nethole
ANSWERED problems getting successful vpn as of 40 minutes ago
As of 40 minutes ago, All airvpn connections, regardless of server used would not complete.   On a cox communications provider in the United States, and having attempted to communicate with various european servers as well as US, both TCP and UDP based from several linux platforms via openvpn.   Did someone just changing something on the airvpn side? or am I experiencing a problem related to cox communication network changes .   I'll post logs once I'm in a position to do so
We have noticed that you are connected successfully, did the problem solve by itself or did you need to modify something?
roughly an hour or so after I had posted, the airvpn connections completed successfully.   I made no configuration changes to my openvpn clients (gluetun docker container, as well as ubuntu desktop).  The issue had resolved before I had collected enough information to determine if the issue was 'DNS related', or 'TCP/IP -routing' related, or if there was a server response specific problem
