org/repository/air_windows8_x86_64.zipFor 32 bit systems:https://airvpn.org/repository/air_windows8_i686.zipThe client is compiled for .NET framework 4. We'll soon rationalize the Air client and OpenVPN packages now that OpenVPN 2.3 stable version has been released.Kind regardsAirVPN Support Team Quote Share this post Link to post
Ellipsis 0 Posted ... In Comodo, under more, you have "manage my configurations", where you can export your Comodo config as an XML document. It is more difficult to read, but is also more detailed and does not truncate like screenshots do. Quote Share this post Link to post
