charoki60
ANSWERED Expose Jellyfin to internet through AirVPN port forwarding
I'm trying to expose Jellyfin to internet through AirVPN port forwarding, but I can't for the life of me make it to work.
You can see the gluetun stack I'm using bellow
45554 is the port I'm trying to use for Jellyfin.
42148 is the one I'm using for Qbittorrent. You can ignore this, it's working perfectly.
I have no idea what I could be doing wrong, tried everything that came to my mind.
In the AirVPN => Client Area => Forwarded Port, I tried to bind 45554 to "local port" 8096, without success.
I'd really appreciate any help,
Thanks for your time!
services:
  gluetun:
    image: qmcgaw/gluetun
    container_name: gluetun
    cap_add:
      - NET_ADMIN
    devices:
      - /dev/net/tun:/dev/net/tun
    environment:
      - VPN_SERVICE_PROVIDER=airvpn
      - VPN_TYPE=wireguard
      - WIREGUARD_PRIVATE_KEY=xxx
      - WIREGUARD_PRESHARED_KEY=xxx
      - WIREGUARD_ADDRESSES=xxx
      - SERVER_REGIONS=Europe
      - FIREWALL_VPN_INPUT_PORTS=45554,42148
    ports:
      - 8080:8080 # Qbittorrent1
      - 42148:42148 # Qbittorrent1 port forwarding
      - 42148:42148/udp # Qbittorrent1 port forwarding
      - 8181:8181 # Qbittorrent2
      - 6881:6881 # Qbittorrent2 port
      - 6881:6881/udp # Qbittorrent2 port
      - 8096:8096 # Jellyfin
      - 45554:45554
  qbittorrent:
    image: lscr.io/linuxserver/qbittorrent:latest
    container_name: qbittorrent1
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Etc/UTC
      - WEBUI_PORT=8080
      - TORRENTING_PORT=42148
    volumes:
      - /home/charly/container/qbittorrent1/appdata/:/config
      - /home/charly/Téléchargements/:/downloads
    network_mode: 'service:gluetun'
    depends_on:
      - gluetun
    restart: unless-stopped
  qbittorrent2:
    image: qbittorrentofficial/qbittorrent-nox:latest
    container_name: qbittorrent2
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Etc/UTC
      - TORRENTING_PORT=6881
      - QBT_LEGAL_NOTICE=confirm
      - QBT_VERSION=latest
      - QBT_WEBUI_PORT=8181
    volumes:
      - /home/charly/container/qbittorrent2/appdata/:/config
    depends_on:
      - gluetun
  jellyfin:
    image: jellyfin/jellyfin
    container_name: jellyfin
    volumes:
      - /home/charly/container/jellyfin/config:/config
      - /home/charly/container/jellyfin/cache:/cache
      - /home/charly/container/jellyfin/movies:/movies
      - /home/charly/container/jellyfin/tvshows:/tvshows
    restart: 'unless-stopped'
    environment:
      - TZ=Etc/UTC
      - PUID=1000
      - PGID=1000
HI guys,
i was tryed do this with rhis video https://www.youtube.com/watch?v=LV3mcfqNgcQ , but still not working.
Here is my compose. Maybe someone figure it out.
Quote
services:
  jellyfin:
    ports:
      - 8097:8097/tcp
      # - 7359:7359/udp
    volumes:
      - ./jellyfin-config:/config
      - ./jellyfin-cache:/cache
      - /mnt/#/media:/media
    environment:
      - PUID=568
      - PGID=568
      - TZ=Europe/Warsaw
      - /dev/dri:/dev/dri
  gluetun:
    container_name: gluetun2
    cap_add:
      - NET_ADMIN
    devices:
      - /dev/net/tun
    ports:
      # Expose qBittorrent's web UI and torrent ports through VPN
      - #airvpn_port:8097 # Jellyfin
    volumes:
      - ./gluetun:/gluetun
    environment:
      - TZ=#
      - WIREGUARD_PRIVATE_KEY=#
      - WIREGUARD_PRESHARED_KEY=#
      - WIREGUARD_ADDRESSES=#
      - VPN_LAN_NETWORK=#
    sysctls:
      - net.ipv4.conf.all.src_valid_mark=1
      - net.ipv6.conf.all.disable_ipv6=1
    depends_on:
      - jellyfin
networks: {}
When i add end point manualy in compose its drop error - "ERROR [vpn] finding a VPN server: target IP address not found: in 250 filtered connections".
Without Endpoint it showing evething is healthy but when i check "curl ifconfig.io" is some ipv6, but no mine end point ipv4.
When i click into jellyfin port its now show jellfin gui.
I`not using 8096 because its busy by running jellyfin serwer.
Jellyfin serwer 8096 i have on Truenas scale
Jellyfin serwer 8097 i wanna run on Truenas->Dockge
I have already qbittorrent on Docke and its working fine.
God bless you all for help;)
Hello there!
Is there a reason to use Jellyfin through the VPN and port forward it?
The most common ways of sharing Jellyfin/Plex would be to have a reverse proxy on your network like Nginx Proxy Manager and accessing it from there if you are outside your home network.
Br Cbkosl
@Bobo90
Your compose file lacks the proper setting of the FIREWALL_VPN_INPUT_PORTS environment variable. If you set it on the command line options fine, but if not you must add it and set it properly. The FIREWALL_VPN_INPUT_PORTS environment variable in Gluetun specifies a comma-separated list of ports that must be allowed through the firewall. Without it, packets forwarded by the VPN server will be dropped by GlueTun firewall.
About this error:
you should be able to resolve it by reading the documentation specific for AirVPN:
https://github.com/qdm12/gluetun-wiki/blob/main/setup/providers/airvpn.md
@cbkosl
I have CGNAT internet. At this moment i get to my web with tailscale and its fine, but i want to share my media with family.
@Staff
i ad "FIREWALL_VPN_INPUT_PORTS=#port_from_airvpn" and nothing change.
i read topic from your link and nothing change, same error.
Reading it is not sufficient, then you have to change your configuration accordingly. How did you add the end point (destination VPN server)?
 i added it to compose
Quote
environment:
- WIREGUARD_ENDPOINT_IP=#ip
 - WIREGUARD_ENDPOINT_PORT=#port
Few attemps ago i tried with wg0.conf but docker didnt read it
On 12/6/2025 at 9:01 PM, Bobo90 said:
 i added it to compose Few attemps ago i tried with wg0.conf but docker didnt read it
environment:
This is potentially the problem, We can't be sure because for some unfathomable reason you deleted once again the endpoint address and the port. Or did you literally enter "#ip" and "#port"?
By the way, when VPN_SERVICE_PROVIDER environment variable is set to an integrated VPN such as AirVPN (as it is in your case) you can rely on more proper variables that will prevent you from entering wrong addresses and/or ports. Please set the proper environment variables, delete the quoted ones (quoted here above), and check whether the problem gets resolved. Please see here again: https://github.com/qdm12/gluetun-wiki/blob/main/setup/providers/airvpn.md
Hi
i send working compose.
Only problem is with "unhealthy" gluetun when serwer/port is not used.
Quote
services:
  jellyfin:
    network_mode: service:gluetun
    volumes:
      - /#/#/Stacks/jellyfin/jellyfin-config:/config
      - /#/#/Stacks/jellyfin/jellyfin-cache:/cache
      - /#/#/media:/media
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Europe/Warsaw
    devices:
      - /dev/dri:/dev/dri
  caddy:
    image: serfriz/caddy-duckdns:latest # Obraz Caddy z wtyczką DuckDNS
    container_name: caddy
    environment:
      - DUCKDNS_TOKEN=#token
    volumes:
      - /#/#/Stacks/jellyfin/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /#/#/Stacks/jellyfin/caddy/data:/data
      - /#/#/Stacks/jellyfin/caddy/config:/config
    depends_on:
      - gluetun
      - jellyfin
  gluetun:
    image: qmcgaw/gluetun:latest
    cap_add:
      - NET_ADMIN
    devices:
      - /dev/net/tun
    ports:
      - #airvpnport:#airvpnport/tcp
      - #airvpnport:#airvpnport/udp
      - 8096:8096/tcp
    volumes:
      - /#/#/Stacks/jellyfin/gluetun:/gluetun
      - /#/#/Stacks/jellyfin/gluetun/wg0.conf:/gluetun/wireguard/wg0.conf:ro
    environment:
      - TZ=#
      - FIREWALL_VPN_INPUT_PORTS=#airvpnport,8096 # Porty przez VPN
      - FIREWALL_INPUT_PORTS=#airvpnport,8096 # Porty wejściowe (TO BRAKOWAŁO!)
      - FIREWALL_OUTBOUND_SUBNETS=192.168.1.0/24 # Pozwól na lokalne
      - VPN_SERVICE_PROVIDER=custom
      - DNS_ADDRESS=8.8.8.8 # ← ZMIEŃ na 8.8.8.8
      - VPN_IPV6=off
      - DOT=off
      - DNS_KEEP_NAMESERVERS=on
      - WIREGUARD_MTU=1320
    sysctls:
networks: {}
