Not connected, Your IP: 3.128.202.38
ActionJLASD
[SOLVED] AirVPN Login Failure w/Comodo FW
I was able to successfully setup Comodo Firewall to work with AirVPN, but unable to figure how to login to AirVPN while Comodo Firewall is Enabled. I currently have to Disable Comodo, login to AirVPN, then Re-Enable Comodo.
I get the following error message: "The remote name could not be resoved: 'airvpn.org'"
I am sure there is a simple thing I inputed wrong in setting up Comodo Firewall, but for the life of me I cant figure it out.
Thanks for any help.
Can you please send us the content of your hosts file?
Attached is a picture of the Global Settings. I hope that is what you were asking for in regards to Host File?
You can find the hosts file here: C:\Windows\system32\drivers\etc\hosts
Please launch a text editor with administrator privileges, open hosts and in order to allow "airvpn.org" resolution even when disconnected from the VPN add to your hosts file the line
85.17.207.151 airvpn.org [press ENTER at the end of the line]
Save the file and close the editor.
