MrGreen101 0 Posted ... Hi, Only just installed, first time user, limited knowledge, entered login credential, select connect to recommended server.... it then loops into multiple connection failures. Is there something I'm missing on initial setup? Many thanks I 2024.11.07 17:35:41 - Session starting. I 2024.11.07 17:35:41 - Checking authorization ... . 2024.11.07 17:35:42 - Using WinTun network interface "Local Area Connection (WireGuard Tunnel)" ! 2024.11.07 17:35:42 - Connecting to Ancha (Netherlands, Alblasserdam) . 2024.11.07 17:35:42 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:42 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", already exists. . 2024.11.07 17:35:42 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.07 17:35:42 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.07 17:35:42 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.07 17:35:42 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:42 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:42 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:42 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:42 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:42 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.07 17:35:42 - OpenVPN > UDP link local: (not bound) . 2024.11.07 17:35:42 - OpenVPN > UDP link remote: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:42 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.167:443, sid=dafa19f8 03b92913 . 2024.11.07 17:35:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.07 17:35:42 - OpenVPN > VERIFY KU OK . 2024.11.07 17:35:42 - OpenVPN > Validating certificate extended key usage . 2024.11.07 17:35:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.07 17:35:42 - OpenVPN > VERIFY EKU OK . 2024.11.07 17:35:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ancha, emailAddress=info@airvpn.org . 2024.11.07 17:35:42 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.07 17:35:42 - OpenVPN > [Ancha] Peer Connection Initiated with [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.242.1,dhcp-option DNS6 fde6:7a:7d20:4f2::1,tun-ipv6,route-gateway 10.8.242.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4f2::10f5/64 fde6:7a:7d20:4f2::1,ifconfig 10.8.242.247 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2024.11.07 17:35:43 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.07 17:35:43 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.242.1' . 2024.11.07 17:35:43 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4f2::1' . 2024.11.07 17:35:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.07 17:35:43 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.07 17:35:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.07 17:35:43 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.07 17:35:43 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.07 17:35:43 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.07 17:35:43 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.07 17:35:43 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.07 17:35:43 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:43 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:43 - OpenVPN > interactive service msg_channel=0 . 2024.11.07 17:35:43 - OpenVPN > open_tun . 2024.11.07 17:35:43 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.07 17:35:43 - OpenVPN > Exiting due to fatal error ! 2024.11.07 17:35:43 - Disconnecting . 2024.11.07 17:35:43 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:43 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", not exists. . 2024.11.07 17:35:43 - Connection terminated. I 2024.11.07 17:35:46 - Checking authorization ... . 2024.11.07 17:35:47 - Using WinTun network interface "Local Area Connection (WireGuard Tunnel)" ! 2024.11.07 17:35:47 - Connecting to Ancha (Netherlands, Alblasserdam) . 2024.11.07 17:35:47 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:47 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", already exists. . 2024.11.07 17:35:47 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.07 17:35:47 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.07 17:35:47 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.07 17:35:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.07 17:35:47 - OpenVPN > UDP link local: (not bound) . 2024.11.07 17:35:47 - OpenVPN > UDP link remote: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:47 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.167:443, sid=d14b2699 d2abf382 . 2024.11.07 17:35:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.07 17:35:47 - OpenVPN > VERIFY KU OK . 2024.11.07 17:35:47 - OpenVPN > Validating certificate extended key usage . 2024.11.07 17:35:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.07 17:35:47 - OpenVPN > VERIFY EKU OK . 2024.11.07 17:35:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ancha, emailAddress=info@airvpn.org . 2024.11.07 17:35:47 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.07 17:35:47 - OpenVPN > [Ancha] Peer Connection Initiated with [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.242.1,dhcp-option DNS6 fde6:7a:7d20:4f2::1,tun-ipv6,route-gateway 10.8.242.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4f2::10f5/64 fde6:7a:7d20:4f2::1,ifconfig 10.8.242.247 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2024.11.07 17:35:48 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.07 17:35:48 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.242.1' . 2024.11.07 17:35:48 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4f2::1' . 2024.11.07 17:35:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.07 17:35:48 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.07 17:35:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.07 17:35:48 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.07 17:35:48 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.07 17:35:48 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.07 17:35:48 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.07 17:35:48 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.07 17:35:48 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:48 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:48 - OpenVPN > interactive service msg_channel=0 . 2024.11.07 17:35:48 - OpenVPN > open_tun . 2024.11.07 17:35:48 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.07 17:35:48 - OpenVPN > Exiting due to fatal error ! 2024.11.07 17:35:48 - Disconnecting . 2024.11.07 17:35:48 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:48 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", not exists. . 2024.11.07 17:35:48 - Connection terminated. I 2024.11.07 17:35:51 - Checking authorization ... . 2024.11.07 17:35:52 - Using WinTun network interface "Local Area Connection (WireGuard Tunnel)" ! 2024.11.07 17:35:52 - Connecting to Ancha (Netherlands, Alblasserdam) . 2024.11.07 17:35:52 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:52 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", already exists. . 2024.11.07 17:35:53 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.07 17:35:53 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.07 17:35:53 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.07 17:35:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.07 17:35:53 - OpenVPN > UDP link local: (not bound) . 2024.11.07 17:35:53 - OpenVPN > UDP link remote: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:53 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.167:443, sid=aaf31b90 1ea52547 . 2024.11.07 17:35:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.07 17:35:53 - OpenVPN > VERIFY KU OK . 2024.11.07 17:35:53 - OpenVPN > Validating certificate extended key usage . 2024.11.07 17:35:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.07 17:35:53 - OpenVPN > VERIFY EKU OK . 2024.11.07 17:35:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ancha, emailAddress=info@airvpn.org . 2024.11.07 17:35:53 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.07 17:35:53 - OpenVPN > [Ancha] Peer Connection Initiated with [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:53 - OpenVPN > SENT CONTROL [Ancha]: 'PUSH_REQUEST' (status=1) . 2024.11.07 17:35:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.242.1,dhcp-option DNS6 fde6:7a:7d20:4f2::1,tun-ipv6,route-gateway 10.8.242.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4f2::10f5/64 fde6:7a:7d20:4f2::1,ifconfig 10.8.242.247 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2024.11.07 17:35:53 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.07 17:35:53 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.242.1' . 2024.11.07 17:35:53 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4f2::1' . 2024.11.07 17:35:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.07 17:35:53 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.07 17:35:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.07 17:35:53 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.07 17:35:53 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.07 17:35:53 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.07 17:35:53 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.07 17:35:53 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.07 17:35:53 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:53 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:53 - OpenVPN > interactive service msg_channel=0 . 2024.11.07 17:35:53 - OpenVPN > open_tun . 2024.11.07 17:35:53 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.07 17:35:53 - OpenVPN > Exiting due to fatal error ! 2024.11.07 17:35:53 - Disconnecting . 2024.11.07 17:35:53 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:54 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", not exists. . 2024.11.07 17:35:54 - Connection terminated. I 2024.11.07 17:35:57 - Checking authorization ... . 2024.11.07 17:35:57 - Using WinTun network interface "Local Area Connection (WireGuard Tunnel)" ! 2024.11.07 17:35:57 - Connecting to Ancha (Netherlands, Alblasserdam) . 2024.11.07 17:35:57 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:57 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", already exists. . 2024.11.07 17:35:58 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.07 17:35:58 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.07 17:35:58 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.07 17:35:58 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:58 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:58 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:35:58 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:35:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:58 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.07 17:35:58 - OpenVPN > UDP link local: (not bound) . 2024.11.07 17:35:58 - OpenVPN > UDP link remote: [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:58 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.167:443, sid=61ab26fa da874f1d . 2024.11.07 17:35:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.07 17:35:58 - OpenVPN > VERIFY KU OK . 2024.11.07 17:35:58 - OpenVPN > Validating certificate extended key usage . 2024.11.07 17:35:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.07 17:35:58 - OpenVPN > VERIFY EKU OK . 2024.11.07 17:35:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ancha, emailAddress=info@airvpn.org . 2024.11.07 17:35:58 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.07 17:35:58 - OpenVPN > [Ancha] Peer Connection Initiated with [AF_INET]213.152.162.167:443 . 2024.11.07 17:35:58 - OpenVPN > SENT CONTROL [Ancha]: 'PUSH_REQUEST' (status=1) . 2024.11.07 17:35:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.242.1,dhcp-option DNS6 fde6:7a:7d20:4f2::1,tun-ipv6,route-gateway 10.8.242.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4f2::10f5/64 fde6:7a:7d20:4f2::1,ifconfig 10.8.242.247 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2024.11.07 17:35:58 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.07 17:35:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.242.1' . 2024.11.07 17:35:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4f2::1' . 2024.11.07 17:35:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.07 17:35:58 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.07 17:35:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.07 17:35:58 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.07 17:35:58 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.07 17:35:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.07 17:35:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.07 17:35:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.07 17:35:58 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:58 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:35:58 - OpenVPN > interactive service msg_channel=0 . 2024.11.07 17:35:58 - OpenVPN > open_tun . 2024.11.07 17:35:58 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.07 17:35:58 - OpenVPN > Exiting due to fatal error ! 2024.11.07 17:35:58 - Disconnecting . 2024.11.07 17:35:58 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:35:59 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", not exists. . 2024.11.07 17:35:59 - Connection terminated. I 2024.11.07 17:36:02 - Checking authorization ... . 2024.11.07 17:36:02 - Using WinTun network interface "Local Area Connection (WireGuard Tunnel)" ! 2024.11.07 17:36:02 - Connecting to Ancha (Netherlands, Alblasserdam) . 2024.11.07 17:36:02 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:36:03 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", already exists. . 2024.11.07 17:36:03 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.07 17:36:03 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.07 17:36:03 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.07 17:36:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:36:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:36:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:36:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:36:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.167:443 . 2024.11.07 17:36:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.07 17:36:03 - OpenVPN > UDP link local: (not bound) . 2024.11.07 17:36:03 - OpenVPN > UDP link remote: [AF_INET]213.152.162.167:443 . 2024.11.07 17:36:03 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.167:443, sid=3925aebc 0bb45dee . 2024.11.07 17:36:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.07 17:36:03 - OpenVPN > VERIFY KU OK . 2024.11.07 17:36:03 - OpenVPN > Validating certificate extended key usage . 2024.11.07 17:36:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.07 17:36:03 - OpenVPN > VERIFY EKU OK . 2024.11.07 17:36:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ancha, emailAddress=info@airvpn.org . 2024.11.07 17:36:03 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.07 17:36:03 - OpenVPN > [Ancha] Peer Connection Initiated with [AF_INET]213.152.162.167:443 . 2024.11.07 17:36:03 - OpenVPN > SENT CONTROL [Ancha]: 'PUSH_REQUEST' (status=1) . 2024.11.07 17:36:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.242.1,dhcp-option DNS6 fde6:7a:7d20:4f2::1,tun-ipv6,route-gateway 10.8.242.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4f2::10f5/64 fde6:7a:7d20:4f2::1,ifconfig 10.8.242.247 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2024.11.07 17:36:03 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.07 17:36:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.242.1' . 2024.11.07 17:36:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4f2::1' . 2024.11.07 17:36:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.07 17:36:03 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.07 17:36:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.07 17:36:03 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.07 17:36:03 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.07 17:36:03 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.07 17:36:03 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.07 17:36:03 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.07 17:36:03 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:36:03 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:36:03 - OpenVPN > interactive service msg_channel=0 . 2024.11.07 17:36:03 - OpenVPN > open_tun . 2024.11.07 17:36:03 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.07 17:36:03 - OpenVPN > Exiting due to fatal error ! 2024.11.07 17:36:03 - Disconnecting . 2024.11.07 17:36:04 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:36:04 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", not exists. . 2024.11.07 17:36:04 - Connection terminated. I 2024.11.07 17:36:07 - Checking authorization ... . 2024.11.07 17:36:07 - Using WinTun network interface "Local Area Connection (WireGuard Tunnel)" ! 2024.11.07 17:36:07 - Connecting to Ancha (Netherlands, Alblasserdam) . 2024.11.07 17:36:07 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:36:08 - Routes, add 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", already exists. . 2024.11.07 17:36:08 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.07 17:36:08 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.07 17:36:08 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.07 17:36:08 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:36:08 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:36:08 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.07 17:36:08 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.07 17:36:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.167:443 . 2024.11.07 17:36:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.07 17:36:08 - OpenVPN > UDP link local: (not bound) . 2024.11.07 17:36:08 - OpenVPN > UDP link remote: [AF_INET]213.152.162.167:443 . 2024.11.07 17:36:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.167:443, sid=5f7cfb0d f049a64f . 2024.11.07 17:36:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.07 17:36:08 - OpenVPN > VERIFY KU OK . 2024.11.07 17:36:08 - OpenVPN > Validating certificate extended key usage . 2024.11.07 17:36:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.07 17:36:08 - OpenVPN > VERIFY EKU OK . 2024.11.07 17:36:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ancha, emailAddress=info@airvpn.org . 2024.11.07 17:36:08 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.07 17:36:08 - OpenVPN > [Ancha] Peer Connection Initiated with [AF_INET]213.152.162.167:443 . 2024.11.07 17:36:08 - OpenVPN > SENT CONTROL [Ancha]: 'PUSH_REQUEST' (status=1) . 2024.11.07 17:36:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.242.1,dhcp-option DNS6 fde6:7a:7d20:4f2::1,tun-ipv6,route-gateway 10.8.242.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4f2::10f5/64 fde6:7a:7d20:4f2::1,ifconfig 10.8.242.247 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2024.11.07 17:36:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.07 17:36:08 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.242.1' . 2024.11.07 17:36:08 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4f2::1' . 2024.11.07 17:36:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.07 17:36:08 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.07 17:36:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.07 17:36:08 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.07 17:36:08 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.07 17:36:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.07 17:36:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.07 17:36:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.07 17:36:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:36:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.07 17:36:08 - OpenVPN > interactive service msg_channel=0 . 2024.11.07 17:36:08 - OpenVPN > open_tun . 2024.11.07 17:36:08 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.07 17:36:08 - OpenVPN > Exiting due to fatal error ! 2024.11.07 17:36:08 - Disconnecting . 2024.11.07 17:36:09 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)". . 2024.11.07 17:36:09 - Routes, delete 213.152.162.167/32 for interface "Ethernet (Intel(R) I211 Gigabit Network Connection)", not exists. . 2024.11.07 17:36:09 - Connection terminated. I 2024.11.07 17:36:10 - Cancel requested. ! 2024.11.07 17:36:10 - Session terminated. Share this post Link to post
Staff 10415 Posted ... @MrGreen101 Hello! For some reason Eddie picks a pre-existing WireGuard interface for OpenVPN and OpenVPN doesn't like it. Maybe it's some interface driven by some customized driver of a third party. Try this to resolve: https://airvpn.org/forums/topic/56643-stuck-in-a-broken-route-never-connects/?do=findComment&comment=225323 Kind regards Share this post Link to post
MrGreen101 0 Posted ... (edited) Brilliant thank you, I didnt follow the advice exactly but it pointed me in the right direction.... I just uninstalled NordVPN and looks to be OK now 🙂 Many thanks... but I'm sure I will be back 🙂 Edited ... by MrGreen101 Share this post Link to post
