agentfridge
Help from VPN Newbie!
Newbie to this whole VPN stuff,
I have openVPN installed using the airvpn client (windows 8 version) on Windows 8
I managed to connect to a server, however once connected I go to the AirVPN site and it states I am not connected. I check my IP address using a website and it still states my standard IP ( I assume it should state the new one)
Sorry if I am missing something obvious, any help appreciated
thanks
Thanks for quick response :
26/12/2012 - 23:23 AirVPN client version: 1.7
26/12/2012 - 23:23 Reading options from C:\Users\Mike\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
26/12/2012 - 23:23 OpenVPN bundle version: OpenVPN 2.3_rc1
26/12/2012 - 23:23 OpenVPN current version: OpenVPN 2.3_rc1
26/12/2012 - 23:23 Ready.
26/12/2012 - 23:23 Login...
26/12/2012 - 23:23 Login success.
26/12/2012 - 23:23 Contacting service...
26/12/2012 - 23:23 Connecting...
26/12/2012 - 23:23 OpenVPN 2.3_rc1 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Nov 6 2012
26/12/2012 - 23:23 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
26/12/2012 - 23:23 Socket Buffers: R=[65536->65536] S=[65536->65536]
26/12/2012 - 23:23 UDPv4 link local: [undef]
26/12/2012 - 23:23 UDPv4 link remote: [AF_INET]108.59.11.194:443
26/12/2012 - 23:23 TLS: Initial packet from [AF_INET]108.59.11.194:443, sid=eff70c01 28888637
26/12/2012 - 23:23 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
26/12/2012 - 23:23 VERIFY OK: nsCertType=SERVER
26/12/2012 - 23:23 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
26/12/2012 - 23:23 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
26/12/2012 - 23:23 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
26/12/2012 - 23:23 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
26/12/2012 - 23:23 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
26/12/2012 - 23:23 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
26/12/2012 - 23:23 [server] Peer Connection Initiated with [AF_INET]108.59.11.194:443
26/12/2012 - 23:23 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
26/12/2012 - 23:23 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.32.58 10.4.32.57'
26/12/2012 - 23:23 OPTIONS IMPORT: timers and/or timeouts modified
26/12/2012 - 23:23 OPTIONS IMPORT: LZO parms modified
26/12/2012 - 23:23 OPTIONS IMPORT: --ifconfig/up options modified
26/12/2012 - 23:23 OPTIONS IMPORT: route options modified
26/12/2012 - 23:23 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
26/12/2012 - 23:23 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
26/12/2012 - 23:23 open_tun, tt->ipv6=0
26/12/2012 - 23:23 TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{4E0982E7-FBBC-4EB2-B15C-1FECA924369C}.tap
26/12/2012 - 23:23 TAP-Windows Driver Version 9.9
26/12/2012 - 23:23 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.32.58/255.255.255.252 on interface {4E0982E7-FBBC-4EB2-B15C-1FECA924369C} [DHCP-serv: 10.4.32.57, lease-time: 31536000]
26/12/2012 - 23:23 Successful ARP Flush on interface [18] {4E0982E7-FBBC-4EB2-B15C-1FECA924369C}
26/12/2012 - 23:23 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
26/12/2012 - 23:23 Route: Waiting for TUN/TAP interface to come up...
26/12/2012 - 23:24 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
26/12/2012 - 23:24 Route: Waiting for TUN/TAP interface to come up...
26/12/2012 - 23:24 C:\WINDOWS\system32\route.exe ADD 108.59.11.194 MASK 255.255.255.255 192.168.1.254
26/12/2012 - 23:24 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
26/12/2012 - 23:24 Route addition via IPAPI succeeded [adaptive]
26/12/2012 - 23:24 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.32.57
26/12/2012 - 23:24 Warning: route gateway is not reachable on any active network adapters: 10.4.32.57
26/12/2012 - 23:24 Route addition via IPAPI failed [adaptive]
26/12/2012 - 23:24 Route addition fallback to route.exe
26/12/2012 - 23:24 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
26/12/2012 - 23:24 OK!
26/12/2012 - 23:24 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.32.57
26/12/2012 - 23:24 C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.32.57
26/12/2012 - 23:24 SYSTEM ROUTING TABLE
26/12/2012 - 23:24 .254 p=0 i=12 t=4 pr=3 a=679 h=0 m=25/0/0/0/0
26/12/2012 - 23:24 .57 p=0 i=12 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
26/12/2012 - 23:24 10.4.32.57 p=0 i=12 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
26/12/2012 - 23:24 .255 192.168.1.254 p=0 i=12 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
26/12/2012 - 23:24 .0.1 p=0 i=1 t=3 pr=2 a=705 h=0 m=306/0/0/0/0
26/12/2012 - 23:24 127.0.0.1 p=0 i=1 t=3 pr=2 a=705 h=0 m=306/0/0/0/0
26/12/2012 - 23:24 55.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=705 h=0 m=306/0/0/0/0
26/12/2012 - 23:24 32.57 p=0 i=12 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
26/12/2012 - 23:24 192.168.1.6 p=0 i=12 t=3 pr=2 a=679 h=0 m=281/0/0/0/0
26/12/2012 - 23:24 55 192.168.1.6 p=0 i=12 t=3 pr=2 a=679 h=0 m=281/0/0/0/0
26/12/2012 - 23:24 .255 192.168.1.6 p=0 i=12 t=3 pr=2 a=679 h=0 m=281/0/0/0/0
26/12/2012 - 23:24 68.1.6 p=0 i=12 t=3 pr=2 a=683 h=0 m=281/0/0/0/0
26/12/2012 - 23:24 55.255 192.168.1.6 p=0 i=12 t=3 pr=2 a=683 h=0 m=281/0/0/0/0
26/12/2012 - 23:24 SYSTEM ADAPTER LIST
26/12/2012 - 23:24 TAP-Windows Adapter V9
26/12/2012 - 23:24 Index = 18
26/12/2012 - 23:24 EB2-B15C-1FECA924369C}
26/12/2012 - 23:24 IP = 0.0.0.0/0.0.0.0
26/12/2012 - 23:24 MAC = 00:ff:4e:09:82:e7
26/12/2012 - 23:24 55.255.255
26/12/2012 - 23:24 DHCP SERV =
26/12/2012 - 23:24 ed Dec 26 23:24:13 2012
26/12/2012 - 23:24 DNS SERV =
26/12/2012 - 23:24 rtual Adapter
26/12/2012 - 23:24 Index = 14
26/12/2012 - 23:24 D51-A228-CCFCC8F4D631}
26/12/2012 - 23:24 MAC = 8a:9f:fa:38:ed:ef
26/12/2012 - 23:24 CI-E Gigabit Ethernet Controller (NDIS 6.30)
26/12/2012 - 23:24 Index = 13
26/12/2012 - 23:24 38A-BD2A-CCE608E5BF43}
26/12/2012 - 23:24 MAC = 20:6a:8a:2a:f2:0b
26/12/2012 - 23:24 Adapter
26/12/2012 - 23:24 Index = 12
26/12/2012 - 23:24 432-87C9-F15E040D75EF}
26/12/2012 - 23:24 5.255.0
26/12/2012 - 23:24 MAC = 88:9f:fa:38:ed:ef
26/12/2012 - 23:24 /255.255.255.255
26/12/2012 - 23:24 54/255.255.255.255
26/12/2012 - 23:24 ed Dec 26 23:12:58 2012
26/12/2012 - 23:24 hu Dec 27 23:12:58 2012
26/12/2012 - 23:24 4/255.255.255.255
26/12/2012 - 23:24 Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
26/12/2012 - 23:24 Starting Management Interface...
26/12/2012 - 23:24 Checking...
26/12/2012 - 23:24 Retrieve statistics...
26/12/2012 - 23:24 Connected.
Hi Admin,
finally got it working, The problem was when I installed Open VPN I had not right clicked and "run as admin"
Didn't see this on the instruction page so might be worth adding it (if I missed it apologies!)
thanks again ,
