FunDusk
ANSWERED Wireguard sessions not showing as connected, port forwarding is closed
Currently connected using Wireguard on two devices, however here in airpvn.org/client it says "Sessions:You aren't currently connected to any server." and port forwarding can't be tested, also the apps show the ports as closed.  It has been working fine always, but today I started app my services and port forwarding is closed on all my devices.
We can see your WireGuard sessions on various servers and apparently the system reports them in your account "Client Area" correctly. Do you mean that you are using more connection slots than those appearing in the client area panel? If so, what are the server(s) whose connections from your client(s) do not appear on the panel?
Hi, I disconnected from the previous sessions (they were in Canada) and reconnected to Sweden and Canada and then the new sessions appeared in the client page and also the ports are open now.  I recall one of the Canada servers with the issue was Tegmen (184....) or something like that if you want to check. Thanks for the prompt reply, everything is fine now! Seems there were issues with just one server for me.
