ixochina 5 Posted ... I have Samsung Galaxy S24+ smartphone. Every time I connect to VPN via Eddie, after few minutes or a while, the connection just drops. Android gives a notification that the "system revoked VPN connection, probably because another app requested VPN connection, Eddie has been disconnected". I have been noticing this several times in my old S10+ as well. Don't know how to solve this. I have other VPN apps, I tried to force stop them all, the issue still persists. Quote Share this post Link to post
Stalinium 54 Posted ... Do you have some adblocking apps perhaps? They too function by posing as a "VPN connection" 1 ixochina reacted to this Quote Share this post Link to post
Staff 10451 Posted ... 9 hours ago, ixochina said: I have Samsung Galaxy S24+ smartphone. Every time I connect to VPN via Eddie, after few minutes or a while, the connection just drops. Android gives a notification that the "system revoked VPN connection, probably because another app requested VPN connection, Eddie has been disconnected". I have been noticing this several times in my old S10+ as well. Don't know how to solve this. I have other VPN apps, I tried to force stop them all, the issue still persists. Hello! @Stalinium is right. You should be able to find the culprit by going into your Android settings and checking which app is enabled for Always on VPN. Kind regards 1 ixochina reacted to this Quote Share this post Link to post
