webshammo
ANSWERED Problems with listening in docker qbittorrent and media-stack
First, Transmission has been working fine for years with all this.
I thought I would upgrade to media-stack to get some other tools, but I cannot get qbitttorent to be connectable. I have tried many things found here, but I am still stuck.
Tried turning ipv6 on in custom.ovpn.  Tried tools->options->advanced->setting ipv4 only and not, setting network for tun0 and not.
The qbittorrent container is running and micro cp will punch holes and download, but tcp should work.  Inside that container netstat shows
tcp        0      0 10.29.238.152:22123     0.0.0.0:*               LISTEN      -
but https://airvpn.org/ports/ has the port forwarded, but testing for is open times out.
This is my docker-compose:
version: "3.9"
services:
  # To use/enable VPN, Run this compose file with --profile=vpn. Its highly recommended to use VPN.
  vpn:
    ## Read https://github.com/qdm12/gluetun-wiki/tree/main/setup/providers for details on configuring VPN for your service provider.
    container_name: vpn
    image: qmcgaw/gluetun:v3.40.0
    cap_add:
      - NET_ADMIN
    environment:
      - VPN_SERVICE_PROVIDER=custom # Valid values: nordvpn, expressvpn, protonvpn, surfshark or custom
      - FIREWALL_VPN_INPUT_PORTS=22123
      - OPENVPN_USER=${OPENVPN_USER:-""}
      - OPENVPN_PASSWORD=${OPENVPN_PASSWORD:-""}
      ## For list of server countries, visit https://raw.githubusercontent.com/qdm12/gluetun/master/internal/storage/servers.json
      ## When VPN_SERVICE_PROVIDER is custom. Comment the below line
      # - SERVER_COUNTRIES=${SERVER_COUNTRIES:-Switzerland}
      # - FREE_ONLY=on  # Valid with protonvpn only. Value willbe set "on" if using free subscription provided by protonvpn
      ## Enable below if VPN_SERVICE_PROVIDER=custom
      - VPN_TYPE=openvpn # or wireguard.
      ## If VPN_TYPE is openvpn
      - OPENVPN_CUSTOM_CONFIG=/gluetun/custom.conf
      ## If VPN_TYPE is wireguard. Replace below env variables as required.
      # - VPN_ENDPOINT_IP=1.2.3.4                                               # Replace with your wg endpoint ip or domain
      # - VPN_ENDPOINT_PORT=51820                                               # Replace with wg server port
      # - WIREGUARD_PUBLIC_KEY=wAUaJMhAq3NFutLHIdF8AN0B5WG8RndfQKLPTEDHal0=     # Replace with your wg public key
      # - WIREGUARD_PRIVATE_KEY=wOEI9rqqbDwnN8/Bpp22sVz48T71vJ4fYmFWujulwUU=    # Replace with your wg client private key
      # - WIREGUARD_PRESHARED_KEY=xOEI9rqqbDwnN8/Bpp22sVz48T71vJ4fYmFWujulwUU=  # Replaced with your wg pre-shared key
      # - WIREGUARD_ADDRESSES="10.64.222.21/32"                                 # Replace with wg address
    ## Enable volume if VPN_SERVICE_PROVIDER=custom and VPN_TYPE=openvpn is used
    volumes:
    #   - /yourpath/yourconfig.conf:/gluetun/config.conf:ro
      - /media/media/gbackup/bin/dockerMS.files/custom/default.ovpn:/gluetun/config.conf:ro
      - /media/media/gbackup/bin/dockerMS.files/custom/default.ovpn:/gluetun/custom.conf:rw
    networks:
      - mynetwork
    devices:
      - /dev/net/tun:/dev/net/tun
    # Uncomment/enable below ports if VPN is used/enabled
    ports:
      # qbittorrent ports
      - 5080:5080
      - 6881:6881
      - 6881:6881/udp
      # prowlarr ports
      - 9696:9696
    restart: "unless-stopped"
  ## Default credentials of qBittorrent - Username: admin password: adminadmin ##
  ## Change password after install from UI --> Tools --> Options --> WebUI ##
  qbittorrent:
    ### profiles: ["qbit"]
    container_name: qbittorrent
    image: lscr.io/linuxserver/qbittorrent:5.0.3
    # Unomment below if vpn is enabled
    depends_on:               # Uncomment this line if vpn is enabled
      - vpn                   # Uncomment this line if vpn is enabled
    # Comment below lines if VPN is enabled
    # networks:               # Comment this line if vpn is enabled
    #   - mynetwork           # Comment this line if vpn is enabled
    # Unomment below line if vpn is enabled
    network_mode: service:vpn
    environment:
      - PUID=1026
      - PGID=100
      - TZ=UTC
      - WEBUI_PORT=5080
    volumes:
      - /media/media/gbackup/bin/dockerMS.files/media-stack_qbittorrent-config:/config
      - /torrent/torrent/qbit:/downloads
      - /media/:/media
      - /volume3/video1/media/:/volume3/video1/media
      - /volume1/videoA/torrent/:/volume1/videoA/torrent
      - /2sort/:/2sort
      - /torrent/:/torrent
    ## Comment/Disable below ports if VPN is enabled
    # ports:
    #   - 5080:5080
    #   - 6881:6881
    #   - 6881:6881/udp
  radarr:
    container_name: radarr
    image: lscr.io/linuxserver/radarr:5.16.3
    networks:
    #   - mynetwork   # Comment this line if VPN is enabled
    ## Uncomment below lines if VPN is enabled
      mynetwork:
        ipv4_address: 172.20.0.34 # ${RADARR_STATIC_CONTAINER_IP} # It should be available IPv4 address in range of docker network `mynetwork` e.g. 172.20.0.2
    environment:
      - PUID=1026
      - PGID=100
      - TZ=UTC
    ports:
      - 7878:7878
    volumes:
      - /media/media/gbackup/bin/dockerMS.files/media-stack_radarr-config:/config
  sonarr:
    image: linuxserver/sonarr:4.0.11
    container_name: sonarr
    networks:
      mynetwork:
        ipv4_address: 172.20.0.33 # ${SONARR_STATIC_CONTAINER_IP} # It should be available IPv4 address in range of docker network `mynetwork` e.g. 172.20.0.2
    environment:
      - PUID=1026
      - PGID=100
      - TZ=UTC
    volumes:
      - /media/media/gbackup/bin/dockerMS.files/media-stack_sonarr-config:/config
    ports:
      - 8989:8989
    restart: unless-stopped
  prowlarr:
    container_name: prowlarr
    image: linuxserver/prowlarr:1.28.2
    # Uncomment below if vpn is enabled
    network_mode: service:vpn # Uncomment this line if vpn is enabled
    environment:
      - PUID=1026
      - PGID=100
      - TZ=UTC
    volumes:
      - /media/media/gbackup/bin/dockerMS.files/media-stack_prowlarr-config:/config
    # Comment below ports if VPN is enabled.
    # ports:
    #   - 9696:9696
networks:
  mynetwork:
    external: true
@webshammo
Apparently the remotely forwarded inbound ports reserved for your AirVPN account are not published in your compose file ports: section so the behavior you observe would be expected. Please add them and also set the environment variable FIREWALL_VPN_INPUT_PORTS accordingly, if necessary.
