AirBR 2 Posted ... (edited) Eddie doesnt connect - seems to be an issue with permissions: 2025.01.16 16:19:26 - Eddie version: 2.24.6 / macos_arm64, System: MacOS, Name: macOS 15.2, Version: 15.2, Framework: v4.0.30319 . 2025.01.16 16:19:26 - Raise system privileges . 2025.01.16 16:19:33 - Collect network information . 2025.01.16 16:19:35 - Profile options not found, using defaults. . 2025.01.16 16:19:36 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn) . 2025.01.16 16:19:36 - SSH - Version: OpenSSH_9.8p1, LibreSSL 3.3.6 (/usr/bin/ssh) . 2025.01.16 16:19:36 - SSL - Version: 5.57 (/Applications/Eddie.app/Contents/MacOS/stunnel) I 2025.01.16 16:19:36 - Ready . 2025.01.16 16:19:37 - Collect information about AirVPN completed I 2025.01.16 16:20:34 - Checking login ... ! 2025.01.16 16:20:35 - Logged in. I 2025.01.16 16:20:42 - Session starting. . 2025.01.16 16:20:42 - Activation of Network Lock - macOS - PF I 2025.01.16 16:20:43 - Checking authorization ... ! 2025.01.16 16:20:44 - Connecting to Mirach (Netherlands, Alblasserdam) . 2025.01.16 16:20:44 - Routes, add 213.152.162.71/32 for interface "en0". . 2025.01.16 16:20:44 - WireGuard > Setup start E 2025.01.16 16:20:44 - WireGuard > Error: Executable '/Applications/Eddie.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root; . 2025.01.16 16:20:44 - WireGuard > Stopping . 2025.01.16 16:20:44 - WireGuard > end ! 2025.01.16 16:20:44 - Disconnecting . 2025.01.16 16:20:44 - Routes, delete 213.152.162.71/32 for interface "en0". . 2025.01.16 16:20:44 - Collect network information . 2025.01.16 16:20:45 - Connection terminated. It then repeatedly trys over and over to connect but same issue in log. I note that wireguard-go is indeed not owned by root, but by me under the admin group, as are all files in that directory. -rwxr-xr-x@ 1 myuser admin 3859280 8 Jan 13:41 wireguard-go Any ideas? Edited ... by AirBR Share this post Link to post
Staff 10486 Posted ... 11 minutes ago, AirBR said: Any ideas? Hello! Please try to solve the issue by changing ownership of wireguard-go with the command (from a terminal): sudo chown root /Applications/Eddie.app/Contents/MacOS/wireguard-go After all, running as root only executable or script files owned by root is a nice security measure providing a complement against privilege escalation. A question: was your account ownership of that file the default setting you found after the installation? If so, did you install from the ZIP or DMG package? Kind regards Share this post Link to post
AirBR 2 Posted ... (edited) 11 minutes ago, Staff said: Hello! Please try to solve the issue by changing ownership of wireguard-go with the command (from a terminal): sudo chown root /Applications/Eddie.app/Contents/MacOS/wireguard-go After all, running as root only executable or script files owned by root is a nice security measure providing a complement against privilege escalation. A question: was your account ownership of that file the default setting you found after the installation? If so, did you install from the ZIP or DMG package? Kind regards Hi, This was the default untouched settings of these files after DMG package install. Additionally, trying to use the above to change ownership fails: myuser@myusers-Mac-mini MacOS % sudo chown root /Applications/Eddie.app/Contents/MacOS/wireguard-go Password: chown: /Applications/Eddie.app/Contents/MacOS/wireguard-go: Operation not permitted <did a sudo -i> myusers-Mac-mini:MacOS root# ls -al total 100504 drwxr-xr-x@ 17 myuser admin 544 8 Jan 14:40 . drwxr-xr-x@ 8 myuser admin 256 8 Jan 14:40 .. -rwxr-xr-x@ 1 myuser admin 18430416 8 Jan 13:57 Eddie-CLI -rwxr-xr-x@ 1 myuser admin 8699552 8 Jan 13:57 Eddie-UI -rwxr-xr-x@ 1 myuser admin 616176 8 Jan 13:41 eddie-cli-elevated -rwxr-xr-x@ 1 myuser admin 240640 8 Jan 13:41 eddie-cli-elevated-service -rwxr-xr-x@ 1 myuser admin 9583632 8 Jan 13:41 hummingbird -rw-r--r--@ 1 myuser admin 225440 8 Jan 13:41 libLib.Platform.MacOS.Native.dylib -rw-r--r--@ 1 myuser admin 4435392 8 Jan 13:41 libcrypto.3.dylib -rw-r--r--@ 1 myuser admin 209488 8 Jan 13:41 liblz4.dylib -rw-r--r--@ 1 myuser admin 195744 8 Jan 13:41 liblzo2.2.dylib -rw-r--r--@ 1 myuser admin 211008 8 Jan 13:41 libpkcs11-helper.1.dylib -rw-r--r--@ 1 myuser admin 970592 8 Jan 13:41 libssl.3.dylib -rwxr-xr-x@ 1 myuser admin 892144 8 Jan 13:41 openvpn -rwxr-xr-x@ 1 myuser admin 2739440 8 Jan 13:41 stunnel -rwxr-xr-x@ 1 myuser admin 123952 8 Jan 13:41 wg -rwxr-xr-x@ 1 myuser admin 3859280 8 Jan 13:41 wireguard-go myusers-Mac-mini:MacOS root# chown root wireguard-go chown: wireguard-go: Operation not permitted myusers-Mac-mini:MacOS root# Edited ... by AirBR Share this post Link to post
Staff 10486 Posted ... 7 minutes ago, AirBR said: Additionally, trying to use the above to change ownership fails: myuser@myusers-Mac-mini MacOS % sudo chown root /Applications/Eddie.app/Contents/MacOS/wireguard-go Password: chown: /Applications/Eddie.app/Contents/MacOS/wireguard-go: Operation not permitted Hello! A possible reason for which the superuser itself is not authorized to change file ownership is the immutability of that file (or directory). In this case the superuser must first turn off the immutable flag and then modify ownership. Another possible reason is the immutability of specific parts of the system à la FreeBSD. In this case turning off the immutable flag may require the system startup in single user mode. Please check whether wireguard-go has any immutable flags set. ls -lO Applications/Eddie.app/Contents/MacOS/wireguard-go If the file has immutable flags (uchg or schg), try to remove them with the command: sudo chflags nouchg /Applications/Eddie.app/Contents/MacOS/wireguard-go 7 minutes ago, AirBR said: This was the default untouched settings of these files after DMG package install. Thanks, we'll warn the packager. Kind regards Share this post Link to post
AirBR 2 Posted ... Just now, Staff said: Hello! A possible reason for which the superuser itself is not authorized to change file ownership is the immutability of that file (or directory). In this case the superuser must first turn off the immutable flag and then modify ownership. Another possible reason is the immutability of specific parts of the system à la BSD. In this case turning off the immutable flag may require the startup in single user mode. Thanks, we'll warn the packager. Kind regards Ok, so i got chown working, the "Terminal" app did not have permission to modify system files and i missed the notification advising this. After fixing that i had to change wireguard-go and wg to be owned by root to allow Eddie to work, but it is now connecting. 1 osmosis reacted to this Share this post Link to post
