Starch7305
ANSWERED Network issues after installing Eddie 2.24.6 on macOS
I'm on macOS 15.3 and Eddie 2.24.6. Eddie seems to be working fine but after I disconnect from the VPN I can't seem to be able to use the internet more broadly. Like, I have a wireguard client configured just because sometimes that's more practical and now it's not reaching a connection. Browsing the web also doesn't work. Surprisingly, pinging seems to work. I'm not quite sure how to debug this as my network expertise is barely above average. Let me know what info I could provide to help investigate this or steps I could take to try a fix.
Any help is very much appreciated, thank you!
After some research I identified the issue. DNS wasn't resetting properly. Problem solved!
Edited ... by Starch7305
Problem solved.
