pfolk
ANSWERED Constant Reconnect / Checking Route
I'm on latest version 2.21.8. I'm encountering constant reconnection attempts by AirVPN and/or checking route, although connection has been established and internet works.
But once it reconnects internet connection drops.
I've already logged out and in again, closed the app etc which used to help sometimes in the past.
Now when I click CANCEL button, it still hangs on "Checking Route" and never cancels - I have to force quit the app.
Is this a known issue? What are fixes/workarounds?
Here's a dump of the logs:
. 2024.11.13 11:59:12 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Enterprise LTSC 2019, Version: Microsoft Windows NT 10.0.17763.0, Mono/.Net: v4.0.30319
. 2024.11.13 11:59:12 - Raise system privileges
. 2024.11.13 11:59:14 - Reading options from C:\Users\Foo\AppData\Local\Eddie\default.profile
. 2024.11.13 11:59:15 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.11.13 11:59:15 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2024.11.13 11:59:15 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
W 2024.11.13 11:59:16 - Windows WFP, recovery of pending rules.
. 2024.11.13 11:59:16 - Recovery. Unexpected crash?
. 2024.11.13 11:59:16 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2024.11.13 11:59:16 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2024.11.13 11:59:16 - DNS IPv6 of a network adapter restored to original settings (Ethernet 4, to automatic)
. 2024.11.13 11:59:16 - DNS IPv4 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic)
. 2024.11.13 11:59:16 - DNS IPv6 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic)
. 2024.11.13 11:59:16 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2024.11.13 11:59:16 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
! 2024.11.13 11:59:16 - Deactivation of Network Lock
! 2024.11.13 11:59:16 - Activation of Network Lock - Windows Filtering Platform
I 2024.11.13 11:59:17 - Ready
. 2024.11.13 11:59:18 - Collect information about AirVPN completed
! 2024.11.13 11:59:26 - Logged out.
I 2024.11.13 11:59:29 - Checking login ...
! 2024.11.13 11:59:29 - Logged in.
I 2024.11.13 11:59:35 - Session starting.
I 2024.11.13 11:59:37 - Checking authorization ...
! 2024.11.13 11:59:37 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.11.13 11:59:37 - Routes, add 23.130.104.129/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)", already exists.
. 2024.11.13 11:59:37 - WireGuard > Setup start
. 2024.11.13 11:59:39 - WireGuard > Setup complete
. 2024.11.13 11:59:39 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.17763; amd64)
. 2024.11.13 11:59:39 - WireGuard > Watching network interfaces
. 2024.11.13 11:59:39 - WireGuard > Resolving DNS names
. 2024.11.13 11:59:39 - WireGuard > Creating network adapter
. 2024.11.13 11:59:39 - WireGuard > Using existing driver 0.10
. 2024.11.13 11:59:39 - WireGuard > Creating adapter
. 2024.11.13 11:59:39 - WireGuard > Using WireGuardNT/0.10
. 2024.11.13 11:59:39 - WireGuard > Eddie build 2
. 2024.11.13 11:59:39 - WireGuard > Dropping privileges
. 2024.11.13 11:59:39 - WireGuard > Interface created
. 2024.11.13 11:59:39 - WireGuard > Setup interface
. 2024.11.13 11:59:39 - WireGuard > Setting interface configuration
. 2024.11.13 11:59:39 - WireGuard > Peer 1 created
. 2024.11.13 11:59:39 - WireGuard > Monitoring MTU of default v4 routes
. 2024.11.13 11:59:39 - WireGuard > Interface up
. 2024.11.13 11:59:39 - WireGuard > Setting device v4 addresses
. 2024.11.13 11:59:39 - WireGuard > Monitoring MTU of default v6 routes
. 2024.11.13 11:59:39 - WireGuard > Setting device v6 addresses
. 2024.11.13 11:59:39 - WireGuard > Startup complete
. 2024.11.13 11:59:39 - WireGuard > Received first handshake
. 2024.11.13 11:59:39 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2024.11.13 11:59:39 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2024.11.13 11:59:39 - DNS leak protection with packet filtering enabled.
. 2024.11.13 11:59:39 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2024.11.13 11:59:39 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2024.11.13 11:59:40 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fd7d:76ee:e68f:a993::1)
. 2024.11.13 11:59:40 - DNS IPv4 of a network adapter forced (vEthernet (Default Switch), from automatic to 10.128.0.1)
. 2024.11.13 11:59:40 - DNS IPv6 of a network adapter forced (vEthernet (Default Switch), from automatic to fd7d:76ee:e68f:a993::1)
. 2024.11.13 11:59:40 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2024.11.13 11:59:40 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2024.11.13 11:59:41 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2024.11.13 11:59:41 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2024.11.13 11:59:41 - Routes, add 23.130.104.130/32 for interface "Eddie (WireGuard Tunnel)".
. 2024.11.13 11:59:42 - Routes, add 2620:7:6000:1:6747:2e2b:3ddb:cce2/128 for interface "Eddie (WireGuard Tunnel)".
. 2024.11.13 11:59:42 - Flushing DNS
I 2024.11.13 11:59:42 - Checking route IPv4
Can you please test Eddie 2.24.4 beta version and check whether or not the problem gets resolved? Please see here:
https://airvpn.org/forums/topic/57401-eddie-desktop-224-beta-released/
