ANSWERED Virtual servers traffic shaping [WAS: I am thinking of giving up]
In the last week I accidentally clicked on logs in eddie and i see thousands of AED decrypt error lines (bad packet id).  I use airvpn only for torrenting legal content, movies and series nothing else. I spent so many euros to VPSes becaue at first I thought its a problem with Netcup. I order a Blackfriday VPS Lfrom Liteserver.nl with 100TB traffic for 50 euros / 3 months again the same thing. My logs are flooded with AED Decrypt errors.
I have tried both in Linux and Windows Server 2019 in Netcup.
I have tried both in Linux and Windows Server 2025 in Liteserver.nl.
I have tried many UDP ports in Eddie. The problem is fixed with TCP if i remember correctly but the speeds are slow with qbittorrent. I have tried mssfix 1280 in UDP in Eddie as another Staff ports pointed out. Nothing works.
I tried experimental and stable versions of eddie.
But at the same time i think its not possible 2 different VPS providers do traffic shaping.
Its the last attempt for any idea and a solution by community or staff. Any help much appreciated. sorry for my bad english
18 minutes ago, georgek3r said:
My logs are flooded with AED Decrypt errors. ... at the same time i think its not possible 2 different VPS providers do traffic shaping.
Netcup does enforce traffic shaping, and exactly against UDP, so you had better drop this service. Liteserver.nl does not mention officially traffic shaping against UDP, but on the forums you can find many issues with it reported by customers (only UDP).
Assuming that traffic shaping is not enforced by liteserver.nl, a common reason for this error on virtual servers is the MTU size of the VPN Interface. Please try a smaller one through MTU option in WireGuard (you should test WireGuard before anything else). On the WireGuard's configuration file [Interface] section our Configuration Generator already adds
MTU = 1320
which is good for most networks. If that's not enough please try also 1280 bytes. You can edit the profile with any text editor. Of course test only from liteserver.nl as Netcup is not suitable. In Eddie 2.24.x beta you can modify WireGuard interface MTU in "Preferences" > "WireGuard" window.
6 minutes ago, Staff said:
A common reason for this error on virtual servers is the MTU size of the VPN Interface. Please try a smaller one through MTU option in WireGuard (you should test WireGuard before anything else). On the WireGuard's configuration file [Interface] section our Configuration Generator already adds
MTU = 1320
I dont have any kind of problems in wireguard, but as you have pointed out in my support ticket when i asked you is not safe for torrenting
https://airvpn.org/faq/wireguard/
19 minutes ago, georgek3r said:
I dont have any kind of problems in wireguard, but as you have pointed out is not safe for torrenting
Please re-read the previous message because in the meantime we have found out that Netcup enforces traffic shaping against UDP, so you will never be fine with Netcup, and we have edited the message accordingly. Switch to WireGuard safely, the privacy problems with WireGuard are irrelevant for p2p, anyway they are mitigated by our system and you can also re-generate your key anytime to change VPN IP address.
with this you mean from https://airvpn.org/devices/ section. correct?
thnks so much for your kind support.
On 1/2/2025 at 12:48 PM, Staff said:
Yes!
You're welcome.
I dont want to open another thread. Any idea why in wireguard in torrenting i get disconnected from NL servers and connected to German Servers automatically? I see this behaviour only on NL servers.
This is due to how your client software picks the destination server. In the thread original message you mentioned Eddie. It lets you build a white list of servers or countries according to your connection preferences, respectively in the "Servers" and "Countries" window.
