I've been using DLNA to share file content and without Airvpn/Bluetit enabled this works across the network and devices can discover the server.
Once Bluetit is enabled the devices cannot discover the DLNA server, is there a way to allow LAN or specific addresses within the Bluetit config .rc?
Solution found by the user:
Quote
I've worked it out... Minidlna was only broadcasting to the network once every 15 minutes... It must've been a coincidence that it was working when the VPN was turned off. I've changed the broadcast to 10 seconds and it's working
