how to fix port forwarding.
I've tried the various settings I've seen here, but it still says connection timed out 110
thank you
@Bokika
A preliminary checklist:
  • please make sure that the listening program is really running and listening to the correct port, and that it is started only after the VPN connection has been established
  • if a bind option is available in the listening program settings please make sure that the program binds to the VPN interface and not to the physical network interface
  • if automatic port mapping options, including UPnP and NAT-PMP, are available on the listening program settings please make sure that they are all disabled
  • please make sure that no firewall rule blocks incoming packets to the listening program. You need to check while the system is connected to the VPN as some firewall tools change rule set according to the network type the system is connected to
I am not sure what is wrong in my config:
I have PFsense with the open ports with the NAT configured properly (to the world just to simplify, later ill restrict it)
Deluge is running and it shows AirVPN ip.
It works under Debian -> CasaOS -> Deluge (Docker)
Any idea of what am I doing wrong? Without the VPN was working fine the port forwarding locally
Open your own thread, providing logs, reproduction steps and what you already tried, linking to other threads which sound similar in your opinion, etc.
Don't hijack the threads of others seeking help with their issue.
